#57 |
Can put in either one as long as it is the updated part number. Just contact Toyota and Subaru and find out which part is cheaper. They are identical parts just different numbers for the two different inventory systems.
| The Following User Says Thank You to Tcoat For This Useful Post: | vladniko86 (09-16-2019) |
#58 | |
Drives: FRS
Perfect I'll go grab the one from my subie dealer cause they have it in stock. Dropping trans today then Sent from my iPhone using Tapatalk |
#59 |
Just make sure that it has the yellow or white paint dot on it to show it is the new one.
#60 |
Drives: FRS
#61 |
Yes. Take a look at the Subaru TSB under the Part Information section. It tells you where to look.
#62 |
Drives: 2013 frs red
You took the tranny out and didn't replace the bearing?
#63 |
Drives: FRS
| The Following User Says Thank You to vladniko86 For This Useful Post: | Lantanafrs2 (09-16-2019) |
#64 | |
Drives: FRS
Ok so I took the slave cylinder off, and while it was off I could move the fork back and forth with no squeak. When I did, I took the boot off and greased the whole pin and put it back in. Now when I press the clutch it still squeaks. I moved the trans by the fork without the cylinder and it didn't squeak, and now with the slave cylinder it still squeaks. Thoughts? Sent from my iPhone using Tapatalk |
#65 | |
#66 | |
Drives: FRS
It's simply a squeak. Also I kind of want to drop trans for peace of mind, I put a solid two finger globs of lube on the wrong side of the fork and would rather drop and clean it up. I never have noise when it runs, just when it's cold and I press the pedal down. The other thing is I put a little Camera into the hole and the TOB looked like it had spots of rust which is concerning Sent from my iPhone using Tapatalk |
#67 | |
#68 | |
Drives: FRS
No just a few spots. Also what do you think of extra grease being in there? Sent from my iPhone using Tapatalk |
#69 |
Mine only makes noise when its cold as well. Its inconsistent.
| Throw out bearing comparison old vs new | Trueweltall | Engine, Exhaust, Transmission | 59 | 07-21-2022 11:36 PM |
| Melted Throw Out Bearing | danthedirt | Issues | Warranty | Recalls / TSB | 59 | 01-25-2018 05:32 PM |
| Throw out bearing | Hyp | Northern California | 26 | 03-13-2017 11:42 PM |
| Throw-out bearing | mhigham | Issues | Warranty | Recalls / TSB | 71 | 08-18-2016 10:21 AM |
| Noisy throw out bearing | jp_r6 | Issues | Warranty | Recalls / TSB | 23 | 08-18-2016 04:45 AM |
