Old 11-05-2019, 09:26 AM   #71
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I have read those threads as well. When I reseal the timing cover I am going to be installing the bluemoon baffle and killer B pickup as well. I have some corners at local tracks that are spiking lateral G's pretty hard and it will drop out the oil pressure to the low teens at 4-5k rpm under load. Right now that has me the most concerned. If it looks good I may up redline to 8k to see what happens. I have a spare motor anyway so might as well experiment.
Old 11-05-2019, 02:17 PM   #72
ermax
ermax's Avatar
Originally Posted by TunaNoCrust View Post
Good to know, thanks for sharing.
Yeah there are a lot of test out there, and what a great article this was.
https://www.ft86club.com/forums/showthread.php?t=134863
Dang I missed that thread. Thanks for sharing!
Old 11-06-2019, 09:44 PM   #73
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
my BRZ is a 2020 and the oil runs 240 most all the time. if I go for a spirited drive, it hits 270 quite quickly.
My oil cooler is on the way. There's no wonder there is a history of rod bearing problems
Rabrooks is offline   Reply With Quote
The Following User Says Thank You to Rabrooks For This Useful Post:
tfp (11-07-2019)
Old 11-07-2019, 08:30 AM   #74
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Your car is stock? Seems very odd that your car runs that high on the drives you describe. Sounds more like your definition of "spirited" is half race mode. At constant 3500-3800 RPM on highways I only ever reach a steady 230. When doing my "spirited" drives whipping higher RPMs around corners and such for a few minutes, I typically don't even reach 230. Though I guess I can't comment on longer periods of time in driving like that, as not only do I not have enough road for that, but I prefer not to reach higher oil temps anyway. But I would have thought it takes a lot more to whip up the BRZ to the 270 range.
Dzmitry is offline   Reply With Quote
Old 11-07-2019, 08:05 PM   #75
Rabrooks
Rabrooks's Avatar
The car was stock until last weekend. I added a header, overpipe and front pipe. Only 1000 miles so new tight engine tolerances may be driving the temps up until the engine is properly broken in.
Yeah I know. I would not have expected the temps to get that high that quickly. My spirited drives are pretty spirited, high rpm downshifts and back on the throttle thru corners. Yes its a bit like tracking the car on a track day.
Fortunately, today's oils can stand 270 without much problem. Just means I need to change the oil more often. Of which, I had it changed today at Subaru dealer. I wanted to make sure it got the oil they recommend. So If I have a problem, its on them.
Dzmitry (11-08-2019)
Old 11-08-2019, 02:40 PM   #76
Dzmitry
Dzmitry's Avatar
I see. That may certainly explain to some rise of temperatures, the rest being your driving. But yeah, in the end you should be alright with the higher temps, just need good frequent oil changes. Not that I want to jump into a deeper topic, but don't forget that if you're still sitting on 0W-20, the oil pressure is not optimal at such high temperatures. So if you're often seeing these temps, consider going slightly higher oil weight. But I guess your oil cooler should solve that issue if you're getting it soon enough.
Old 11-08-2019, 04:04 PM   #77
ka-t_240
They probably won't like a header/op/fp and likely tune when it comes to an engine failure "being on them"
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
TunaNoCrust (11-08-2019)
Old 11-08-2019, 04:34 PM   #78
new2subaru
Weight Weenie
Drives: 15 FR-S
Not to beat a dead horse, but, let me get this straight...
270F is okay = I just change the oil more often
270F is okay but 290F is not okay (20F difference)
Got it
The Following User Says Thank You to new2subaru For This Useful Post:
NoHaveMSG (11-08-2019)
Old 11-08-2019, 06:37 PM   #79
ZDan
ZDan's Avatar
Drives: '23 BRZ
If you wanna know what I think about 290F go back to post #49. In any case it's irrelevant for most of us because a stock car on the hottest track days doesn't see oil temps go over about 272F.
Running just over 270F, I run 0w30 or 5w30 synth during track season. About to switch back to 0w20.
new2subaru (11-08-2019)
Old 11-08-2019, 09:26 PM   #80
soundman98
ProCrastinationConsultant
soundman98's Avatar
Got it
exactly.
in florida 70 degrees is frozen, 90 degrees is too hot!
new2subaru (11-09-2019)
Old 11-11-2019, 08:09 AM   #81
Dzmitry
Dzmitry's Avatar
Got it
290F is simply LESS okay than 270F. The proper solution to this would be even more frequent oil changes if you are seeing this temperature at times vs. seeing 270F.
Old 11-11-2019, 08:31 AM   #82
new2subaru
Weight Weenie
Drives: 15 FR-S
Or, an oil cooler
Old 11-11-2019, 10:18 AM   #83
Dzmitry
Dzmitry's Avatar
Or, an oil cooler
That would be an aftermarket solution which, depending on the product, creates other risks that could lead to harming your engine. A quality product with proper installation is certainly important when going this route, as well as constant maintenance of the cooler for any problems such as leaks, and gauges to insure you are getting the temperatures and pressures you desire (as oil may run too cool for daily applications). Not steering anyone away from oil coolers, but many people have been led to believe the simple solution for oil rising to high temperatures is an oil cooler. Unfortunately, it's more complicated than that, and though it is a viable solution, plenty of research should be done before jumping on the thought that "I'll just get an oil cooler and everything will be all good!"
The Following 2 Users Say Thank You to Dzmitry For This Useful Post:
DarkPira7e (11-13-2019), ZDan (11-13-2019)
Old 11-13-2019, 07:27 AM   #84
new2subaru
Weight Weenie
Drives: 15 FR-S
Yup. There is tons of info on this forum however not all agree. TBH I think a lot of newer people are led to believe taking your car to the track is not a big deal. Maybe for the first while that is true.
These car are street cars that can be tracked. They're not built for racing. You start tracking a car and stressing components and problems will arise.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
cliff (11-13-2019), Dzmitry (11-13-2019)
Engine Oil Temps after Oil Cooler ryoma Engine, Exhaust, Transmission 31 03-23-2016 09:21 PM
Air temps and impact on engine load brn12345 Software Tuning 0 04-30-2014 02:50 PM
Boxer engine and temps SlinkyAvalanche Engine, Exhaust, Transmission 9 03-27-2014 03:00 PM
Reducing engine compartment temps mike_ekim1024 Engine, Exhaust, Transmission 1 12-11-2013 02:57 AM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
