Old 10-02-2018, 02:00 PM   #1
srscion
srscion's Avatar
Drives: 2016 FRS
Toyota 2AZ-FE Engine Swap
So I took out the box motor and put in a 2AZ FE motor with a custom turbo kit. The results were very good. I have instant torque and next to no boost lag.
srscion is offline   Reply With Quote
The Following 5 Users Say Thank You to srscion For This Useful Post:
atomicalex (05-28-2019), chaoskaze (10-02-2018), JeremyR (10-02-2018), Trust86 (10-02-2018), ybotspawn (04-16-2019)
Old 10-02-2018, 02:01 PM   #2
srscion
srscion's Avatar
Drives: 2016 FRS
Acceleration Video
This is old, I have been too busy to make a new one just yet
[ame]https://www.youtube.com/watch?v=T5raNoWfPaQ[/ame]
The Following 2 Users Say Thank You to srscion For This Useful Post:
DustinS (10-02-2018), JeremyR (10-02-2018)
Old 10-02-2018, 04:36 PM   #3
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
I have so many questions..
Donor car? Engine MGMT? Tranny? Any plans to make the cluster work?
We need more details!
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 10-02-2018, 07:26 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Like any of the dozen Toyota vehicles that had it. Now he has a RWD Scion TC. Cool, it’s different.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 10-03-2018, 02:38 AM   #5
Godzilla35
Drives: Nissan GT-R
More info!!!
Godzilla35 is offline   Reply With Quote
Old 10-03-2018, 09:58 AM   #6
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Nice job Shane. Did you ever figure out a hood fix?
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
srscion (04-15-2019)
Old 10-04-2018, 12:21 AM   #7
Irace86.2.0
I feel like the Lexus 8AR-FTS would have been the swap to do. 86mm bore and stroke, d4s, turbocharged, all aluminum. Probably much harder to find and more expensive, but maybe not as expensive as a motor plus a custom turbo kit.
Old 10-08-2018, 01:13 PM   #8
PuslarBrrrz
He's only $3k into the swap since 2AR's are dirt cheap. You'd need more than that to get a 8AR-FTS.
PuslarBrrrz is offline   Reply With Quote
The Following User Says Thank You to PuslarBrrrz For This Useful Post:
why? (04-21-2019)
Old 10-08-2018, 02:31 PM   #9
Irace86.2.0
$3k isn’t bad for an engine, turbo kit, custom belhousing, clutch kit, engine management and materials/misc for fabrication and assembly. Chinese turbo? Im guessing cheaper than the twin scroll on the 2AR. It would be cool to see a parts list.
Old 04-15-2019, 03:03 PM   #10
srscion
srscion's Avatar
Drives: 2016 FRS
Updates.
Hey guys, for some reason I never got any notifications but I do have a hood fix and the car is equipped with full integration so it functions like it came from the dealer with this motor. I will post up a lot of details and a high quality promo video when the hood finally gets done. Its been taking a while dude to the availability of the person doing the body work on the hood. Thank you all for your patience.
The Following User Says Thank You to srscion For This Useful Post:
why? (04-21-2019)
Old 04-15-2019, 03:11 PM   #11
srscion
srscion's Avatar
Drives: 2016 FRS
So far the build list is as follows:
Custom trans adapter plate
ACT pressure plate
Stock clutch disc and flywheel
700cc DW injectors
Garret 60/63 custom 360 thrust bearing turbo
Megan Racing Strut Bar
Toyo Proxes 4+ tires 245-45-17
Grid Classic Wheels
Street Rays short shifter
Duel ECU solution with AEM engine management
Mtec Shift springs
Helper spring delete
Grimspeed BMC brace
Powerslot rotors
11psi (estimated 340whp) raw hp from base tune was 314. It's dialed in decent now.
Old 04-15-2019, 04:20 PM   #12
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Saw in the comments of one of your videos that you're working on a swap kit. Is that still something you plan to produce? Any clue on ETA/cost estimate?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 04-15-2019, 07:46 PM   #13
Irace86.2.0
ACT pressure plate
700cc DW injectors
Grid Classic Wheels
Mtec Shift springs
Grimspeed BMC brace
Powerslot rotors
Any pics of the adapter? Curious to see how it works with the stock trans, clutch fork and the 2AZ flywheel, etc.
So engine, turbo, manifold, engine management, custom trans adapter, etc was $3k? What about BOV, external wastegate, intercooler setup, etc? I’m still confused how this all came together so cheap.
Shark_Bait88 (04-16-2019)
Old 04-16-2019, 01:14 PM   #14
evomike
Drives: frs
possibly had alot of that stuff laying around from old builds, i know i have all kinds of random parts laying around from years of modding cars.
evomike is offline   Reply With Quote
Toyota Aristo Engine Harness Conversion to USDM Supra TT to Swap into FRS ThePurist Engine Swaps 0 11-23-2017 08:13 PM
Toyota left a nice surprise if you're doing a Toyota motor swap.. Manji Engine Swaps 15 01-07-2015 01:48 AM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 01:56 AM
Engine Swap hybrid35 Southern California 0 01-07-2013 01:04 PM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
