Old 08-06-2015, 03:43 PM   #1
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
what more can i do for a lighter front end?
I`m trying to lighten up the front end to balance the car a bit better, and so far I have done the KC machines battery kit with the Shorai battery. That alone was a huge improvement in terms of feel of the car. I was quite impressed from the amount of difference it made, despite the position of the battery being so close to the center of the car.
things already done:
tomei UEL header (-5lbs)
tomei overpipe (-1lb)
Shorai battery kit (-22.75lbs)
intake snorkel and some other stuff (maybe a -1lb)
to-do list:
Beatrush bumper beam ( i believe it`s -5 lbs)
APR brake ducts (gets rid of the fog lights.. no idea how much those weigh)
drain or get rid of washer fluid tank (no idea how much it weighs..)
things that will add/have added weight:
STI front lip (probably 2-3lbs)
oil cooler (no idea how much it would weigh)
other ideas I have are brake kits that lose weight like the AP racing front kit (Sprint kit is 20lbs, Endurance kit 10lbs)...
Wheels will help, but that is an overall weight loss rather than just the front end. At the end of the day, overall weight loss is more important than the balance, but just trying to see what I can do with the front end of the car first...
mokinbird87 is offline   Reply With Quote
Old 08-06-2015, 04:01 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Remove bumper and headlights?? haha jk, what about removing skid plates or a dry carbon hood (only like 2 lbs less) do a big brake kit those can save some unsprung mass off the front and preform better them oem?
Old 08-06-2015, 04:11 PM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
That would be hard.... But most weight easy savings should be from suspension/wheel components?
Old 08-06-2015, 04:24 PM   #4
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Lighter fenders, remove ac, remove stereo/speakers, floor mats, lighter flywheel, lighter wheels and tires, lighter pulleys, lighter brakes...
murdoc is offline   Reply With Quote
Old 08-06-2015, 04:47 PM   #5
OkieSnuffBox
Drives: '23 BRZ Limited
I wouldn't mess with the bumper beam since this is a street car. No point in making it more susceptible to damage.
Then again, if you claim you can tell a HUGE difference from the battery change alone (lolz) maybe it's worth.
The small Wilwood BBK that FT86SF sells pulls 32lbs out of the front brakes (both sides combined).
The Following 4 Users Say Thank You to OkieSnuffBox For This Useful Post:
drewbot (08-07-2015), ka-titties (01-28-2020), strat61caster (08-07-2015), wparsons (08-08-2015)
Old 08-06-2015, 04:52 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Why the front end?
What is your end goal (other than "a lighter car")?
Why the front end specifically?
You want to lose weight but you don't explain why the front end. You can easily accomplish the same w/ bucket seats, taking out all the stuff in the trunk, swapping your trunk, and removing the glass...
-alex
Old 08-06-2015, 04:57 PM   #7
OkieSnuffBox
My guess would be IIRC, the F/R weight distribution on this car is 58/42 stock.
But I'm guessing it's because the car is "FUH RAZE!"
Old 08-06-2015, 05:00 PM   #8
DAEMANO
Time Traveller
Lose some weight off that bigazz!
Then look here: Anthony's 4 Step Diet Program @Anthony
Also...
Much lighter wheels and tires (you chose both heavy wheels & tires)
Much lighter front seats
PTuning Washer bottle
Battery relocation to trunk
Carbon Fiber Fenders
Aluminum oil pan
Single DIN head-unit or Stereo delete
Raceseng (or other) AC delete
Growler tube delete (if not already done)
The Following 4 Users Say Thank You to DAEMANO For This Useful Post:
Anthony (08-10-2015), raven1231 (08-07-2015), strat61caster (08-07-2015), Tristor (08-30-2018)
Old 08-06-2015, 05:24 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
Remove the interior except drivers seat. Wheels.
If this is a street car the cost/lb will be shocking!
Lose weight (body) and lower/slide your seat to the max.
If you take off 100 lbs and find the difference profound then more power to you, and your wallet.
Old 08-06-2015, 05:45 PM   #10
OkieSnuffBox
He's already done a super lightweight battery kit.
Moving 7lbs to the back is negligible, not to mention, you'd lose a chunk of the weight savings back in running the aught gauge cable back to the front of the car.
Old 08-06-2015, 05:45 PM   #11
OkieSnuffBox
Not the front, but there is a nice rear seat delete kit that drops 29lbs.
Old 08-06-2015, 05:49 PM   #12
DAEMANO
Time Traveller
If he is sensitive enough to detect the difference in weight from the stock battery to his Shorai, then certainly his finely tuned butt dyno could feel another 7.
btw, the cable weighs about 2lbs spread over the lowest point in the car (the floor). I had to research this a while back.
The Following User Says Thank You to DAEMANO For This Useful Post:
SuperTom (01-05-2020)
Old 08-06-2015, 05:52 PM   #13
OkieSnuffBox
Touche!
Old 08-06-2015, 06:00 PM   #14
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Our 2015 BRZ was 54.5% front with a full tank of gas and 175 lbs of driver. Also worth noting, the LF/RR cross was 50.1%. That's extremely hard to achieve, even with adjustable shocks. Those numbers were taken on Intercomp scales on a poured epoxy surface plate.
To the OP, what exactly are you trying to change about the car? You're saying you want to improve the balance of the car, but you didn't post your previous balance numbers.
GSpeed is offline   Reply With Quote
The Following 7 Users Say Thank You to GSpeed For This Useful Post:
BlueWhelan (09-09-2018), DAEMANO (08-06-2015), drewbot (08-06-2015), Icanfaptothis86 (08-06-2015), mokinbird87 (08-07-2015), strat61caster (08-07-2015), Tristor (08-30-2018)
Making the BRZ ever lighter Alabang BRZ Cosmetic Modification (Interior/Exterior/Lighting) 10 04-16-2014 08:57 AM
Are dry carbon fiber front 1/4 panels lighter than OEM? Superhatch Cosmetic Modification (Interior/Exterior/Lighting) 5 05-27-2013 03:47 AM
Better to go wider or lighter? BRAWL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-02-2012 09:48 PM
Increased whp by having lighter wheels mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 07-03-2012 12:46 AM
What return from going with lighter wheels? bazguitarman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 06-01-2012 09:35 AM
