#113 | |
Drives: 13 BRZ Limited
#114 |
Drives: C5, GT-86, '24 Colorado TrailBoss
well im working on my own lighter rear brake setup
Subaru 2pots calipers - someone advertised 3lbs lighter per side but once you ad in adapters it looks like ill be lucky to get a pound per side Base model 11mm thin rotors - 2lbs lighter per side rotational since there will be a gap of 8mm between the pads ive made spacers to push out the brake pads. I got 3.2mm spacers on both sides. So there should only be a 1.6mm gap. This is all experimental until I install it next week but ive got all the pieces ready. If it doesn't work Ill just install the 2pots on the current stock rotors ![]()
#115 |
Drives: 2013 Subaru BRZ Premium MT
SuperTom, the company called RacingBrake makes stockish sized two-piece rear rotors with an aluminum hat. They also put in an iron sleeve to allow functioning of the e-brake, so there isn't much weight loss. You might be able to do something with this, if your custom shims don't work out.
I like your attempts at lightening the rear brake setup, and I'm interested to see the results. Thanks. Sent from my SM-G930P using Tapatalk |
| The Following User Says Thank You to sifl For This Useful Post: | SuperTom (01-28-2020) |
#116 |
Drives: Subaru BRZ
Move the engine into the trunk..
| The Following User Says Thank You to JD001 For This Useful Post: | strat61caster (01-28-2020) |
#117 | |
read newest post on my build thread http://www.ft86club.com/forums/showt...71#post3297671 |
| Making the BRZ ever lighter | Alabang BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-16-2014 08:57 AM |
| Are dry carbon fiber front 1/4 panels lighter than OEM? | Superhatch | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-27-2013 03:47 AM |
| Better to go wider or lighter? | BRAWL | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 08-02-2012 09:48 PM |
| Increased whp by having lighter wheels | mechaghost | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 07-03-2012 12:46 AM |
| What return from going with lighter wheels? | bazguitarman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 06-01-2012 09:35 AM |
