Old 10-15-2019, 10:49 PM   #1
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
17+ engine oil temps
Hi Guys... What kind of oil Temps are you guys averaging?
Mine seem to have crept up after I boosted but I never paid much attention to them before.
First Pic was highway driving tonight.
2nd Pic got close to 270 in the hills naer Santa Barbara last weekend.
Sent from my SM-N960U using Tapatalk
tfp is offline   Reply With Quote
Old 10-15-2019, 10:58 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
What does the model year of the car have to do with oil temps?
Old 10-15-2019, 11:06 PM   #3
tfp
tfp's Avatar
Perhaps none. Perhaps some. Minor engine tweaks on 17+. Just trying to gather numbers.
Old 10-15-2019, 11:34 PM   #4
alphasaur
friendly
Drives: 17' 86
The car needs an oil cooler stock
Boost exacerbates the issue. Stock I hit near 220 during autocross and I space out my runs to cool down.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 10-16-2019, 12:38 AM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I have the forester XT regulator routed through the throttle body and I never see my temps anywhere near that. In fact, they almost always stay below 225 unless I'm driving really hard.
MS, CSCS, TSAC-F, CPT
Old 10-16-2019, 01:16 AM   #6
norcalpb
norcalpb's Avatar
270f is way too hot. I assume you are on 0w20?
Time for an oil cooler and I’d let it cool down if you ever go above 250f which may be hard to do with said cooler.
I personally think 225f is where you want to be in terms of max temp.
Old 10-16-2019, 01:29 AM   #7
tfp
tfp's Avatar
Yes, 0-20w.
Old 10-16-2019, 01:42 AM   #8
86MLR
86MLR's Avatar
You need to correlate oil temp, oil pressure, what type of oil and what grade of oil.
Synth oils don't mind temp to a point, but you need to watch the oil pressure.
Plus using E85.
Plus length between oil changes.
I run at about 120° Celsius when I'm up it, but only for short periods.
Turbocharged with Forester heat exchanger.
Currently running Penrite synthetic 5w 30.
I really need to get an oil pressure gauge.
I also need to find the best place to mount it to get an accurate reading.
It's on my to do list.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 10-16-2019, 01:58 AM   #9
norcalpb
norcalpb's Avatar
Originally Posted by tfp View Post
Yes, 0-20w.
I’m not an expert on this but fwiw with 0w20 oil pressure drops quickly at these high temperatures which can reduce engine internal lubrication.
Luckily winter is around the corner so you’ll have a lot of time to pick out an oil cooler before you need it.
Old 10-16-2019, 02:00 AM   #10
Ultramaroon
not playing cards
It has nothing to do with the year, some to do with being blown, and mostly to do with engine speed.
An oil pressure gauge along side a temp gauge will motivate any sensible person with a stock engine to look into an oil cooler. Don't cheap out. Get a good one.
Old 10-16-2019, 11:51 AM   #11
tfp
tfp's Avatar
Oil Temp seemed great this morning otw to work. Was low 50's outside.
Might as well plan on getting the Jackson oil cooler since they got all my money so far with my boost build .
Old 10-16-2019, 08:10 PM   #12
scottbrz
Drives: 2017 BRZ Limited PP
It looks like your coolant temperature is getting kind of high. Isn't the first tick mark the 190 line?
If my car is moving at all, it never goes above the 190 range no matter what I do.
My car is factory stock and I recently got my oil temps up to perhaps the 245-250 range (visual estimation) on some mountain roads around the Tail of the Dragon area over here. I'm planning to do the OEM style oil cooler at some point.
scottbrz is offline   Reply With Quote
Old 10-16-2019, 09:11 PM   #13
Grady
Grady's Avatar
Hav a 2017. When I boosted put a forested oil cooled on and temps stayed a about the same with normal driving. 160 or so Texas summer driving. Switched to standard oil cooler and temps went to 120ish. Did a track day last weekend. Temps in the 80’s. After 20 min session temps were in the 140 range. I am running 5w30. I would switch to 5w30. If you are heading to the track get a cooler.
Old 10-16-2019, 09:33 PM   #14
tfp
tfp's Avatar
Crap... Based on everyone's input my system has been running hot for a while on both coolant and oil.
I didn't start paying attention until I boosted so for all I know it could have been high when NA.
Engine Oil Temps after Oil Cooler ryoma Engine, Exhaust, Transmission 31 03-23-2016 09:21 PM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 03:00 PM
Reducing engine compartment temps mike_ekim1024 Engine, Exhaust, Transmission 1 12-11-2013 02:57 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
