Old 12-01-2019, 02:56 PM   #211
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Originally Posted by Stang70Fastback View Post
Nicely done, sir! Can't wait to receive my Trac-Box! The switch panel in my car, which is the original one I made by hand before turning to 3D printing for "mass production" is also made of clear acrylic - but covered with Alcantara instead of painted.
Yes, I followed your notes extensively. Thanks for the inspiration.
Getting that blasted piece out was not pleasant. I took half the interior apart trying to free it up. A lot of guides suggesting you should reach up behind the knee-pad trim piece and pop it out from behind, but there is zero chance of my hand fitting up there. Ultimately I shoved a trim removal tool under the cubby on the bottom right corner, while pushing down on the center console trim. That popped one clip loose and I was able to work my way along the bottom edge until the whole thing came out.
gcranston is offline   Reply With Quote
Old 12-01-2019, 03:07 PM   #212
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Haha the easiest way I found was not to pop the trim piece itself out from behind, but to remove the little trim piece under the kneepad, reach up under the kneepad and pop out the USB/AUX module. That part sticks further back and is easier to reach, and much easier to push out. It pops forward, so then you pull it out the front, and can reach into the resulting hole with your finger and get a good grasp on that trim piece and yank it out
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 12-17-2019, 03:12 PM   #213
Stang70Fastback
A.K.A. Starlord
Got it last night; installed it this morning. Took 30 minutes. Thought I'd share a video of it doing its thing (second half of the video.)
[ame]https://www.youtube.com/watch?v=knMtY6Cnoig[/ame]
Old 12-18-2019, 12:29 PM   #214
Deezee
Drives: 2013 FRS
Looking to disable ABS and permanently enable pedal dance. I’m hearing via FB groups that pulling the ABS fuse does both? Can someone clarify if that AND a track box are required? Thanks in advance
Deezee is offline   Reply With Quote
Old 12-18-2019, 01:21 PM   #215
Icecreamtruk
Drives: Track preped NA FRS
It does but it also fucks up your brake balance hard. Some people here have tried it, they can chime in.
Icecreamtruk is offline   Reply With Quote
Old 12-20-2019, 01:00 PM   #216
Silky
Drives: 2014 Black FR-S
I've daily driven 6+ months during drift season with my ABS fuse pulled. I didn't notice any significant difference in brake balance just felt like driving a normal analog car. Feel free to ask if you want to know anything specific.
Silky is offline   Reply With Quote
Old 12-20-2019, 01:38 PM   #217
Icecreamtruk
Well, I havent done it myself but I have a few track buddys who tried it (for different reasons) and what they all felt is that the bias shifts to the front heavily. Yes brakes work, but trail braking becomes hard because of how the bias shift to the front (bias normally is already way too much forward). Thinking about it now, for drifting, its probably perfect since you want much more front bias for altering your speed with the brakes without stopping the drift (overpowering the engine with the rear brakes).
Have you tried grip driving wiht it off? Does the front feels like its doing all of the job? No rotation while trailing? Im always up for story time
Old 12-20-2019, 04:28 PM   #218
ML
ML's Avatar
Drives: 13 White MT FR-S
I noticed that when I turn on the fan switch the oil temp reading on my Torque app won't read....really strange.
Old 12-21-2019, 05:09 PM   #219
Butterballz
Drives: Black FRS
I just installed the trac box but I get no features. The switches light up but none of the features seem to be working. The only thing I did was depin the options connector to sleeve the wire. As far as I can tell the wires were pinned back to the correct spot. Might be a defective unit.
Butterballz is offline   Reply With Quote
Old 12-22-2019, 03:46 PM   #220
geraldjust
Drives: MR2, Sliver BRZ
Torpue app tend to bombard the canbus when in "fast mode" is enabled. And it's technicianly outside of spec. I would mess with the speed to make it like a standard scanner. Or check because some cheaper bluetooth elm327 copies tends to have messy canbus implementation. So they work but not the best to spec.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 12-23-2019, 02:42 AM   #221
geraldjust
yeah that won't be a issue like i said in the email il send you a replacement! might of been just a issue with the sensor inputs. But i wont be able to tell until i replace it.
Old 05-15-2020, 09:34 PM   #222
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
FINALLY got around to installing it, maybe when FUN is 'un-cancelled' I can play with it.
I was pointed to a custom switch from CH4X4 that fits perfect in the usb slot.
PRO86 | STL | LuckyDog
Old 05-16-2020, 02:38 PM   #223
Lonewolf
Lonewolf's Avatar
Drives: Moped
I love the pedal dance button, lol
Old 05-18-2020, 05:53 AM   #224
churchx
churchx's Avatar
Drives: 2014 GT86
Indeed, wonderful mod. @rice_classic: That "custom switch from CH4X4" - any more details? Part number?
WTB a Beastronix 86 Nanny unit tonylop33 Want-To-Buy Requests 0 09-25-2018 07:14 PM
FS: Beastronix 86 Nanny - SOLD Agent_D Engine, Exhaust, Bolt-Ons 3 05-09-2018 01:57 PM
Beastronix Install HoonThis Software Tuning 4 06-08-2017 10:02 PM
Flex Fuel Kit and Beastronix 86Nanny Trac/VSC Juanito08 Engine, Exhaust, Bolt-Ons 7 05-10-2017 02:20 PM
Beastronix - 86 Nanny , Speed Academy version brzaapi User/Vendor/Sponsor Reviews, Feedback, Comments 4 07-05-2016 11:17 AM
