Drives: Scion FRS
If you know a solution to this problem please feel free to let us know,thank you <3
If you install a header, you're getting rid of your primary cat so there's going to be a certain amount of "rasp" that comes with the territory. I don't know what you're running for the rest of your exhaust, but if it's too raspy, you might want to add a resonator.
#3 | |
Drives: Scion FRS
And I am also running these headers Let me know what you think! Last edited by Squido3J; 04-02-2014 at 03:03 PM. |
Drives: SWP FR-S
Any sound clips?
Drives: Scion FRS
#6 | |
Nevermind: I just read the couple links above. A) EL header = more raspy, especially catless. B) That exhaust is a cheap ripoff of an N1 and the resonator looks a lot smaller. You may want to go with something a bit more muffled to combat the rasp. Something like the Q300 is much quieter, but will be much less raspier. Sound is a difficult one depending on the header. EL can be raspy on one exhaust then turn around and use a UEL header on the same exhaust and the rasp goes away. So much goes into acoustics. My advice, keep a catted front pipe, or resonated, and have a resonated catback. Removing any of those components will introduce rasp most likely. Going loud and not raspy is a balancing act.... Trust me, I know. It took me a year of swapping exhausts till I found the combo I love. |
| Raspy header and weird noise | Scalzo | Engine, Exhaust, Transmission | 39 | 08-24-2020 07:40 PM |
| Borla Header Rattle Noise | tonytduc | Issues | Warranty | Recalls / TSB | 40 | 05-09-2014 01:28 PM |
| Borla UEL Header noise? | frslee | Engine, Exhaust, Transmission | 22 | 04-04-2014 11:37 PM |
| Aftermarket Header Dying Cricket Noise | Squido3J | Engine, Exhaust, Transmission | 6 | 03-31-2014 06:07 AM |
| Noise after KW V3 install? | Blizzard | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-28-2013 03:08 PM |
