Old 02-12-2018, 04:18 PM   #71
StraightOuttaCanadaEh
Wes
Originally Posted by sato View Post
Thanks for everybody's input.... Great thread.
So, if I understand this correctly, these coilovers can be left at stock ride height, and have similar comfort to OEM dampers? I come from a stock 2014 FR-S. My aim is mainly to have a very comfortable (better than OEM if possible) and might lower car a bit in the future but might only do 1” (not at first). These seem like a good set for my goals (might track later, mainly DD), but very worried about handling on crappy roads around here.
no issues with our crappy roads up here and tons of snow and ice
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
sato (04-13-2018)
Old 04-10-2018, 05:53 PM   #72
MeisterR
MeisterR's Avatar
Drives: BNR32
Bringing this back up now that we have release the revised ZetaCRD+ with the 5/5 springs rate.
Also, we should have some review with new ClubRace coilovers.
Jerrick
MeisterR is offline   Reply With Quote
Old 02-01-2020, 11:28 PM   #73
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Bump.
I'm still rocking them 2.5 years later and still enjoying them. Daily driven, even through winter/snow/salt. No issues to report
Anybody else still running these?
Old 02-02-2020, 12:10 AM   #74
Wes
Originally Posted by NLSP View Post
Bump.
Yeah. Not happy with them though. But I have learned from the experience and now when I get something like a KW V3, I’ll REALLY appreciate the difference. Not happy with the damping but these are entry level after all.
Instagram: @gt86ws
Old 02-02-2020, 03:36 AM   #75
NLSP
NLSP's Avatar
That's unfortunate. I was actually kinda in the same boat for period of time too, but when I revised by damping settings with relation to my tire pressure and tire load index, it made a pretty significant difference in the ride and handling. So I've come to appreciate them now and realized it was me that didn't dial things in optimally.
What are your damping settings now? And what tire model, size, and pressures are you running?
On the topic of KW's, I previously owned a set of RCE (KW) Tarmac 0's with the optional Swift springs in the past. Going from memory, I don't know if I can say they were worth almost twice the price (for street and occasional autocross at least; don't have track experience with either set). I also didn't want to bother sending them back and forth down to the US for a rebuild when it came time for it, and they were a tad too stiff for me as a daily driver. But I'm sure KW V3 are more street-friendly.
Part of the reason why I went for the MeisterR's was the ability to just buy and replace the shocks when/if the time came, and just to experiment with my first-ever set of "cheap/entry-level" coilovers. So far, I am not disappointed after I dialed things in better.
Old 02-02-2020, 07:18 AM   #76
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Bump.
Still rocking mine about the same amount of time.
SInce ive taken ~400lbs off the car I went back and adjusted all the Shock settings to full Negative. The car is less bouncy now.
I also went to slighty change the right height lower. One of my coilovers is/was frozen from turning. Had to remove and keep spraying it with PB blaster. 2 days later it finally freed!
SuperTom is offline   Reply With Quote
The Following User Says Thank You to SuperTom For This Useful Post:
NLSP (02-03-2020)
Old 02-02-2020, 05:22 PM   #77
Wes
Can’t remember. I tried full soft, full hard, middle, a couple clicks above/below middle. Making them stiffer helps with constant radius turn movement but then the ride is too harsh. Too soft and it’s keeps squirming side to side. I tried lowering the tire pressure to 34 psi and it did help a bit but then I’m losing that off the line acceleration. I ran 3 different tires and all 3 have issues, including the winter. The grippier the tire is, the worse the coils perform.
What’s your setup?
Instagram: @gt86ws
Old 02-03-2020, 12:02 AM   #78
NLSP
NLSP's Avatar
What’s your setup?
Currently 19 clicks away from full hard front & rear. Tire pressure set at 31psi front & rear on a tire with a 96XL load index.
The Following User Says Thank You to NLSP For This Useful Post:
SuperTom (02-03-2020)
Old 02-03-2020, 07:48 AM   #79
Wes
Yeah that’s way too low. With that kind of pressure the car feels sluggish.
Instagram: @gt86ws
coilovers, meisterr, suspension
Fortune Auto 500 Coilover Review stoneman155 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-16-2020 05:22 AM
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
MeisterR ZetaCRD+ Coilovers pictures and contents MeisterR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 11-10-2016 09:46 AM
My BC Racing ER Type coilover review Bodyrollin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-23-2013 05:15 AM
T1R B52 Street and Track Coilover Review jau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-08-2013 01:33 PM
