Whag is the newest ROM supported / Idle Issues
What is the newest ROM supported for a 2013 FRS MT Canadian?
I had A01 and upgraded to B01, but I now have a rough idle that flucuates from 1100-600 and almost dies. It’s constant with no accessories on and even driving very very little throtte you can feel the car slightly bucking. NOTE: I upgraded from A01 because it had another high idle issue while coming to a stop and some intermittent staling on warm start.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73 1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress) 2023 Chevrolet Corvette Z51 Stock |
With all your mods it's unlikely its a base rom issue. Theirs no other factpry update beyond B01C for 2013 car
Its more likely going to be a tune issue or hardware issue. Could be a simple as port injector scaling or latency issue. Try running 100% direct injection at very low rpm and loads instead of a mix of pi\di. |
#3 | |
I was thinking bad O2? What are the symptoms of a failed DI seal?
Di seals fail usually get poping out intake
I made 2 datalogs of startup then idle:
- ZA1JA01C: https://datazap.me/u/eazy-v/2013-frs-fbm-za1ja01c-idle - ZA1JB01C: https://datazap.me/u/eazy-v/2013-frs-fbm-za1jb01c-idle
#6 | |
Manifold absolute pressure looks strange check map sensor, With engine off ( and ignition on ) should be amospheric pressure 14.8 psi. Then with engine running you should be pulling it down to arround 4.7 psi but yours varies a lot. Look for leaking bov or catch cans . The afr is way rich though oil temp is 80 c so its been runnog a while and you di injection time is zero. So its running entirly on port injectors at idle mayve you have pi\di scaling tables wrong. Or make sure your di compiter module is solidly groinded by pall its mounting bolts under bonnett. Or your port injector scaling latenct is way off Last edited by steve99; 05-27-2018 at 05:05 AM. |
#7 | |
Maybe not all changed tables transfered from old rom ?? Not sure
#9 | |
Btw, my A01 logs shows car initially starts up on PI and is fairly rich at 11afr, but then after 25secs it starts to level out and after 46secs it levels 14-15afr and runs off DI. Is that not fairly normal? Or would you do it differently? Also, I noticed B01 goes into DI way later around 65secs and AFR is all over the place and never stabilizes.
#10 |
The initial start ie cranking is always 100%PI.
then soon after start-up it switches to setting in cold/warm/hot pi/di ratio depending on coolant temp. that is pretty well hard coded and not easily changed |
#11 | |
Also just to clarify, my A01 logs shows car initially starts up on PI and is fairly rich at 11afr, but then after 25secs it starts to level out and after 46secs it levels to 14-15afr and runs off DI. Is that not fairly normal?
#12 |
have a look at the port injector scalar it should be something like 550cc/min to match bigger injectors
| Idle issues on Ecutek | Bobster | Software Tuning | 1 | 08-02-2017 11:36 PM |
| More damn idle issues... About to say bye to my frs | spatcha88 | Issues | Warranty | Recalls / TSB | 21 | 05-01-2015 02:16 PM |
| How to fix the idle issues...according to jalopnik | jeebus | BRZ First-Gen (2012+) — General Topics | 17 | 10-11-2012 05:06 PM |
| With all these CEL/idle, chirp issues, should I postpone buying? | Iixii | Issues | Warranty | Recalls / TSB | 31 | 10-11-2012 04:18 PM |
| Anyone worried about chirping/idle/taillight condensation issues? | JDM-dono | AUSTRALIA | 31 | 07-21-2012 01:12 AM |
