Old 01-05-2015, 05:26 AM   #1
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Toyota left a nice surprise if you're doing a Toyota motor swap..
Manji is offline   Reply With Quote
Old 01-05-2015, 06:04 AM   #2
BlackMonarch
Drives: Red BRZ
It's the little things like this that make me love our cars. Clearly designed from the ground up for the enthusiast. Same way a 2JZ bolts in almost entirely on the factory mounting points.
BlackMonarch is offline   Reply With Quote
Old 01-05-2015, 06:07 AM   #3
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
It does?
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 01-05-2015, 07:04 AM   #4
BlackMonarch
Drives: Red BRZ
Originally Posted by SomeoneWhoIsntMe View Post
It does?
Almost... http://www.speedparts.biz/jdmswaps.php?tempmodel=2710 - These here mounting brackets mount right up to the stock points.
Old 01-05-2015, 11:48 AM   #5
SomeoneWhoIsntMe
@BlackMonarch yeah, I have those Xcessive Manufacturing mounts for my 1JZ.
Most swap kits for almost every car ever utilize the stock mounting points with a fabricated bracket that bolts to the engine... by the same logic, Nissan designed the 240sx "for the enthusiast" by making a Toyota 1JZ mount up... before the engine was even released
Old 01-05-2015, 12:17 PM   #6
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
I think that is just a LHD/RHD alowment on the stock chasis to simplify production and lower costs on manufacturing and distribution across each market.
Just a happy coincidence, and not intended IMO.
-Jack Burton
Old 01-05-2015, 12:31 PM   #7
SomeoneWhoIsntMe
Could be vestigial from other RWD toyota transmission tunnel designs, or from when the engineers were holding out hope for a real engine and trans combo in it.
Old 01-05-2015, 01:19 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
^ THis
Old 01-05-2015, 09:21 PM   #9
FirestormFRS
That'd make perfect sense if the car didn't use the impreza/legacy platform as a starting point.
FirestormFRS is offline   Reply With Quote
Old 01-06-2015, 06:08 AM   #10
SomeoneWhoIsntMe
I mean in terms of the CAD data they used for the trans tunnel. I'm assuming they redesigned that section of the impreza chassis for the toyota trans but I guess I'm not sure.
Old 01-06-2015, 10:42 AM   #11
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Everything fit pretty nicely for me, my fab guy is dope. Think that recess is still on the rh side
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 01-06-2015, 10:46 AM   #12
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Things to note for r154... 5" shifter extension(pretty quick to make), makes exhaust ground clearance to be low as hell (prob going to a flat style tube around this area, not now but down the road), and to clear front sway bar had to grind down some webbing on the outside of the case (see above)
***that's an old pic above
Omar GC
Instagram: 2jzus
Old 01-06-2015, 05:27 PM   #13
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Lol forgot to mention... jza70 154
But we did the webbing cuts just in case I do decide to run a front sway (normally dont) but I have a feeling I'll be running something fairly large this go around.
Omar GC
Instagram: 2jzus
Old 01-06-2015, 06:23 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Are the different versions any difference in price or are they all in the same ball park?
Toyota V6 & V8 motor swap info GTV86 Engine Swaps 54 08-12-2014 01:03 PM
Best Motor TV - Toyota 86 / Subaru BRZ zAnSh1n FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 01-06-2014 11:10 PM
Best Motor TV - Toyota 86 / Subaru BRZ zAnSh1n BRZ Photos, Videos, Wallpapers, Gallery Forum 0 07-03-2012 02:05 AM
Toyota reference has the FR-S with a 2.5L motor Toyota fr-s Scion FR-S / Toyota 86 GT86 General Forum 3 09-24-2011 05:42 PM
Toyota MR2 motor swap Abflug Other Vehicles & General Automotive Discussions 18 01-12-2011 06:12 PM
