Old 09-16-2019, 12:47 PM   #57
Originally Posted by vladniko86 View Post
Not to resssurect an old thread, I have a 2013 frs with 68k miles. Can I put in the subaru throwout bearing in to fix my squeak? I've tried lubing the components already
Can put in either one as long as it is the updated part number. Just contact Toyota and Subaru and find out which part is cheaper. They are identical parts just different numbers for the two different inventory systems.
vladniko86 (09-16-2019)
Old 09-16-2019, 12:48 PM   #58
vladniko86
vladniko86's Avatar
Drives: FRS
Perfect I'll go grab the one from my subie dealer cause they have it in stock. Dropping trans today then
vladniko86 is offline   Reply With Quote
Old 09-16-2019, 01:08 PM   #59
Just make sure that it has the yellow or white paint dot on it to show it is the new one.
Old 09-16-2019, 01:13 PM   #60
vladniko86
vladniko86's Avatar
Drives: FRS
On the part itself?
Old 09-16-2019, 01:18 PM   #61
On the part itself?
Yes. Take a look at the Subaru TSB under the Part Information section. It tells you where to look.
Old 09-16-2019, 01:54 PM   #62
Lantanafrs2
Drives: 2013 frs red
You took the tranny out and didn't replace the bearing?
Lantanafrs2 is offline   Reply With Quote
Old 09-16-2019, 02:06 PM   #63
vladniko86
vladniko86's Avatar
Drives: FRS
No my trans squeaks when I press clutch and I'm taking it out today. I had recall done not too long ago and should've had them replace it but oh well
The Following User Says Thank You to vladniko86 For This Useful Post:
Lantanafrs2 (09-16-2019)
Old 09-17-2019, 10:52 AM   #64
vladniko86
vladniko86's Avatar
Drives: FRS
Ok so I took the slave cylinder off, and while it was off I could move the fork back and forth with no squeak. When I did, I took the boot off and greased the whole pin and put it back in. Now when I press the clutch it still squeaks. I moved the trans by the fork without the cylinder and it didn't squeak, and now with the slave cylinder it still squeaks. Thoughts?
Old 09-17-2019, 11:03 AM   #65
Is it a squeak or a squeal? If a squeak only then you may just need to lube more. If a squeal it is the TOB. The TOB will not squeal when moving things by hand it needs to be spinning.
Old 09-17-2019, 11:05 AM   #66
vladniko86
vladniko86's Avatar
Drives: FRS
It's simply a squeak. Also I kind of want to drop trans for peace of mind, I put a solid two finger globs of lube on the wrong side of the fork and would rather drop and clean it up. I never have noise when it runs, just when it's cold and I press the pedal down. The other thing is I put a little Camera into the hole and the TOB looked like it had spots of rust which is concerning
Old 09-17-2019, 11:10 AM   #67
Surface rust on the outside of the bearing are no big deal since moisture can get in there. If the whole thing is uniformly rusty it could be an indication that it is overheating since heat will promote rust.
Old 09-17-2019, 11:11 AM   #68
vladniko86
vladniko86's Avatar
Drives: FRS
No just a few spots. Also what do you think of extra grease being in there?
Old 09-17-2019, 11:22 AM   #69
Lantanafrs2
Mine only makes noise when its cold as well. Its inconsistent.
Throw out bearing comparison old vs new Trueweltall Engine, Exhaust, Transmission 59 07-21-2022 11:36 PM
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 05:32 PM
Throw out bearing Hyp Northern California 26 03-13-2017 11:42 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 04:45 AM
