Drives: 2018 Subaru BRZ Sport-Tech RS
Metal on metal scratching noise front left wheel
Hi,
My BRZ 2013 with 6000km on it just started doing this today. Basically only when I turn right my front left wheel make a pretty loud metal on metal scratching noise. Brake dust cover scratching? Brake pad scratching? I have no idea what it is exactly but I have confirmed with a friend standing outside the car in my parking lot that the sound comes out of the left front wheel while I'm turning right. It's a loud metal on metal scratching sound that is constant until I stop turning right while moving. Any thoughts or experience with this issue? Thanks |
Drives: Asphalt FRS
Does the sound increase and decrease with speed? Are there any modifications done in that area?
#3 | |
Yes it increase with speed but I need to be turning right in order to hear the sound. No modification, during summer I use the OEM standard wheels. I read somewhere that it my be gravel stuck between the brake dust cover and the brake disk... I went outside with a pen and started knocking on the brake dust cover to see if something is stuck between the cover and the brake disk. I can hear a little rattling noise, just like if a small rock was stuck there. I tried doing the same thing on the right front wheel and I don't hear the small rattling noise. My guess right now is that there's a small rock stuck there... what should I do? |
Drives: Asphalt FRS
You could take it to the dealership if you haven't had any mods in that area done and see what's going on. They shouldn't charge you just to look at it. And if anything, they can at least put everything back together for you with the right torque specs. That's what I would do first.
#5 | |
Super 86
Drives: Red 86 GTS
230rwhp/184ftlb on 98RON/93AKI
Build thread Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can |
#6 | |
Drives: SWP BRZ
I haven't investigated the brakes yet but I'll do it next week end. Let us know what happens with your car.
thanks for the replies, I'm not comfortable removing my brake disks... I will see if the rock get out by itself.
otherwise if its a mechanical defect the part will just break and I will get it replaced under warranty. but it does make a very loud metal on metal scratching rubbing noise. People on the street can hear it very much |
Does it sound like this??
[ame="https://www.youtube.com/watch?v=QTxZD9KpQC4"]Mazdaspeed 3 screeching sound. Rock in between brake pad and rotor? - YouTube[/ame] Pop the wheel off and take a peak, it happened on my old tC. I took the wheel off, gave the rotor a shake and a rock fell out.
| Scratching noise from clutch when stopped | jshadeck | Issues | Warranty | Recalls / TSB | 2 | 09-10-2013 12:37 PM |
| Scraping metal noise? | Gost | Issues | Warranty | Recalls / TSB | 0 | 03-14-2013 09:11 PM |
| WEDSSPORT TC105N - 18x8.5/9.5 - Gun Metal Now Available ~ 17 lbs per wheel | RavSpec | Wheels and Tires | 12 | 12-02-2012 07:47 AM |
| I've seen the GT86 in the metal and... | Craikeybaby | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 12-13-2011 03:57 AM |
