Old 12-16-2019, 05:56 PM   #1
djenousis
Drives: 2015
Another car with idle issues
Background:
Car is a 2015 Subaru BRZ Limited. Currently, my only modification is the Edelbrock Supercharger. Also, I don't know enough to help myself (car n00b).
Areas of Concern:
DTC Codes - P0172 (rich bank 1), P117b (direct injector), P1170 (port injector), C1201 (?), B14A1 (?). Fuel trims are way off (LTFT is -30% at idle) and AFR is all over the place (12-15| doesn't hold near 14.7). Traction light in the middle of the tach is always on.
Main Issue:
The rpm will drop to about 600 then go up to about 1500 then drop to 800 and repeat. Sometimes the rpm drops low and the car turns off. The problems existed with no DTC codes or CEL for a while.
Repair Journal:
12/13/2019 - I took the car to a shop last week. The guy couldn't find any exhaust leaks or vacuum leaks, but was witnessing the idle fluctuation/hunt. Rescheduled for a day he had more time.
Update Journal:
12/15/2019 - Over the weekend, the traction light turned off on it's own. The P0172 rich bank 1 is now gone. Fuel trims are still not normal from what I'm being told, but are better. AFR is no longer bouncing all over the place and is behaving normally. The other injector codes, and the two unknown codes are still there. Car no longer sluggish. Also, is finally quiet like it should be with an OEM exhaust system. I feel like all signs point towards fuel system. Going back to my mechanic tomorrow.
**12/17/2019 - Car was inspected for about 5 hours at the shop. Mechanic did not have enough time to check my car properly last week. He could not find any reason as to why the car is having idle issues. Mechanic confirmed my observations, and states the car is doing better at idle than last Friday. He is completely stumped at the moment. He states that unlike last week, the car seems to be doing fine while being driven. He suggested that I reach out to the manufacturer as he thinks this is a tune issue. I hope it's a simple fix where Edelbrock has a secret revised CARB tune that fixes all of this, but I doubt it.
Data Log:
12/15/2019 https://datazap.me/u/djenousis/12152...17-20-26-27-37
2015 Subaru BRZ
djenousis is offline   Reply With Quote
Old 12-16-2019, 06:29 PM   #2
kev0
Drives: '14
Stuck injector or faulty bypass actuator for the SC. Did the problem pop up suddenly or was it right after you got the SC installed?
kev0 is offline   Reply With Quote
The Following User Says Thank You to kev0 For This Useful Post:
djenousis (12-16-2019)
Old 12-16-2019, 07:03 PM   #3
Originally Posted by djenousis View Post
Background:
Areas of Concern:
Main Issue:
Repair Journal:
Update Journal:
Data Log:
Good plan. If he can't get it settled down, I suggest you take it to a different mechanic/tuner.
Old 12-16-2019, 07:26 PM   #4
djenousis
Drives: 2015
It kind of popped up suddenly... It's interesting that you mention bypass actuators, because it all started around the time my actuator was replaced. The new bypass actuator solved a similar problem, but then gave me my current problem. Thanks for the lead I'm gonna look into what you said about stuck injectors.
2015 Subaru BRZ
Old 12-16-2019, 08:13 PM   #5
kev0
Drives: '14
Oh..it’s unlikely a stuck injector then..what was your problem before? Who installed the actuator? I’m pretty sure the arm of the actuator needs to be oriented in a specific position as it can affect AFR and such.
I mentioned the bypass because it’s a very common part that faile on the Edelbrock.
I had the same issue (with my Sprintex kit). Very similar codes and it turned out to be the bypass actuator. Good luck!
Old 12-17-2019, 08:12 PM   #6
djenousis
Drives: 2015
Thanks. I got the car back right now. The mechanic was stumped, and suggested that it might be a tune issue. Unfortunately, this issue has occurred while using the CARB tune and a DT tune. I guess progress was made, because now I know it's not a vacuum or exhaust leak and that my o2 sensors are fine.
2015 Subaru BRZ
The Following User Says Thank You to djenousis For This Useful Post:
humfrz (12-17-2019)
Old 12-18-2019, 11:09 AM   #7
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Since you're in Torrance, the Edelbrock factory/headquarters in Torrance as well. Maybe you could stop by (email first) and see if an engineer/specialist might chat with you for a bit.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
djenousis (12-18-2019)
Old 01-06-2020, 03:55 AM   #8
kev0
Drives: '14
Any updates?
Old 08-15-2020, 07:39 AM   #9
ALWYZBZ
Drives: 86
OP any updates? Having similar issues
ALWYZBZ is offline   Reply With Quote
Old 08-28-2020, 08:51 PM   #10
crutch92
Somebody HAS to resolve this issue. I have literally opened 50 threads with people having these same codes and no definitive solution.
I've had the same codes ongoing for over a year now. First tuner replaced Edelbrock bypass valve, but issue continued. After that they said they couldn't find anything else.
I've personally replaced my front O2 sensor and done a smoke test for vacuum leak, both also with no luck.
Now a second tuner has been working on the vehicle over a couple weeks. First they replaced the injector control module, but issue continued. Next they tuned the vehicle (had been running Edelbrock CARB tune until now), and issue still continues. Meanwhile just hitting 60k miles so new spark plugs are going in. That's a slim possibility. They're talking about replacing the ECU next.
I am getting so frustrated with this mf car. It was so fun up until all of this crap. Somebody please help all of us get this sorted.
crutch92 is offline   Reply With Quote
Old 08-28-2020, 09:12 PM   #11
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you done anything with the injectors? What injectors are you using? If they're not OEM, switch to the ID1050X for the best spray pattern
Whag is the newest ROM supported / Idle Issues Eazy-V Software Tuning 11 05-28-2018 05:36 AM
Idle issues on Ecutek Bobster Software Tuning 1 08-03-2017 12:36 AM
More damn idle issues... About to say bye to my frs spatcha88 Issues | Warranty | Recalls / TSB 21 05-01-2015 03:16 PM
How to fix the idle issues...according to jalopnik jeebus BRZ First-Gen (2012+) — General Topics 17 10-11-2012 06:06 PM
With all these CEL/idle, chirp issues, should I postpone buying? Iixii Issues | Warranty | Recalls / TSB 31 10-11-2012 05:18 PM
