BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
11-13-2019, 07:33 AM | #85 | |
Rust bucket enthusiast
It's not a video game, successfully bolting it onto the car once does not means its function will be accomplished or sustained. |
11-13-2019, 11:32 AM | #86 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
The Following User Says Thank You to weederr33 For This Useful Post: | jcw99 (11-13-2019) |
11-13-2019, 12:02 PM | #87 | |
Drives: Crapcan
The rest I agree with and I check my lines and fittings regularly. One of my fears at the track is having an off and tearing it off wear it is mounted. I will be moving it this year but it is still susceptible to debris. So it will be getting a duct and putting a screen in front of it. |
11-13-2019, 03:59 PM | #88 | |
The Following User Says Thank You to DarkPira7e For This Useful Post: | NoHaveMSG (11-13-2019) |
11-13-2019, 04:18 PM | #89 |
Drives: Crapcan
Ahhh. I rarely see under 20F.
11-14-2019, 10:12 AM | #90 |
Drives: '20 Tundra, '84 SpecE30
Any thoughts on going without the Forester XT oil cooler setup, as in stock with no oil cooler/warmer, in proper winter conditions (<0F)? Especially when one has a short commute, but will happily make 20min+ trips regularly.
The Following User Says Thank You to raisingAnarchy For This Useful Post: | norcalpb (11-14-2019) |
11-14-2019, 11:01 AM | #91 |
Anti stance.
You guys should talk to some oil engineers.
260-270 is nothing on a modern synthetic. |
11-14-2019, 12:24 PM | #92 | ||
Drives: '23 BRZ
My point: you don't do yourself any favors trying to fix problems that don't exist. I would bet that oil coolers on these cars have caused more problems (and more serious problems) than they've solved for cars that track 15-20 minute stints at a time at HPDEs. Casual HPDE track usage just doesn't degrade good synthetic oil terribly quickly. A guy on the Porsche list runs ~8 track days and ~10k miles between changes based on oil analysis, with oil temps in our range of 270-275F. Run good 30wt synth and don't worry about it, I say... |
11-14-2019, 05:48 PM | #93 | |
Weight Weenie
Drives: 15 FR-S
We're likely never going to agree and that's fine. Again, to each his own. To me it seems silly not to try and keep temps optimal, (oil, coolant, tire, brakes, or otherwise) Everyone's opinion on optimal may vary, doesn't really matter. |
11-14-2019, 06:03 PM | #94 |
Does anyone know a repubtable 200F thermostat that has an external oil temp gauge fitting?
I'm thinking about changing from my 185F jackson racing thermostat as Winter approaches. |
11-14-2019, 08:03 PM | #95 | ||
Drives: '23 BRZ
When I began to look into it, I expected to be getting an oil cooler for the car. After tracking the car and monitoring oil temps, learning more about what synthetic oils can tolerate, and what 30wt viscosity is vs. 20wt at these temps, I decided that for my usage adding an oil cooler was not necessary. That is my opinion, but it is a better-informed opinion than my previous one. It seems silly to me to spend $$$ on a piece of equipment that adds multiple failure points if it isn't a benefit. As far as I can tell, 270F isn't an issue, oil pressure isn't an issue, viscosity isn't an issue with 30wt, so what's the point? I think a larger pickup tube is a better idea for engines that see a lot of time at redline rpm (another opinion). |
The Following User Says Thank You to ZDan For This Useful Post: | Tokay444 (11-16-2019) |
11-14-2019, 08:45 PM | #96 |
Drives: Crapcan
Similar Threads | ||||
Engine Oil Temps after Oil Cooler | ryoma | Engine, Exhaust, Transmission | 31 | 03-23-2016 09:21 PM |
Air temps and impact on engine load | brn12345 | Software Tuning | 0 | 04-30-2014 02:50 PM |
Boxer engine and temps | SlinkyAvalanche | Engine, Exhaust, Transmission | 9 | 03-27-2014 03:00 PM |
Reducing engine compartment temps | mike_ekim1024 | Engine, Exhaust, Transmission | 1 | 12-11-2013 02:57 AM |
Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 03:17 PM |
