Old 07-11-2013, 01:46 AM   #1
jau
Drives: 2013 frs raven
Post T1R B52 Street and Track Coilover Review
Hi guys and girls, I have installed T1R B52 Coilover with Cusco control arm two days ago. (Big thanks to Ben and Jacky in A&J Racing) Today I am writing a review of this coilover.
Description
T1R offers 44mm piston MONOTUBE tube design for maximum dampening ranges for street and track. T1R also offers camber, 30 way rebound adjustable, ride height/stroke and spring preload adjustable for wide range suspension setting and tuning. Made out of CNC machined chromoly steel (with rust-proof coating) built for heat dissiapation and to reduce unsprung weight. Comes with front pillowball uppermount , adjust wrenches and necessicity hardware for installation. SAE9254 Cold forming springs are equipped with the damper kit.
Why T1R?
-It is track proven coilover at low cost
-It remains the comfort for DD
-It is rebuild able
-wide range of height adjustment
My Set up
-custom spring rate, 10k all around
-custom alignment with corner balanced
-ride height about 1 finger gap all around
-Cusco rear lower control arm
First impression:
Before installing the coilover, I was running with my OEM suspension and I really like the stiffness of the oem shocks, it gives me a sporty ride but also remain the comfort for DD.
After installing the T1R B52 coilover with the cusco lower control arm, the steering response is surprisingly good comparing to the oem suspension. Also the steering becomes very sensitive as i can feel every bump on the road, which i like it very much. Currently my rebound is at the softest setting for running in the coils, it is slightly softer than the oem shocks. I will be switching to a stiffer setting once I run in my new coils.
I will be going on a track event in the beginning of august, I will be keep you guys update of my feedback with the T1R B52 coilover on a track :happy0180:
jau is offline
The Following User Says Thank You to jau For This Useful Post:
Dezoris (09-01-2013)
Old 07-11-2013, 02:44 AM   #2
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Cool Ben is a good guy, just too busy sometimes it seems. I am very suprised at your choice of spring rates, you must really like to feel everything that is friken stiff man!
WHO is actual maker of the T1R anyhow?
OICU812 is offline
Old 07-11-2013, 10:54 PM   #3
jau
The T1R products are made by AJR
jau is offline
Old 07-12-2013, 03:54 AM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
AJRacing do not make their own coilovers/struts. One can see "MAX" in the pic so I am guessing they are Powered by MAX. It is quite possible the valving is to AJR's specifications though.
Captain Snooze is offline
Old 08-27-2013, 11:36 PM   #5
jau
Update:
So I went to the Ridge Motorsport Park with my T1R B52 Coilover. I am using Toyo R888 tires.
In the morning, I was figuring out the lines and braking zone as I am new to this car. I found that the frs has a hard time to pass any car in the passing zone but I loved the way it handles on every corner. My overall impression of the T1R coilover with the alignment set up is very well balanced and neutral on the track. The car does not have too much under or oversteer which i like it very much.
At the end of the day, my best lap time is 2:04 at the ridge, which is 2 seconds faster than my previous car (Acura TSX). I was very impressed how well this car did on the track with my current setup. I will definitely bring my frs back on a track again someday this year.
jau is offline
junior_reyez (02-11-2014)
Old 08-28-2013, 03:23 AM   #6
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
^^^Function and form^^^
Look at that contact patch!
Bravo
Wheel (size/offset) and tire specs?
Anorexic 86 is offline
Old 08-28-2013, 09:46 PM   #7
jau
Bravo
Thanks
I am running 18 x 9.5 +40 with 255 35 18 tires
jau is offline
Old 08-30-2013, 04:49 AM   #8
OICU812
Just a dude
OICU812's Avatar
So to fit those wheels on your car how low are you and what were your final front and back camber and toe settings?
Also any rubbing and did you have to roll the fenders?
OICU812 is offline
Old 08-30-2013, 08:12 AM   #9
Dimman
Kuruma Otaku
Dimman's Avatar
These are just rebranded, marked up price Megan (or some other cheap Taiwanese brand, I can't remember) coilovers.
Because titanium.
Dimman is offline
Old 08-31-2013, 04:57 AM   #10
jau
I am running about 1 finger gap all around, front camber -3 and rear -2.2, toe 0 front and rear.
I did not do any fender work, front doesn't have any issue. But It was rubbing the rear bumper tab in the beginning, but no more rubbing after the track day, lol. the tire shaved off part of the bumper tab and rear bumper still holding strong.
jau is offline
Old 08-31-2013, 05:05 AM   #11
jau
It is possible they manufactured the coilovers in Taiwan. But they are pretty good coilovers in my opinion, and it does the job on the track.
jau is offline
Old 08-31-2013, 10:29 AM   #12
OICU812
Just a dude
OICU812's Avatar
-3 up front wow was that to ensure to clear or avoid rubbing issues up front or just personal preference? How does it handle on street in this setup?
OICU812 is offline
Old 09-01-2013, 05:58 AM   #13
jau
-3 up front wasnt the purpose to avoid rubbing issues, it was personal preference for track set up .
it handles great on a street, it doesnt have much under or over steer like i was on the track, turn in is still very sharp even with alot wider tires. But the car does hydroplane quite often in the rain coz of the r compound tires and the -3 camber
jau is offline
Old 09-01-2013, 01:31 PM   #14
Dimman
Kuruma Otaku
Dimman's Avatar
Your 1st post 'opinion' here is an advertisement.
AJR doesn't make these, they pick whatever is cheap off of a site like Alibaba.com and put their name on them. They posted up here a while ago with some coilovers for this car that were just Impreza ones, because they fit. They had screwed up spring rates and tried to explain that it didn't matter because the struts were inverted and made the rate less, which is an unbelievably stupid and ignorant statement.
They also were trying to get away without being a paying sponsor when they did it.
So if AJR is now buying a real 86 design for Bor Chong or Megan or K-Sport and relabelled them, that's a tiny improvement. If you want a cheap coilover, skip these T1R and save money by buying straight from the Taiwanese manufacturers.
Because titanium.
Dimman is offline
Review: Project Mu HC+ 800 Street/Track Pads spitz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 65 11-30-2019 01:58 PM
Need Coilover Advice for combined Street Comfort + Track Use distracteddev Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-23-2013 04:15 PM
