Old 01-28-2020, 07:22 AM   #113
MaverickMonk
Drives: 13 BRZ Limited
Originally Posted by SuperTom View Post
The DBA's ive found are for the front. Still haven't found anything for the rear. If im mistaken please send a link
Yeah I read through that whole build. He also had a lot of custom titanium parts made as well.
Ive just bought a punch and flare tool to do some experiment on non structural metal...
You are not mistaken, I just can’t read. They only have up through the 4000 series (single piece) for the rears. Shame, I was thinking they’d be a great way to shed weight without paying 2k+ for a bbk
MaverickMonk is offline   Reply With Quote
Old 01-28-2020, 09:41 AM   #114
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
well im working on my own lighter rear brake setup
Subaru 2pots calipers - someone advertised 3lbs lighter per side but once you ad in adapters it looks like ill be lucky to get a pound per side
Base model 11mm thin rotors - 2lbs lighter per side rotational
since there will be a gap of 8mm between the pads ive made spacers to push out the brake pads. I got 3.2mm spacers on both sides. So there should only be a 1.6mm gap.
This is all experimental until I install it next week but ive got all the pieces ready. If it doesn't work Ill just install the 2pots on the current stock rotors
SuperTom is offline   Reply With Quote
Old 01-28-2020, 11:25 AM   #115
sifl
sifl's Avatar
Drives: 2013 Subaru BRZ Premium MT
SuperTom, the company called RacingBrake makes stockish sized two-piece rear rotors with an aluminum hat. They also put in an iron sleeve to allow functioning of the e-brake, so there isn't much weight loss. You might be able to do something with this, if your custom shims don't work out.
I like your attempts at lightening the rear brake setup, and I'm interested to see the results. Thanks.
Sent from my SM-G930P using Tapatalk
sifl is offline   Reply With Quote
The Following User Says Thank You to sifl For This Useful Post:
SuperTom (01-28-2020)
Old 01-28-2020, 02:36 PM   #116
JD001
JD001's Avatar
Drives: Subaru BRZ
Move the engine into the trunk..
The Following User Says Thank You to JD001 For This Useful Post:
strat61caster (01-28-2020)
Old 02-08-2020, 04:06 PM   #117
SuperTom
SuperTom's Avatar
Did get this completed today successfully!
read newest post on my build thread
http://www.ft86club.com/forums/showt...71#post3297671
Making the BRZ ever lighter Alabang BRZ Cosmetic Modification (Interior/Exterior/Lighting) 10 04-16-2014 08:57 AM
Are dry carbon fiber front 1/4 panels lighter than OEM? Superhatch Cosmetic Modification (Interior/Exterior/Lighting) 5 05-27-2013 03:47 AM
Better to go wider or lighter? BRAWL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-02-2012 09:48 PM
Increased whp by having lighter wheels mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 07-03-2012 12:46 AM
What return from going with lighter wheels? bazguitarman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 06-01-2012 09:35 AM
