Old 08-20-2015, 06:33 AM   #15
Frazer
Drives: Toyota GTS 86 Aero 2014
Originally Posted by churchx View Post
BS on 'they all do it'. Do you have any choice where to service your car to maybe more competent shop?
It is currently being handled by Toyota Australia, need to go to who they say at the moment. Only due to the fact that after the regional tech said it wasn't an issue the case was reported to Toyota and the case was closed. I tried going to another dealer and told them what happened and because of it being reported by the tech they wouldn't do anything about it, even emails and calls to Toyota Australia didn't help. Had to put in a complaint with Fair Trade to get them to speak to Toyota. Got a letter from Fair Trade yesterday with this in it "David Cooper of Toyota Motor Corporation Australia Limited explained that they are still investigating the matter and will contact you directly to arrange a meeting." Would of been nice of Toyota to tell me themselves that they are still looking into the matter before complaints had to be issued. Anyway done is done, at least someone from Toyota got back to me.
Frazer is offline   Reply With Quote
Old 08-20-2015, 10:11 AM   #16
ganz954
ganz954's Avatar
Drives: Subaru BRZ MT WR Blue
Please keep us updated.
I definitely don't want a $450 driveshaft collecting dust in my garage.
I will probably give it another go tomorrow and Ill see what I can find related to the vibration.
ganz954 is offline   Reply With Quote
Old 08-20-2015, 11:32 PM   #17
soundman414
Drives: 2014 Silver BRZ Limited
Have you checked the hub bearing and see if any compliance issues there?
soundman414 is offline   Reply With Quote
Old 08-21-2015, 12:01 AM   #18
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
They lied to fair trade and told them the case was open when in fact it was closed. You should inform fair trade of that fact.
Old 08-21-2015, 06:02 AM   #19
Frazer
Thanks Wayno, done.
Old 08-23-2015, 05:22 PM   #20
aagun
Drives: 86
same issue . at 200km/h
aagun is offline   Reply With Quote
Old 08-28-2015, 08:39 AM   #21
Frazer
Went to Toyota today and got to take the regional tech for a drive myself and got to point out exactly what the issue is. After they had it up on the hoist again, he's come back and said they can not see anything, but at a guess it could be a possible imbalance with the rear axles and will replace them to see if that helps. Hopefully in about 4 weeks the parts will be here and we'll find out if that's the cause. At least they are trying to do something about it now.
Old 08-28-2015, 10:30 AM   #22
puma
crew chief
puma's Avatar
Drives: Race car FR-S
we had the same problem with our alu driveshaft but our subframe is raised in the back and we needed to tilt the front of the subframe a little bit so the driveshaft would clear the fuel tank.
Our vibration was pretty bad, we ran it on a lift and realised there is a frequency at a certain speed that deforms the driveshaft, it basically moves almost 1/2 an inch from side to side. We put the stock driveshaft back in and it never did it again.
I don't know if the same thing happens with a carbon driveshat but my friend didn'twant to spend and other 1200$ just to try.
So i guess anything that changes the way the rear subframe is hooked creates that with an aluminum driveshaft. It just doesn't seem stiff enough.
puma is offline   Reply With Quote
Old 08-28-2015, 12:13 PM   #23
churchx
churchx's Avatar
Drives: 2014 GT86
It would be nice though for makers of shaft request to add it in description for all resellers, to lessen chance of it becoming unpleasant surprise for customers After purchase.
Old 03-28-2016, 01:26 PM   #24
rx3
I also have that issue at around 75 mph with the CF drive shaft and the harder bushings, but only when coasting - it disappears during acceleration. (The aftermarket pinion ring gear has more backlash than the original and the pinion protrudes much deeper into the differential-housing, which may also aggravate this issue).
rx3 is offline   Reply With Quote
Old 11-26-2019, 11:36 AM   #25
pslater
Drives: 2017 Golf R
sorry to bring this back from the dead... frazer, did you end up with a resolution? i have a small vibration at 75km/h and then above 100km/h. i've had it since the car was new (it's got about 9000km on it now), and the first time i brought it in, the tech said it was the stock tires. they did not offer to do anything about it, but i was there for another issue anyway.
i've since put snow tires on the same wheels (stock wheels) and the issue remains, so i know it's not tires. to me, it seems like an axle or a diff. it will happen at speed with zero load on the drivetrain, so it's somewhere in the rotating assembly.
peter
pslater is offline   Reply With Quote
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 05:21 PM
FS: Driveshaft Shop (DSS) aluminum driveshaft (for AT only) $350 dp1 Transmission and Driveline 8 06-18-2014 04:16 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 02:27 PM
