| Engine Swaps Discussion of engine swaps. |
Drives: Toyota 86
hey guys
I apologize if I didn't ask my question in the right place i have a question about 2jz swap ![]() i have 2017 toyota 86 A/T and i wanna swap to 2JZ Manual Trans just i wanted to know what the problems would be in this swap How's that?and how to ? thanks guys |
#2 |
Drives: 2017 series yellow BRZ
whats your budget? for the most part 30-35k is basically bare minimum.
My BRZ Build Thread
http://www.ft86club.com/forums/showt...17#post3079417 |
#3 |
Drives: Toyota 86
#4 |
Rust bucket enthusiast
If you even remotely understood the implication or context of your own inquiry you wouldn't be asking.
#5 |
Are you doing the swap yourself, or paying a shop? If you're paying a shop, you should be asking them. If you're doing it yourself, good luck, this will be one of the easier parts of the swap.
#6 |
Drives: WORKS CARB Legal Turbo BRZ
There is going to be a lot of issues you're going to have to deal with. For the clutch system, you will need a new pedal assembly with clutch pedal. Then you will have to mount a clutch master cylinder and reservoir. After you've got that going it is going to be a fun project making a drive by wire system work. I'm not even sure how this would be accomplished. It may be easier to completely switch to a Tilton pedal setup as that would solve both of these issues so far. Of course, you will need a custom drive shaft and probably make a shifter cut out. Then there is the wiring. Thats going to be scary. I wouldnt even know how to begin with that. Getting diagrams for both engine and chassis would be a good start. Have highlighters and pens ready and get to matching wires. It is going to be a lot of hard work and even more money. Good luck with it all.
#7 | |
Drives: 2017 toyota 86
Step 2. Buy M/T Supra Swap complete. On a serious note. The A/T to M/T conversion is the least of your concerns, since you will be buying a new trans, drivetrain, etc... already regardless. But the swap itself is a lot of work. So much so that the need to ask this question probably takes you out of the very very few individuals in this world where a swap like this makes sense. Built FA20 shortblocks are pretty cheap if you can DIY everything yourself besides a tune you can be at a fun safe reliable 450whp for around $15k. If you want a M/T trade your car in for one. Or you can build the AT to handle 400ft lbs with clutch pack, valve body, torque converter for $3-4k more. |
#8 | |||
Drives: Toyota 86
![]() If I could buy M/T car, I'd buy it. But there are problems that make this impossible for me. I know one Tuning Group doing this for a few other 86. But they were M/T If I want to do it, I'll get help from them btw thanks for your help Quote:
yeah i know it's huge and needs hard and hard work and of course money but i didn't do anything yet... I just started gathering info and experience thanks ![]() Quote:
thanks |
#9 |
#10 |
Drives: 2013 frs red
Troll thread
#11 | |
My BRZ Build Thread
#12 |
#13 | |
he says he has a manual in that thread, but auto in this?
#14 | |
What would limit you from trading in and/or selling your 86 to buy a different one with a M/T already in it? New and or lightly used BRZ/86 M/Ts are all over the place. |
| Tags |
| 2017 86, 2jz swap, toyota 86 |
| Toyota 2AZ-FE Engine Swap | srscion | Engine Swaps | 54 | 10-26-2020 11:13 PM |
| FRS to Toyota 86 emblem swap | amartinez9881@gmail.com | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 03-15-2016 05:03 PM |
| Swap Emblem: FRS -> Toyota | simplychrispy | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 02-25-2015 12:14 PM |
| Toyota left a nice surprise if you're doing a Toyota motor swap.. | Manji | Engine Swaps | 15 | 01-07-2015 01:48 AM |
| Toyota MR2 motor swap | Abflug | Other Vehicles & General Automotive Discussions | 18 | 01-12-2011 06:12 PM |
