Old 10-11-2019, 06:23 PM   #1
Case study comparing the Ace header against a popular UEL header with FI
First dyno:
2017 MT (205hp base motor, new red manifold, etc.)
UEL header w/ ceramic
JRSC C38 w/ High Boost Pulley
Graphs:
baseline (stock)
ACN91
E55 (MBT, aka no more power to be made with more ethanol)
Second dyno:
2013 MT
Ace A350 header w/ CSG double ceramic
JRSC C30 w/ standard pulley and High Boost Pulley
Graphs:
baseline (stock)
E85 SBP
E85 HBP
Overlaid (combined) graphs w/ identifiers for comparison.
Conclusions: Smaller supercharger (C30) with less boost (~2psi less), makes more power (+35whp, +25wtq), due to the Ace header. The C30 + standard pulley + Ace header makes more power and more area under the curve than the C38 + high boost pulley + UEL header!
Both cars dyno tuned by Zach Tucker of CSG.
Imagine a C38 + HBP + Ace header...
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
brybot (11-01-2019), gtengr (10-12-2019), mrg666 (10-14-2019)
Old 10-11-2019, 07:18 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
No offense, but do we really need another thread reminding us the ACE header makes the most power? Otherwise, that output is very impressive!
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
Irace86.2.0 (10-15-2019), sroby (10-13-2019)
Old 10-12-2019, 01:38 AM   #3
colushi808
Drives: 2017 Toyota 86
Did you ever compare the different ace headers with boost? Is the 350 the best for boosted? I seen on their website that says the crossfire is for forced induction.
I also can't figure out that different size wheels and gear ratios would affect whp and call for a different header.
Sent from my SM-G965U1 using Tapatalk
colushi808 is offline   Reply With Quote
Old 10-12-2019, 09:50 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Wheel, tires and gear ratios are all hearing. Gearing is how power is delivered, not what makes power
Old 10-12-2019, 11:20 AM   #5
colushi808
Yeah that's why I dont understand ace headers website which recommends the different headers according to wheel size and gear ratios.
Old 10-12-2019, 11:47 AM   #6
86TOYO2k17
Drives: 2017 toyota 86
Im guessing it probably has to do with how long you stay in each gear. Longer gearing, stay in each gear longer, a more broad powerband would be better like the 350/400. Shorter gearing, stay in each gear less, a more peaky powerband would be better like 150/250.
The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post:
gtengr (10-12-2019), tomm.brz (10-12-2019)
Old 10-12-2019, 01:16 PM   #7
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
What I really want to see is an ACE header vs a Ptuning header, both tuned by Zach. For whatever reason PTuning always is ignored.
The Following User Says Thank You to why? For This Useful Post:
J1Avs (10-12-2019)
Old 10-12-2019, 02:55 PM   #8
J1Avs
Drives: 2018 BRZ tS
Or an ACE Header tuned by Zach and the PTuning header tuned by Toan but on the same dyno/same time -- as CSG uses a Dynojet and PTuning uses a Dyno Dynamics.
I've read that Dyno Dynamics is heart-breaker compared to a Dynojet, so I'd be quite interested to see what my tS with a JRSC C30/PTuning Header/JDL UQFP/E85 setup would do on a Dynojet. For reference, on PTuning's Dyno Dynamics I put down 307whp/230ft-lbs on a 90+degree day.
J1Avs is offline   Reply With Quote
Old 10-12-2019, 05:48 PM   #9
weederr33
weederr33's Avatar
I want to see the Nameless header but no one likes it lol. And it's discontinued. Or the HKS header. I don't need no fancy ACE header and sure as hell don't like UEL sounds. But I feel ya!
Old 10-12-2019, 07:33 PM   #10
We've seen Ptuning and Ace, both tuned by Shawn Church, and the same story as usual. NA, Same peak power, area under the curve is won by Ace, by a mile.
I haven't seen an apple to apples comparison FI yet.
why? (10-13-2019)
Old 10-12-2019, 07:36 PM   #11
CSG has a Dynapack in-house, and also often uses TRL's Dynojet.
While the dynos themselves can't be directly compared, when you always provide a baseline, you can very much overlay the baseline to get a semi-accurate comparison, as well as compare the % gain, which is what truly matters.
For reference, the TRL Dynojet reads exactly how a Dynojet should read, and is accurate for NASA Dynojet numbers. You can take whp numbers, divide by 0.88, and get accurate crank numbers. A stock FA20 reads ~175whp on this dyno
The CSG Dynapack reads lower, and you can take CSG whp numbers, divide by 0.75, and get accurate crank numbers. A stock FA20 reads ~150whp on this dyno.
Old 10-12-2019, 08:29 PM   #12
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Rod breaking power is available without the Ace, but thanks for the data.
Old 10-12-2019, 09:14 PM   #13
86MLR
86MLR's Avatar
I would like to see the ACE vs UEL catless vs OEM Decat (hammer and screwdriver).
Same car, same tuner (hopefully a good one), same dyno, same conditions, same fuel.
All on an NA engine where the pipe length, diameter, velocity, collector design and pulses really mean more in design than a boosted application where blow down is seen.
All by a independent place that doesn't sell aftermarket parts.
Disclaimer: I'm no expert, I just like fluid and thermal dynamics and their part in making power.
I would also like to see some traps and mph for each test.
From my experience there is generally a difference in claims when the tyres are on the blacktop.
Marketing is a magical thing.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 10-12-2019, 10:40 PM   #14
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
So many peeps salty bout the Ace being heads above the rest ..... thanks again for the validation of me buying the right header/ tune for my Fi brz
mswbrz is offline   Reply With Quote
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Drift-Office : Vortech SC with and without Header - Case Study / Discussion? Drift-Office Forced Induction 14 09-27-2013 09:16 AM
