Old 12-07-2018, 08:40 PM   #1
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Since beastronix is no more, what’s the alternative?
I checked in again with Beastronix. They’re not making and selling product for the foreseeable future.
I’m a DE instructor in the Pacific NW. There are many, many spring, fall and winter track days when my student’s session is finishing as my session has started. I hate sitting in the paddock, reving my engine at 4000+ rpm so it can get warm enough to do the pedal dance!
I have a winter two day event next month.
Is someone else offering a Beastronix comparable product for sale?
I read the threads where I can make my own 3 second defeat device. That’s NOT what I need. I need a fully, pedal dance at any temperature capable device. So not OFT with not only pedal dance enable.
Any leads are appreciated! Even used Beastronix would be fine.
Thank you.
Four_wheel_drifts is offline   Reply With Quote
Old 12-08-2018, 12:59 AM   #2
Icecreamtruk
Drives: Track preped NA FRS
Interested in the results as well, im more or less in the same boat.
Old 12-08-2018, 10:08 PM   #3
RJasonKlein
RJasonKlein's Avatar
Me, too - I’ve been looking for one in the classifieds.
RJasonKlein is offline   Reply With Quote
Old 12-09-2018, 12:34 AM   #4
Totemo_Hayai
Totemo_Hayai's Avatar
Drives: 2013 FRS
How does one tell if the pedal dance has been unsuccessful using OFT? I just got my FRS and tried using the OFT pedal dance feature once right after startup. A few lights came on so it appeared to be successful.
Edit: I just realized that my car is programmed to drop to regular idle speed right after startup. That might be why I don't have to wait for the car to warm up.
Totemo_Hayai is offline   Reply With Quote
Old 12-09-2018, 03:46 PM   #5
dutchman1
Drives: 2017 86 6-Speed
If the requisite for the pedal dance is the coolant temp sensor reading, you could just install an appropriate resistor in place of the sensor to simulate an appropriate reading. Downside of that would be you wouldn't know if your coolant is starting to run hot, you wouldn't know it.
This is done frequently in shops (especially diesel shops) to run diagnostics without having to wait for the engine to warm up. To figure out what resistor you'd need, you can buy (or probably borrow or rent) a resistor substitution box, dial it to the setting that provides the reading you want, and then install a resistor that matches the setting on the box.
I don't know if anyone wants to run on track without having an accurate coolant temp reading, but it's a simple way to do it. It may also affect your radiator fan engagement, if the fan kicks on/off based on coolant temp sensor data, then if you set the reading above the point where the fan kicks on it'll be permanently on, and vice versa.
Just a thought.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 12-10-2018, 05:57 AM   #6
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
The stock gauge is pretty inaccurate, if you're running on a track you should have your own dedicated gauge.
Trueweltall is offline   Reply With Quote
Old 12-10-2018, 05:44 PM   #7
With enough interest, more Beastronix units can be made and sold by CSG.
Old 12-10-2018, 06:20 PM   #8
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
That's bummer Beastronix stop making them. Good thing I bought it before hand.
Hope CSG or other shop can help it out, cuz I'm pretty sure there will be 86/BRZ owner who's interested in this system.
Old 12-10-2018, 06:21 PM   #9
kch
Senior Misanthrope
kch's Avatar
Interest++
Old 12-10-2018, 06:39 PM   #10
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
I'd buy a spare. Especially one of the later models with the switches for pedal dance, abs, and fans
Joesurf79 is offline   Reply With Quote
Old 12-10-2018, 10:58 PM   #11
nico_rsx
Drives: BRZ 2017 Pure Red, MT
You could always put the resistor on a switch somewhere below the dash.
Start the car, flip the switch to simulate correct temp, do pedal dance, and flip the switch back to return to accurate temp reading.
nico_rsx is offline   Reply With Quote
Old 12-11-2018, 01:19 AM   #12
Totemo_Hayai
Drives: 2013 FRS
I'm ready to buy one.
Old 12-11-2018, 01:26 AM   #13
Not quite that simple unfortunately.
Old 12-11-2018, 02:23 PM   #14
B T
I'll be selling my Beastronix module in coming months, setup with one button pedal dance, 2x abs disengage and hold for full fan. Removing the ABS module, so it won't be necessary anymore.
B T is offline   Reply With Quote
WTB a Beastronix 86 Nanny unit tonylop33 Want-To-Buy Requests 0 09-25-2018 07:14 PM
FS: Beastronix 86 Nanny - SOLD Agent_D Engine, Exhaust, Bolt-Ons 3 05-09-2018 01:57 PM
Beastronix Install HoonThis Software Tuning 4 06-08-2017 10:02 PM
Flex Fuel Kit and Beastronix 86Nanny Trac/VSC Juanito08 Engine, Exhaust, Bolt-Ons 7 05-10-2017 02:20 PM
Beastronix - 86 Nanny , Speed Academy version brzaapi User/Vendor/Sponsor Reviews, Feedback, Comments 4 07-05-2016 11:17 AM
