Old 10-17-2019, 08:19 AM   #57
DBW
Motorsports
Drives: 19BRZ PP, 16 M4
Well, there's only two UELs sold on the CSG website. This is one of the two.
Is the Ace necessary? Only if you want maximum efficiency.
Lets clarify. It's actually 35whp more, with 3 psi less boost observed. C30hbp/Ace vs C38hbp/UEL.
Or, the C30 on std pulley makes ~10whp more, with 5.5psi less boost observed on C30 sbp/Ace vs C38 hbp/UEL.
That's pretty damn substantial!
In the end, the conclusion is always the same: The Ace delivers the best results at the highest price. Some folks don't want to spend that price, or prefer the UEL sound. To each their own!
If you are seeing such a dramatic boost drop there is more going on then just a header swap. To see that much drop likely there are large changes in cam timing and overlap in the tune itself. An apples to apple test would be same ecu calibration, same fuel, same day. Or post the data of the two headers dyno runs.
Douglas W.
DBW is offline   Reply With Quote
Old 10-17-2019, 08:45 AM   #58
86TOYO2k17
Drives: 2017 toyota 86
he is using a smaller blower in scenario 1, and smaller blower with smaller pulley in scenario 2 to generate less boost... The point is pretty simple and clear, typically more boost equals more power, but with a change in header design they where able to generate more power with the ACE at a lower boost amount then another header made with more boost. That is pretty clear substantial data. Sure it would be nice to have 100% same setup before and after with ACE vs another header being the only variable, but based on this data the result would most likely end up being an even greater difference then was illustrated in this comparison as you would just be giving the ACE side even more power.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
CSG Mike (10-17-2019), mrg666 (10-17-2019)
Old 10-17-2019, 01:33 PM   #59
gtengr
Drives: 2017 BRZ
Originally Posted by mrg666 View Post
If the two engines with two different boost levels are giving the same torque, the one with higher boost is wasting part of that energy. And the wasted energy is wear/strain on the engine components. So out of two engines with equal boost, the engine with higher torque will not necessarily have higher wear/strain. Actually, a better flowing more efficient exhaust reduces the pressure level in the cylinder while increasing the torque which decreases the failure risk. It is more complicated than just looking at the area under the curve.
The greatest strain (ignoring RPM) is the power stroke. Mass flow rate is the key. Better headers sap less power to expel exhaust, which results in better cylinder filling, less psi, more mass flow rate, and consequently more torque.
Comparing psi changes is more useful for comparing changes to the pulley. When used that way, the psi change is a more true indicator of mass flow rate change.
gtengr is offline   Reply With Quote
The Following 2 Users Say Thank You to gtengr For This Useful Post:
Old 10-17-2019, 02:08 PM   #60
CSG Mike
CSG Mike's Avatar
Except a tune optimized for the Ace would not work well for the UEL, and the tune optimized for the UEL would not work for the Ace.
But you should already know that.
Also, The Ace is on a smaller unit than the UEL, C30 vs C38.
Old 10-17-2019, 02:15 PM   #61
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Any EGT info on these dyno runs?
Old 10-17-2019, 04:21 PM   #62
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Overlaid (combined) graphs w/ identifiers for comparison.
Conclusions: Smaller supercharger (C30) with less boost (~2psi less), makes more power (+35whp, +25wtq), due to the Ace header. The C30 + standard pulley + Ace header makes more power and more area under the curve than the C38 + high boost pulley + UEL header!
Imagine a C38 + HBP + Ace header...
Those sentences seem linked, but the first sentence is HBP vs HBP, and second sentence is standard pulley vs HBP like you discussed below in the other quote.
For that first sentence, the peak horsepower difference is seen at redline or close to redline; sub 6k or 6.5k, that difference is smaller, right? Maybe not a 10hp average, but less than 20hp difference average. It would be nice to know what the average difference is across the rpms instead of just a peak hp difference.
For the second sentence, the curves are virtually identical with the UEL HBP making slightly more power down low and then the curves cross at 5.5k rpms. The real difference seems to be past 7k where there is a 10hp difference in peak power. That difference would likely not get felt or seen except on the track.
It would be nice to see a C38 with a “HBP”. Maybe there would be no difference on the same pulley at such low, relative boost. Seems like most of the gains would be seen at higher boost than the HBP levels, where the C30 is working hard and heat/efficiency is an issue.
So this UEL header could be the JDL UEL header with a high flow cat? Why not say which one it is? Because if it is the one with a high flow cat then the 10hp difference up top might disappear without a cat, or be explained because of the cat, and the difference in power for HBP vs HBP could dwindle from an average of 15-20hp to 10hp. In which case, the price might be fine or might be too much. It is good to know before someone buys.
Old 10-17-2019, 04:55 PM   #63
CSG Mike
CSG Mike's Avatar
All headers involved are catless. Curves wouldnt be anywhere near close to this with a cat in the header.
Old 10-17-2019, 06:33 PM   #64
Irace86.2.0
So I see a JDL UEL catted, a JDL UEL uncatted, Tomei UEL and MXP UEL. Which one was this?
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Drift-Office : Vortech SC with and without Header - Case Study / Discussion? Drift-Office Forced Induction 14 09-27-2013 09:16 AM
