Old 12-11-2013, 02:08 AM   #1
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Reducing engine compartment temps
I'm curious if there will be more aftermarket producs to help reduce engine compartment temps. There seem to be a few ways with vents.. Just before the front windshield, side vents (but need to cut holes), custom hoods, intake coolers, intake and header wraps...
I'm no fluid dynamics expert, but I'd imagine it gets pretty turbulent under there, with heat having nowhere to escape. It'd be interesting to see smoke and a wind tunnel flow through under the hood. Or a simulation even.
Ultimately.. I'm curious how low you can get intake temps. Speaking of, is there a difference between metal and plastic intake tubes? Related:
http://www.ft86club.com/forums/showp...1&postcount=21
http://www.ft86club.com/forums/showthread.php?p=1336228
http://www.ebay.com/itm/VIS-12-13-FR...p2054897.l4275
http://www.ft86club.com/forums/showthread.php?t=21007
http://www.importtuner.com/tech/impp_0808_cooling_mods/
http://www.designengineering.com/cat...er-sprayer-kit
http://www.flex-innovations.com/intake_wrap.htm
mike_ekim1024 is offline   Reply With Quote
Old 12-11-2013, 02:57 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
The stock system gets intake temps down to within a degree or 2 of ambient. I know someone who's monitored the Injen on a trackday and seen the IAT readings hovering not too far off as well. It seems that the air flow through the bay is enough, as well as the cooling effects of air through the intake system itself. The issue is mainly when you're not moving and radiated heat from the radiator creating heat soak.
.: Stealth 86 :.
Kodename 47 DJ:
Questions for Reducing Body Roll Ingeberger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-19-2014 07:34 AM
Reducing Rasp Admired Engine, Exhaust, Transmission 28 01-25-2014 01:40 PM
Reducing bumpy ride with sportline springs Lemar58 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-11-2013 09:24 AM
Reducing Insurance for hardly used car? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 6 08-31-2013 06:35 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
