Old 09-28-2019, 03:26 AM   #1
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
18x9.5 +45 rubs on my front spring perches. Help me please.
So I read on the forums that 18x9.5 +45 fits on our cars without spacers. I put the wheels on tonight and to my dismay found that the tires are right up against the spring perch. I'm using 255/35/18 tires on these rims.
I'm gonna guess that everyone that got them to fit is using coilovers vs stock struts? Is there any detail that I'm missing here? Thanks everyone for any help you can provide.
mrha is offline   Reply With Quote
Old 09-28-2019, 03:56 AM   #2
Firedrops
Drives: MY15
Are you on stock struts?
Firedrops is offline   Reply With Quote
Old 09-28-2019, 04:41 AM   #3
Skyehigh55
Drives: 2017 Pure Red BRZ w/ Perf Package
Stock struts already have a hard enough time fitting 18x9.5 at +38 offset... Idk where you heard 18x9.5 +45 fits comfortable on stock struts but for next time,use the wheel calculator at https://www.ft86motorsports.com/wheelitfit/
This is your setup currently at stock height and nothing else added (given your notes in your post). If you're running camber bolts or anything else, it may affect your fitment but idk so I"m using base numbers as a guideline.
Clearly it has 12mm clearance issues.
The other thing you can do is get 15mm spacers to clear the perch. The 15mm will make your wheels technically +30 offset in this case. To dial in the poke you'll have at +30 offset, I then recommend camber bolts to about -2 degrees to tuck in the wheel. In theory it should clear with these add-ons.
If this all seems too complicated... Just get a set of coilovers and you won't have to worry about a +45 fitment on a 9.5 wheel. Hope this helps!
Skyehigh55 is offline   Reply With Quote
The Following 4 Users Say Thank You to Skyehigh55 For This Useful Post:
DarkPira7e (11-04-2019), mrg666 (11-30-2019), soundman98 (09-28-2019), strat61caster (09-28-2019)
Old 09-28-2019, 10:51 AM   #4
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
17x9 +45 does not fit. So yea, you will have fitment issues. +15 stud spacer until you get coils?
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 09-28-2019, 01:58 PM   #5
mrha
#1819
mrha's Avatar
Are there any coil overs that would not work for my wheels? Are all coil overs roughly the same diameter?
Old 09-28-2019, 02:52 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18X9.5 +38 Fits with a 235/40/18 on stock suspensions.
18x9.5 +35 fits with a 245/35/18 on stock suspensions.
Get extended studs, 10mm to 15mm spacers, and camber bolts minimum.
Edit: yeah with a 255/35/18 already... you will want coils.
I LIKE TIRES!
Old 10-07-2019, 03:13 PM   #7
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
18x9.5 +38 with 245/35/18 fits on stock suspension too, full lock to lock no rub. I know because I had it for two weeks while waiting for my coils
Shizuka is offline   Reply With Quote
Old 10-07-2019, 03:27 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks! I know, but not all 245/35's are the same width. And with a +38 offset, which is very close, not all 245/35s fit on stock suspension.
I LIKE TIRES!
Old 11-02-2019, 09:32 PM   #9
carlovestela
Drives: 2015 Firestorm FRS
Planning to do the advan tc4 which is 18x9.5 +45 with 255/40/18 tires.
Will it fit using tein flex a/z or bc br coils?
Thanks.
carlovestela is offline   Reply With Quote
Old 11-03-2019, 01:43 AM   #10
mrha
#1819
mrha's Avatar
Thanks.
40 is a bit tall. You may want to run that through a calculator. The coilovers should be fine. I myself went with ST coils.
Old 11-03-2019, 01:37 PM   #11
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I had 255 35 R18s on my 18X9.5 (MP4S), you definitely need coils to run 255s or you will rub. You need like 235s to be on the safe side to not rub on stock suspension on the fronts. You will also need to dial in some negative camber, at least -2 degrees or you'll get some poke. That +45 is not helping you either.
Old 11-04-2019, 05:17 AM   #12
carlovestela
Yes. Im on tein flex z coils now. Im using 57cr 17x9+38 245/40/17.
And im planning to change it to advan tc 18x9.5+45 245-255/35/18.
Will it rub? Even if i change my coils to flex a or bc?
Thanks
Old 11-04-2019, 07:23 AM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Please let us know where you heard that a 9.5" wheel with a +40 offset would fit so we can correct them. I had light rubbing on +35 8.5" wheels with stock struts.
Your only option is to either gets coilovers, or get some serious bolt on spacers. Since you'll be spending the money anyone, I'd just get some coilovers to avoid the issue altogether.
Old 11-04-2019, 06:48 PM   #14
carlovestela
Sir. 18x9.5 +45 with 255/35/18 tires will not rub if i have tein flex z/a or bc coils?
Thanks
Coaxial Spring Perches Rear Coilovers Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-14-2019 06:05 PM
BRZ/FRS stock spring perches (MCS) AndrewMcG Brakes, Suspension, Chassis 2 08-23-2017 10:32 AM
[SOLD] Raceseng Cas/Cam Plates (90mm perches) Shark_Bait88 Brakes, Suspension, Chassis 4 07-31-2017 02:05 PM
Lowered on coilovers with camber, front swaybar endlink rubs/binds inner wheel well? Krovi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 09-28-2016 10:02 AM
17x9 et45 245/40/17 rubs no more. garfull Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 11-26-2013 07:41 PM
