Old 06-19-2017, 03:36 AM   #1
nearvincent
Drives: GT86
Ceramic Coat Or Heat Wrap For Turbo Setup
For those who are turbo'd, what is better ceramic coat or heat wrap for daily use and some track days?
nearvincent is offline   Reply With Quote
Old 06-19-2017, 09:52 AM   #2
Amputechture
Drives: 2014 BRZ
Ceramic for sure. It costs more obviously but worth it. My car is only street driven so I opted for a turbo blanket and wrapping the downpipe, manifold, and over-pipe. Some folk say that wrapped exhaust has a tendency to retain moisture, rust, and eventually crack your piping but I've been wrapped my exhaust on several cars and never had an issue.
Amputechture is offline   Reply With Quote
Old 06-19-2017, 09:57 AM   #3
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
In for details... I saw something interesting at the track. Someone had coated their intake piping (piping after intercooler, sc setup) in wrinkle black. Something similar to what our plastic intake manifold looks/feels like. I wonder what the benefits would be.
pgranberg11 is offline   Reply With Quote
Old 06-19-2017, 12:39 PM   #4
Amputechture
Drives: 2014 BRZ
To my understanding, wrinkle finished aluminum has no thermal protecting properties...it is simply cosmetic. Although it may help the piping age better.
The Following User Says Thank You to Amputechture For This Useful Post:
pgranberg11 (06-20-2017)
Old 06-19-2017, 01:22 PM   #5
ST185RC
Drives: White Out FR-S
Ceramic coat over heat wrap any day of the week. For one, it makes your engine bay look really ratty after a month.
Second, if you live where it's even slightly humid it'll trap moisture over time.
Third, heat makes metal expand. So some guys wrap this thing so tight that it essentially puts extra strain on the piping. This added on top of trapping moisture isn't the most friendly to the pipe underneath.
ST185RC is offline   Reply With Quote
Old 06-19-2017, 08:14 PM   #6
FirestormFRS
Unless you leave your car sitting for months moisture build up is a non issue with wrap. Start the car and boom moisture is gone after 2 minutes. The big issue with wrapping is oil saturating the wrap then burning. They do however do wonders for under hood temps.
FirestormFRS is offline   Reply With Quote
Old 06-20-2017, 03:36 AM   #7
504
504's Avatar
Drives: 2014 86 GTS
Why not both
504 is offline   Reply With Quote
Old 06-20-2017, 05:49 PM   #8
sid94
Drives: 2013 frs
Well you see down here in Florida it's rainy one minute and not the next. Also it's humid 24/7 so it depends where you're at cause constant back and forth is not good either
sid94 is offline   Reply With Quote
Old 06-20-2017, 06:25 PM   #9
ST185RC
I'm sure OP is planning to turn the car on and off more than one time. So bearing that in mind, I'm pretty sure that the car will be off overnight at least 8 hours when moister collects the most when it's coolest. when you factor in the fact that 8 hours a day is equal to more than 120 days out of the year at the very minimum with a pipe in moisture. So 2 minutes required to burn off isn't exactly comforting when the cycle has to happen each time.
Personally, I would never heat wrap a pipe on a road going daily driver. If you wanna consider that pipe a disposable part, go for it. Did I mention that it looks ratty and shitty after a few days?
PS, I used to own a GT-Four RC with a berk DP along with another guy who also owned one and we bought the DP together, he went heat wrap. I went with the ceramic coating direct from berk. After we both ran the car for a few years, my pipe sill looked decently clean, where as his required to be rewrapped. When he did remove the wrap to be rewrapped, it had all the dirt from moisture seeping through the wrap and onto the pipe and the outlines of where the wrap was. All the crud was burned into the pipe itself and looked nasty. I can't imagine that's healthy for the pipe.
Old 06-20-2017, 10:43 PM   #10
ZZT86
ZZT86's Avatar
Drives: BR86
You can't wrap the inside of a pipe or header
ZZT86 is offline   Reply With Quote
Old 06-20-2017, 11:25 PM   #11
choi0706
Drives: t
heat shield products https://www.heatshieldproducts.com/a...atshield-armor
or
https://www.turbosource.com/TurboSou...lds-s/1938.htm
choi0706 is offline   Reply With Quote
The Following User Says Thank You to choi0706 For This Useful Post:
arthur93 (06-20-2017)
Mounting aftermarket header. Do i have to wrap/ ceramic coat for heat protection? giorgi0424 Engine, Exhaust, Transmission 9 03-03-2017 08:58 PM
Ceramic Coating - keeps heat in or out? Fizz Engine, Exhaust, Transmission 11 05-27-2016 01:55 PM
Stock heat shield vs Ceramic coated? deuncos Engine, Exhaust, Transmission 29 02-29-2016 06:12 PM
Request: Oil Pan heat wrap? 1Cor10:23 DIY (Do-It-Yourself) Guides 14 11-26-2014 04:01 PM
What's it cost to power coat or ceramic coat exhaust tips black? tracerit Engine, Exhaust, Transmission 4 03-30-2013 11:28 PM
