Drives: FRS RS 2.0 #757
Header ceramic coat or heat shield wrap?
I'm buying a uel this weekend. I've dome some research, and it seems like it's a good idea to ceramic coat headers. I found a local place that does it, using cerakote. I've also seen the heat wrap thing that you place on your oil plan. Not sure if I need this or not.
My car will be street driven, no track usage. Are either of these necessary? I know lowering the amount of heat will be a good thing. However, in your opinion, is ceramic coating necessary for a street driven car? Would an after market header produce more heat than the stock header? |
#2 |
Drives: 2017 BRZ (Sold), 2023 GR86
I'd highly recommend coating it. Without all the heat shields that the stock header has, things get quite hot in there even in DD conditions.
I've never used wrap so I can't comment on it's effectiveness by comparison. |
| The Following User Says Thank You to mistople For This Useful Post: | Phuviano (10-30-2019) |
#3 |
Drives: 2013 Raven FR-S
In my opinion there are only pros when it comes to ceramic coating headers, it's just whether or not you want to spend the money. Just got to make sure that the place doing it is doing both the outside and the inside of the header.
As you mentioned, it helps keep heat down in the engine bay, but it also has other benefits. It helps protect the header material from dirt/oil/road salt that may it may come into contact with, and it also aids in the performance of the header. Keeping the exhaust gases hot within the exhaust allows the gas to maintain its speed and flow out of the exhaust. If you have the money, I say go for it. |
| The Following User Says Thank You to JCW 86 For This Useful Post: | Phuviano (10-30-2019) |
#4 |
Dismember
Drives: 2013 Red Scion FR-S
It's unnecessary for a street car. Not even necessary for a track car. At some point, when you're really good at driving, it may become necessary. It's just another way to remove heat.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Phuviano (10-30-2019) |
#5 |
Both. Keep the heat in the exhaust were it belongs and out of the engine bay.
| The Following 2 Users Say Thank You to Grady For This Useful Post: | Teseo (07-06-2024) |
#6 |
Purist
Drives: 2013 FRS - Hot Lava
Ceramic Coating
![]() Ceramic Coating ![]() Know the difference.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#7 |
Wrapping is much more efficient than ceramic coating.
In saying that we don't use salt on the road here, so IRT wrap and contamination for your area, I have no idea. Lagging a header on a street car is a really good idea, the added temps from an unlagged header when you are sitting in traffic is huge. Ceramic coating should be inside and outside. Ceramic coating only the outside will not have a large effect, it will negate some corrosion though, but minimal heat. Painting a header with high temp paint (protects against corrosion) and then wrapping (heat retention) gives the best of both worlds. I have had headers ceramic coated and wrapped before, but, I feel the additional cost of the ceramic coating was unjustified when some high temp paint could have been used, with simular results in heat control. I am currently waiting for a time to put my car up on a lift or over a pit to wrap the AVO turbo manifold and dump, they are coated, and the coating seems to be holding up well, but, not really what I would call efficient at heat control in comparison to a wrapped header. The best place to get ceramic coating done is at an industrial flame coating place. Ceramic coating to control temps isn't just a case of spraying on a coat, sadly this is what all alot of places do, and they charge alot of coin for it. Quality of base materials, thickness of coating and longevity are also things to concider.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following User Says Thank You to 86MLR For This Useful Post: | Phuviano (10-31-2019) |
#8 |
The Fail Boat
Drives: CWP S.B.
Warping is simple, effective & easy + you can do it yourself.
As long as your car isn't leaking lots oil... |
| The Following User Says Thank You to chaoskaze For This Useful Post: | Teseo (07-06-2024) |
#9 | |
Drives: Blue ZC6
As others have mentioned, coat first then wrap. The ceramic coating will provide some thermal protection, but wrapping it is a much better thermal barrier. The ceramic coating, or high temp paint, works best as a corrosion barrier. Keeping it from flaking off over time is going to come down to how well you prep the surface prior to application of whatever coating you go with.
You can easily notice the improvement after wrapping that manifold. After I wrapped mine I put my hand close to the wrapped header and then the joint between the manifold and the turbo and noticed a substantial difference in temperature while the engine was running. If your able to, I'd recommend installing a turbo blanket as well. |
#10 | |
Meh, shopping adventures abound. I'm actually not looking forward to wrapping the headers, wrapping installed headers is a PITA. Everytime I wrap a header on a car I say I will never do it again.....until I do.....then I say I'll never do it on the car again, again.....
#11 |
Drives: 2017 BRZ PP , 2005 Saab 97X
I never liked wrapping even though its cheap and makes bad welds look good.
the idea of wet wrap sitting agianst the metal makes me shutter.. i just keep it clear or if i can hit it with the engine enamel paint before paying for ceramic coating |
#13 |
Drives: 2013 FRS
The wrap will dry out quickly sitting against a hot manifold. Odd for the wrap to be soaking wet if the pipe isn't hot...
#14 |
| Anyone know the typical temps on the OEM header heat shield? | canyons | Engine, Exhaust, Transmission | 5 | 08-07-2019 04:24 PM |
| Ceramic Coat Or Heat Wrap For Turbo Setup | nearvincent | Forced Induction | 10 | 06-20-2017 11:25 PM |
| OFT + Gruppe S UEL header with heat shield, Berk front pipe | Smough | Engine, Exhaust, Bolt-Ons | 8 | 05-11-2017 02:17 PM |
| Mounting aftermarket header. Do i have to wrap/ ceramic coat for heat protection? | giorgi0424 | Engine, Exhaust, Transmission | 9 | 03-03-2017 08:58 PM |
| Stock heat shield vs Ceramic coated? | deuncos | Engine, Exhaust, Transmission | 29 | 02-29-2016 06:12 PM |
