#211 | |
Drives: 2015 Subaru BRZ Limited DGM
Yes, I followed your notes extensively. Thanks for the inspiration. Getting that blasted piece out was not pleasant. I took half the interior apart trying to free it up. A lot of guides suggesting you should reach up behind the knee-pad trim piece and pop it out from behind, but there is zero chance of my hand fitting up there. Ultimately I shoved a trim removal tool under the cubby on the bottom right corner, while pushing down on the center console trim. That popped one clip loose and I was able to work my way along the bottom edge until the whole thing came out. |
#212 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#213 |
A.K.A. Starlord
Got it last night; installed it this morning. Took 30 minutes. Thought I'd share a video of it doing its thing (second half of the video.)
[ame]https://www.youtube.com/watch?v=knMtY6Cnoig[/ame]
| The Following 3 Users Say Thank You to Stang70Fastback For This Useful Post: |
#214 |
Drives: 2013 FRS
Looking to disable ABS and permanently enable pedal dance. I’m hearing via FB groups that pulling the ABS fuse does both? Can someone clarify if that AND a track box are required? Thanks in advance
#215 |
Drives: Track preped NA FRS
It does but it also fucks up your brake balance hard. Some people here have tried it, they can chime in.
#216 | |
Drives: 2014 Black FR-S
I've daily driven 6+ months during drift season with my ABS fuse pulled. I didn't notice any significant difference in brake balance just felt like driving a normal analog car. Feel free to ask if you want to know anything specific. |
| The Following User Says Thank You to Silky For This Useful Post: | CSG Mike (12-20-2019) |
#217 | |
Have you tried grip driving wiht it off? Does the front feels like its doing all of the job? No rotation while trailing? Im always up for story time
#218 |
Drives: 13 White MT FR-S
I noticed that when I turn on the fan switch the oil temp reading on my Torque app won't read....really strange.
#219 |
Drives: Black FRS
I just installed the trac box but I get no features. The switches light up but none of the features seem to be working. The only thing I did was depin the options connector to sleeve the wire. As far as I can tell the wires were pinned back to the correct spot. Might be a defective unit.
#220 |
Drives: MR2, Sliver BRZ
Torpue app tend to bombard the canbus when in "fast mode" is enabled. And it's technicianly outside of spec. I would mess with the speed to make it like a standard scanner. Or check because some cheaper bluetooth elm327 copies tends to have messy canbus implementation. So they work but not the best to spec.
Always looking to tinker with something..
| The Following User Says Thank You to geraldjust For This Useful Post: | ML (12-22-2019) |
#221 | |
#222 |
Drives: Nevermorange FRS
FINALLY got around to installing it, maybe when FUN is 'un-cancelled' I can play with it.
I was pointed to a custom switch from CH4X4 that fits perfect in the usb slot. ![]() ![]() ![]() ![]() ![]()
PRO86 | WTCC | STL
| The Following 12 Users Say Thank You to rice_classic For This Useful Post: | churchx (05-18-2020), fminicooper (12-09-2020), Jyn (08-07-2020), Lonewolf (05-16-2020), ML (05-16-2020), NoHaveMSG (05-16-2020), Opie (05-20-2020), Pat (05-15-2020), Plumbus (12-01-2020), sato (05-17-2020), soundman98 (05-16-2020), Ultramaroon (12-12-2020) |
#223 |
Drives: Moped
I love the pedal dance button, lol
| The Following 3 Users Say Thank You to Lonewolf For This Useful Post: |
#224 |
Drives: 2014 GT86
Indeed, wonderful mod. @rice_classic: That "custom switch from CH4X4" - any more details? Part number?
| WTB a Beastronix 86 Nanny unit | tonylop33 | Want-To-Buy Requests | 0 | 09-25-2018 07:14 PM |
| FS: Beastronix 86 Nanny - SOLD | Agent_D | Engine, Exhaust, Bolt-Ons | 3 | 05-09-2018 01:57 PM |
| Beastronix Install | HoonThis | Software Tuning | 4 | 06-08-2017 10:02 PM |
| Flex Fuel Kit and Beastronix 86Nanny Trac/VSC | Juanito08 | Engine, Exhaust, Bolt-Ons | 7 | 05-10-2017 02:20 PM |
| Beastronix - 86 Nanny , Speed Academy version | brzaapi | User/Vendor/Sponsor Reviews, Feedback, Comments | 4 | 07-05-2016 11:17 AM |
