Old 07-03-2016, 04:59 PM   #1
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
Exhaust question, Rattle or Rasp
So right now I'm running a magna flow catback without a resonator in the mid pipe area. Sounded great before, then today I installed a Berk HFC. After install and making sure I installed all the gaskets and everything was all tight, upon driving it around while it was cold, there was rattling from 4k-7k range. Once it warmed up throughout the day there was a different rattling sound from 4k-4.5k. Now will this be fixed by adding a resonator in the mid pipe area, or is there another reason why it's rattling.
KungFuWaffle is offline   Reply With Quote
Old 07-03-2016, 07:39 PM   #2
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Resonator won't fix a rattle.
Old 07-03-2016, 09:25 PM   #3
humfrz
I reckon some part of your exhaust is lose or banging up against something.
humfrz
Old 07-04-2016, 01:03 AM   #4
KungFuWaffle
Drives: Whiteout
humfrz
Well, went back under the car and checked all the bolts, and tried wiggling the pipe and it wasn't hitting n anything.
Going to try to put a resonator back on and see if it helps.
Old 07-04-2016, 03:02 AM   #5
humfrz
Well, OK....... that might do it .......
Sometimes when an engine "torques over" a part of the upper exhaust can hit and vibrate on a part of the frame/undercarriage ......
I hope you get it sorted out ......
humfrz
Old 07-05-2016, 04:17 PM   #6
KungFuWaffle
Drives: Whiteout
humfrz
Alright problem solved, put a resonator on and no more rattle/rasp. Only problem now.... It's not loud enough....
Old 07-05-2016, 05:40 PM   #7
humfrz
humfrz redneck fix ....... pound a piece of pipe half way through the resonator ......
Old 07-05-2016, 09:11 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
I'll bet you that the Berk pipe has a crack in it. A hairline crack can be a bitch to find and will make a rattle that will change with the temp of the pipe. Check around the flanges and all the welds. Bend and flex them. It could also be in the hanger area.
I had a catback exhaust with hairline cracks at some brackets in the axleback section and once the cracks were welded the rattle went away.
Startup: Loud metallic (rasp?) sound from middle/under of car, not from exhaust johnmk Engine, Exhaust, Transmission 15 06-04-2016 09:20 PM
My exhaust setup produces wayyyy to much rasp. Helpppp BoostedWrbBrz Engine, Exhaust, Transmission 12 07-27-2014 01:14 PM
How to get rid of the rasp in my exhaust sound? DrewIsAmus Engine, Exhaust, Transmission 8 02-04-2014 11:41 PM
Best exhaust rumble - no rasp DarkestBuddha Engine, Exhaust, Transmission 5 07-17-2013 02:49 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
