Old 10-20-2019, 12:45 PM   #1
Joyriding_86
Drives: 2015 Firestorm Frs
Help - rpm drops after flashing E85 tune.
So like I said, after flashing e85 with oft the car is running kind of bad. Before hand I had flash the stg1 oft tune no problems, the car pulled hard and smooth. I ran the tank low filled with e85. Gave it about 20+ miles just low rav driving. And from the first drive from flash I noticed the rpm drops almost to stall when I release the clutch. And the rpm bounce around when driving and letting off the clutch without giving it gas. Ltft and stft is both between 7-/+. I did change and set the launch control to a lower rpm I don't think that would mess with the tune. Should I reflash it with stock e85 tune? Would it have to relearn e85 if I do? Should I give more time to adjust?
Thank for any advice!
Tldr; after filling up and flashing e85 car runs rough and drops rpm
Joyriding_86 is offline   Reply With Quote
Old 10-20-2019, 01:00 PM   #2
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
Try reflashing it again sometimes the file doesnt flash correctly also make sure you uploaded the correct file specific to your cars i.d
BlOody_BoOger is offline   Reply With Quote
Old 10-20-2019, 03:15 PM   #3
Joyriding_86
Will the car have to relearn E85? I have ran stg1 no problem before. I'll try to rewrite later today. Would the LC change have anything to do with it?
Old 10-20-2019, 03:50 PM   #4
BlOody_BoOger
You would need to let the ECU learn again, if it didn't upload properly, just drive it for like 10miles chill and see what happens
Old 10-20-2019, 03:54 PM   #5
BlOody_BoOger
Also when plugging in and out your oft make sure the car is off. Plug in your oft and then turn the car on. If you're connecting and disconnecting it with the car running you can cause the ECU to go into limp mode.
Old 10-20-2019, 04:00 PM   #6
Joyriding_86
Thanks, and I do unplug and plug sometime while running. I will retune and run lightly for 20 miles and see what happens. Cause if anything I'll just go back to stage 1, I felt more tq and hp in that tune.
Thanks
Old 10-20-2019, 04:13 PM   #7
BlOody_BoOger
Thanks
Lol if you do it correctly e85 should feel like you just gave your car an adrenaline shot. It's much more aggressive and and the the throttle response is a lot more sensitive
Old 10-20-2019, 04:33 PM   #8
Joyriding_86
Would you think me changing the LC rev limiter could of played apart?
Old 10-20-2019, 05:08 PM   #9
steve99
Drives: FT86
Its possible if you set the LC or FFS rev limt delta to strange values you will get issues.
When you flash a car the flash is either sucessfull or fails if you got a partial flash the car wont even start as checksum routine in ecu will fail.
Flash a un altered e85 tune and see how it goes
Ie no lc or ffs mods and no mods for pops
Just standard oft e85 tune
Are you running stock intake ??
Old 10-20-2019, 05:19 PM   #10
Joyriding_86
Omg Steve! Yes everything is stock minus a borla axle back.
I just re flashed with the e85 stock tune and the car is still running funky. Just sitting here. The rpm is all over the place I just flashed about 10mins ago and was doing the adjusting by driving under 4k rpm
@steve99
Old 10-28-2019, 07:35 PM   #11
aceangel
aceangel's Avatar
Drives: 13 BRZ WRB LTD 6AT
I had a similar problem with stalling before but figured it out. My air filter (a K&N drop-in) was old and was clogging up the intake. I changed the filter and it started to idle fine without stalling. Might want to check the air filter.
aceangel is offline   Reply With Quote
The Following User Says Thank You to aceangel For This Useful Post:
Joyriding_86 (11-06-2019)
Old 10-28-2019, 10:15 PM   #12
Lantanafrs2
Drives: 2013 frs red
My car idled like crap for 30 miles or so after flashing e85 tune. Cleared up though
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 11-06-2019, 02:30 PM   #13
Joyriding_86
I didn't even think of that. I'm going to Change it out tomorrow. The car drives alot better now. It's just cold starts are taking 2-3 time before running. Thanks mate.
Old 11-06-2019, 02:32 PM   #14
Joyriding_86
Yeah I think I jumped the gun on everything even though I have it 70+ miles to learn.
Lit symbols in dashboard after flashing Xero Limit tune kev0 Software Tuning 19 07-07-2019 06:05 AM
After flashing A new tune to your car John27 Software Tuning 5 06-08-2018 02:03 PM
Oil drops on pulleys? Where'd they come from? Packofcrows Issues | Warranty | Recalls / TSB 14 02-08-2016 11:28 AM
rpm drops to about 500 JM'sFR-S562 Issues | Warranty | Recalls / TSB 8 01-23-2014 07:07 PM
86 Insider Drops Mishimoto 86_Insider Announcements, Contests, Giveaways 3 09-23-2013 08:40 PM
