Old 10-08-2019, 12:00 PM   #1
Antisocialspeed
Drives: 2013 FRS
Metal in oil
Purchase a 2013 FRS back in August with around 25,000 miles on it currently has 27000 miles. Changed the oil about two weekends ago and noticed metal in the oil ie: glitter looking. About a week later dropped a little bit of the oil into a cup and still n
oticed glitter in the newer oil. I know the valve spring recall was done at 23, 500 miles so there has been about 3,500 miles put on since the valve spring recall. Question is whether or not this is just possibly break in from the new valve springs which I highly doubt as I don't believe there's metal-to-metal contact on the valve springs but please correct me if I'm wrong. Looking at options now potentially taking it to a local dealership and having them drop the pan to document if they find any gasket material in there that lead it back to the recall. Unfortunately the car was purchased out of state and the dealership that did the work is out of state so I can't take it back there.
So far I have not heard any tell tale knocking sounds. Performance seems fine however I don't have anything to compare it to. Getting 27.2 average miles per gallon if that makes any difference? Pulled the dipstick yesterday and found two tiny pieces of metal on cloth appears to be silver so I'm guessing aluminum as does not get picked up by a magnet. Going to pull an oil analysis however I've heard that these don't always tell what is going on if the bearings are failing.
Car is stock aside from a TRD intake.
Side note, I sometimes smell a heavy exhaust smell when accelerating quickly, not sure if this is normal or may have something to do with what's going on and doesn't happen all that often.
Any suggestions or guidance?
Antisocialspeed is offline   Reply With Quote
Old 10-08-2019, 12:02 PM   #2
Lantanafrs2
Drives: 2013 frs red
I never had any exhaust odor on acceleration. There should never be metal pieces on your dipstick
Lantanafrs2 is offline   Reply With Quote
Old 10-08-2019, 12:13 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The only way to know is to have your oil sample tested.
Anything else is just speculation and of zero use to you.
Old 10-08-2019, 12:18 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Have you expressed concern with the dealership who did the work yet? A wound is easier to treat before gangrene sets in. I understand the work was not performed under your ownership, but it's still worth bringing attention to if it's feasible.
Old 10-08-2019, 01:27 PM   #5
Grady
Grady's Avatar
A) Cut oil filter open and inspect for excessive metal.
B) Have oil sample done.
C) Drive it till she blows.
I would suggest doing items A and B.
FYI
Inspecting oil filter right after an oil change is worthless. Do you have your old filter?
The Following User Says Thank You to Grady For This Useful Post:
Tcoat (10-08-2019)
Old 10-08-2019, 01:32 PM   #6
FYI
If there is already that much metal (to the point you can find pieces on the dipstick) then I think that item C is pretty much a forgone conclusion. Even getting oil flow back at this point will just prolong the inevitable.
Grady (10-08-2019)
Old 10-08-2019, 02:55 PM   #7
mav1178
mav1178's Avatar
The problem is 'glitter looking'.
When I ran ENEOS oil on my BRZ, the oils always looked like it had glitter in it.
OP is speculating at this point without any actual proof, so either his engine is on its way out, or there's nothing to be worried about.
For OP: if UOA can't detect metal wear in the oil, then you have nothing to worry about. If a bearing is failing, it will wear excessively and the shavings WILL be present in an analysis. If it just snapped without warning, then yes you won't be able to get any readings... but then again, your engine would've been toast already.
Internal parts usually do not just snap from normal driving, excessive metal wear is the first telltale sign.
Tcoat (10-08-2019)
Old 10-08-2019, 03:05 PM   #8
The glitter wasn't what set off my alarms it was the metal on the dipstick.
Old 10-08-2019, 03:44 PM   #9
Antisocialspeed
Drives: 2013 FRS
Oil is on its way to Blackstone so we will see what they find. And Tcoat, you are exactly right, the glittering in the oil made me concerned but it wasnt until I saw actual metal on the dip stick that caused panic. Some oil additives will probably give a glittery appearance and no idea what was added before I bought it. I was sure hoping that maybe it was just the kind of oil or something else in there.
Going to check and see if I still have the old filter in the garage when I get home tonight. If I do I'll cut it open and see.
I have an appointment with a local dealership tomorrow morning to drop the oil pan and see if there is any gasket remnants in there or the pick up to possibly trace it back to recall work. But if not I'm out the service fee and I'll be looking to source a new engine for when this one goes.
What's the latest model that will directly drop in a 2013? A 14, or will a newer 2015/16 go in with out having to change a bunch iof stuff around, wiring, ecu etc??
Thanks for all the feedback and help everyone!!
Old 10-08-2019, 05:38 PM   #10
Grady
Grady's Avatar
Excessive metal/glitter is subjective. Probably bad but possibly he is over reacting.
For all we know he may work at a strip club and all he is seeing is stripper glitter.
Mr.ac (10-09-2019)
Old 10-08-2019, 07:33 PM   #11
mav1178
mav1178's Avatar
I know, but if I was in OP's shoes I'd do a UOA and then figure out next steps.
Without some type of analysis OP's word is as good as Subaru's. Plus, if this was truly a concern I'd stop driving the car immediately until 1) UOA is done, or 2) Subaru agrees to inspect the car.
Considering how different dealers don't like to handle someone else's work, this will drag on forever... so the only way to know is to get the oil tested and determine next steps.
Old 10-08-2019, 08:29 PM   #12
Agree. Didn't say otherwise.
Old 10-09-2019, 01:00 AM   #13
solidsnake11
Drives: brz
Usually you can hear rod knock at a cold start when its in the early stages. Catch it early enough ,you can just change the rod bearings on most motors and be fine.
solidsnake11 is offline   Reply With Quote
Old 10-09-2019, 08:50 AM   #14
Antisocialspeed
Drives: 2013 FRS
Since there is metal already floating around would I risk the coil passages potentially clogging up on the future or causing issues down the road if I only repair the engine?
Again as others have stated it's all speculative at this point. But the size of the piece of metal on the dipstick was bad. Like a flat grain of sand size.
metal on metal sound when releasing the clutch MyNave Engine, Exhaust, Transmission 7 04-18-2018 12:00 AM
WTB 57DR Gun Metal x 4 xbwhahax Want-To-Buy Requests 0 04-24-2015 01:16 PM
what is this metal piece travisb BRZ First-Gen (2012+) — General Topics 9 03-17-2015 03:08 PM
Metal on metal noise at 2500 RPM ssyed Issues | Warranty | Recalls / TSB 2 09-08-2014 04:01 PM
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 12:00 AM
