Old 09-14-2019, 12:33 AM   #1
Butterballz
Drives: Black FRS
Coaxial Spring Perches Rear Coilovers
So I'm going to buy some coilovers that use the stock top hat for the rears. I'm going to buy an aftermarket top hot and was wondering if a coaxial spring perch is necessary or recommended. Since I'm tracking the car, it would go through stresses higher than usual. Does not using one put extra stress on the seals and shock rod or is the extra wear overexaggerated? I don't think I've ever heard someone say they wore out their coilovers sooner than normal.
Butterballz is offline   Reply With Quote
Old 09-14-2019, 06:05 PM   #2
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
They are not necessary but they do make everything work "better." I run them with my MCS, but I am trying to optimize the car for STX as much as possible.
Lincoln Logs is offline   Reply With Quote
DIF Top Hats -- Caster/Camber Adjustable, Caster Adjustable, and Coaxial Rear FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-19-2017 01:43 PM
BRZ/FRS stock spring perches (MCS) AndrewMcG Brakes, Suspension, Chassis 2 08-23-2017 10:32 AM
[SOLD] Raceseng Cas/Cam Plates (90mm perches) Shark_Bait88 Brakes, Suspension, Chassis 4 07-31-2017 02:05 PM
2way coaxial vs component system lbroskee Electronics | Audio | NAV | Infotainment 29 03-12-2016 12:03 PM
[WA] Kicker CSS65 coaxial speakers x 4pcs Fizz Australia Classifieds 0 06-18-2013 09:30 PM
