Old 04-13-2016, 09:41 PM   #1
MeisterR
MeisterR's Avatar
Drives: BNR32
Thumbs up MeisterR ZetaCRD+ Coilovers pictures and contents
A few ask us what does the MeisterR ZetaCRD+ looks like for the FR-S / BRZ
So I thought I post a few pictures up.
Several features of the MeisterR ZetaCRD+ Coilovers:
*Barrel (MiniBlock) front springs allow more springs travel as well as ride height adjustment range.
*Rear rubber insulated press steel top mount helps reduce suspension noise associated with the chassis.
All coilovers comes with a pair of our UK patent pending laser cut C-spanner, adjustable drop links, and nuts/bolts mounting hardware.
If anyone got any questions, please feel free to let me know.
Always happy to help answer any concerns.
Jerrick
MeisterR is offline   Reply With Quote
The Following User Says Thank You to MeisterR For This Useful Post:
Clipdat (04-13-2016)
Old 04-13-2016, 11:50 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Those front springs look a bit wider than most, any issues with people who want to get coilovers for aggressive wheel fitment in terms of rubbing?
Something like 17x9 +45 on 245/40
Originally Posted by humfrz
I'm old and lazy
Old 04-14-2016, 10:56 AM   #3
MeisterR
MeisterR's Avatar
Drives: BNR32
They are only wider by a little bit, the max width is 115mm.
They are probably no wider than most OEM springs, and most of that springs will be out of the way anyways.
Clearance was a concern I had during the designing phase.
But for the amount of spring travel we need, a normal straight linear springs could reach coil bind.
That is not good for performance, and it isn't a risk we like to take.
Which is why we custom coil this miniblock springs to our specific springs rate for the FR-S / BRZ application.
Jerrick
Turdinator (04-14-2016)
Old 04-25-2016, 12:41 PM   #4
mpross
mpross's Avatar
Drives: 2015 Scion FRS
Bump
I just installed these last weekend, and I'm very happy with them- stay tuned for a full review
mpross is offline   Reply With Quote
Old 09-17-2016, 06:27 PM   #5
Dangerzone
Drives: 2015 Subaru BRZ, MT
I'm looking into these coils. My friends on the Z34 platform keep raving about them. I use my car for some daily driving but also a fair bit of track/autocross/drifting...so performance is important to me. SO important that I'm often willing to sacrifice daily driving comforts for it.
Have you had any feedback in regards to the coils in more intense HPDE settings?
Dangerzone is offline   Reply With Quote
Old 09-17-2016, 06:45 PM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I wonder how these compare to the St xta coils. Those are at the top of my list now (German, and I've had great experience with them on 2 cars now), but also 40% more expensive. I'll bee looking out for those reviews! I'm not buying til spring time so I've got some time haha
-Josh
Old 09-17-2016, 06:46 PM   #7
Yoshoobaroo
TRACKBREAD
How much front camber do these allow for?
-Josh
Old 10-26-2016, 01:34 PM   #8
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Interested, how many inches will these drop? What are their spring rate? I'm planning to have my fender meet my tires but need stiffer spring so it won't rub
turtlefeeder is offline   Reply With Quote
Old 11-09-2016, 10:43 AM   #9
MeisterR
MeisterR's Avatar
Drives: BNR32
The standard springs rate are designed for fast road usage as well as occasional track use.
They will be perfectly fine as a dual purposes suspension.
For those seeking better all around performance, we do have the MeisterR GT1 coilovers.
These are custom build, and are design to rival the like of Ohlins DFV in performance as a multi-role street / track car.
-Josh
Using the adjustable top mount and the slotted bolt hole in the lower bracket.
You should have no problem getting about -2.5 degree camber on the front.
If you want more, i can see if any of the race people run a bit more, but generally speaking that is more than enough for most application.
Dropping 2" shouldn't be a problem.
Springs rate are front 5kg/mm, rear 4kg/mm
The main concern is that we design the ZetaCRD+ as a performance suspension, so the suspension need to move to perform.
We are looking at possibility making a more track focused suspension setup with stiffer springs rate and damping, but that might not be very comfortable to use on bumpy uneven road surfaces.
However, that is only at the planning stage at this moment.
Jerrick
Old 11-09-2016, 11:03 PM   #10
phongtphan21
Drives: 2013 Fr-s
Anyone have any rubbing issue when they lower it to 2 inch and running wheel fitment? I'm looking to purchasing this or ST suspension.
Sent from my SM-N920T using Tapatalk
phongtphan21 is offline   Reply With Quote
Old 11-09-2016, 11:57 PM   #11
turtlefeeder
Drives: UltraMFrS
I was going to get st xta also but I just got meisterR in and jeez glad I did no rubbing man I'm mad low as the coilover goes and the thing is still damn comfortable lol when I stiffen it up it rides like a track car it's amazing aside from that xta cost 1440 while meister cost 995 aside from that their wrench... works like a champ without a slip
Old 11-09-2016, 11:57 PM   #12
MeisterR
MeisterR's Avatar
Drives: BNR32
To be honest, everyone will be in the same shoe.
The suspension have to move in order to work, if your wheel don't clear the fender and you hit a bump, it is going to rub rather it is MeisterR, ST, or Ohlins.
There are a lot of variable, but there are also a lot of adjustments on the MeisterR.
The dual perch setup so you can adjust springs pre-load independently from ride height really start to show it's benefit the lower you go with the car.
Jerrick
Old 11-10-2016, 12:29 AM   #13
phongtphan21
Drives: 2013 Fr-s
Thanks for your opinion . Gonna probably get these then lol
Old 11-10-2016, 12:30 AM   #14
phongtphan21
Drives: 2013 Fr-s
Jerrick
Thanks jerrick. Lately I couldn't make up my mind , does it come with camber plates and etc or do I use the oem top Mount for the front?
NEW: MeisterR Coilovers for FR-S / BRZ, $995 Delivered MeisterR Brakes, Suspension, Chassis 50 03-26-2018 09:57 PM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
MeisterR coilovers for FR-S / BRZ, what do you use your suspension for? MeisterR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 07-13-2016 07:56 PM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
SOLD: Fortune Auto V4 500 Coilovers *pictures added* remii Brakes, Suspension, Chassis 17 02-27-2014 09:12 PM
