Old 09-08-2014, 01:44 PM   #1
ssyed
ssyed's Avatar
Drives: 2013 Frs
Metal on metal noise at 2500 RPM
So, I went for a drive In the morning to get open loop logs for MAF scaling and I did a few 2k to redline runs and on the way back I started hearing this metal on metal noise at exactly 2500 RPM. I've done this before as well and no issues.
Any thoughts on what it could be?
Mods:
- Openflash OTS Stage 2 UEL 91 tune ( on car for 1 month)
- JDL UEL headers (3 months)
- nameless down pipe (front pipe over pipe combo) (3 months)
- Ark DTS Exhaust
- Perrin 2.75" intake with Perrin inlet hose (1 month)
Car details:
2013 FRS
25,000 KMs
ssyed is offline   Reply With Quote
Old 09-08-2014, 02:13 PM   #2
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
I would check all of your header back connections. They can come lose and cause a rattle at the right RPM due to the vibrations. I have one at 1,000 RPM upon initial load and it turns out my header heat shield rattles on the down pipe upon initial torque load. I'm going to use large hose clamps and some heat wrap to insulate the two.
Because you have an aftermarket header you won't have the heat shield problem but my overripe hanger bolt has also come loose before. Might check that.
Mods:
- Ark DTS Exhaust
Car details:
2013 FRS
25,000 KMs
nlowell is offline   Reply With Quote
Old 09-08-2014, 04:01 PM   #3
ssyed
ssyed's Avatar
Drives: 2013 Frs
So I figured it out. Ark DT-S exhaust was the culprit. Name:  ImageUploadedByTapatalk1410206439.573009.jpg
I don't know how this happened but that piece was broken off and making noise lol, and I thought it was my engine ready to go kabooom
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 12:00 AM
Die Cast Metal Car FT86JC FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 08-10-2014 03:21 PM
Looking For Metal Fabricator rb6freak Southern California 2 03-04-2014 09:05 PM
Anyone into folk metal? Anthony Off-Topic Lounge [WARNING: NO POLITICS] 32 09-20-2013 03:06 AM
Scraping metal noise? Gost Issues | Warranty | Recalls / TSB 0 03-14-2013 09:11 PM
