Old 09-14-2019, 05:15 PM   #1
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
High pitched whining only when clutch pedal is fully extended.
Hey guys. '13 FRS with 50k on the clock. I'm getting a high-pitched whining when the clutch pedal is fully extended from somewhere within the clutch/tranny/drive shaft area. Goes away completely when clutch is depressed. Happens both in neutral and while driving in gear. Been happening for about a month or two but has gotten louder recently. Was hard to notice over my exhaust initially but now when I start the car it is quite noticeable.
Taking it in Tuesday most likely but just looking for some thoughts. Tranny fluid replacement? TOB? Clutch?
Any help would be appreciated. Thank you.
Evil Jesus is offline   Reply With Quote
Old 09-14-2019, 06:58 PM   #2
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Maybe flywheel. That's where all my noise comes from, but lots of moving parts in that area. Does it go away when you push the clutch in?
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 09-14-2019, 07:03 PM   #3
Evil Jesus
Evil Jesus's Avatar
Yup, completely disappears when the clutch is in.
Old 09-14-2019, 08:01 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds like your TOB is going out.
At 50k is when I started to hear a whirling sound just like you described. Mine lasted it 73k when it completely shot itself in the Taco Bell drive through.
So.... if I where you I would start looking into doing that repair soon.
Old 09-14-2019, 08:27 PM   #5
Decep
Drives: 2013 FR-S Series 10
Join the TOB club
Old 09-14-2019, 09:52 PM   #6
Evil Jesus
Evil Jesus's Avatar
I think I saw your post in another TOB thread in this section. Did you have any clutch damage or flywheel damage?
Originally Posted by Decep View Post
Join the TOB club
Ugh, this is not a club I want to be a part of. In the 7 years I've had it I've been in the idle dropping and stalling club (literally the day I drove it off the lot), the HPFP crickets club, the condensation in the rear tail lamps club (3 F'n Times!), the coil pack failure club, the valve spring recall club, and now this one. Hooray February '12 build date!
Old 09-14-2019, 10:02 PM   #7
Decep
Lol. I had the cracked tail light, crickets (though they have disappeared, havent heard them since last summer) and TOB. TOB started rattling at 48k, though by the looks of it it could have gone another 20K. Just didn't want it to explode and take a bunch of stuff out with it. Missed the valve spring recall by about 3 months thankfully.
Last car was a 2000 Accord i drove from 60k to 200k, and all i replaced was a heater control valve and a thermostat. Did the spark plugs at like 170k and they looked pretty clean. I did have to change all the shocks but that's because my dumb ass had eibach prokit lowering springs installed which made them all leak. Shortly after i sold it apparently the new owner had to replace a couple fuel injectors.
That car was a total joke in terms of maintenance, amazing testament to Japanese engineering. Didn't handle that bad either after the springs. Since it was a stripped down DX, it weighed about the same as my FRS. No rear sway bar (lol!) so i installed a fat one from the Acura CL.
Old 09-14-2019, 10:02 PM   #8
Strife26
Strife26's Avatar
A new clutch might make the car feel more lively. Mine got stupid torquey after a new clutch.
Old 09-14-2019, 10:06 PM   #9
Decep
uh, what?
Old 09-14-2019, 10:39 PM   #10
Strife26
Strife26's Avatar
uh, what?
Oh gawd...here we go. Let's not hijack it. If youre legitimately curious you can im me, otherwise I have no food for you.
Old 09-14-2019, 10:43 PM   #11
Lantanafrs2
Drives: 2013 frs red
I get the same thing occasionally especially when in neutral.
Lantanafrs2 is offline   Reply With Quote
Old 09-15-2019, 03:11 PM   #12
Evil Jesus
Evil Jesus's Avatar
Does the pitch increase with revs?
Old 09-15-2019, 06:10 PM   #13
Lantanafrs2
Yes
Old 09-15-2019, 09:31 PM   #14
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
When the TOB goes out the only damage if any is the shaft it rises on.
Clutch cover plate could have a 5% chance of getting scared.
When I did mine clutch and flywheel where in perfect condition. So I deem them good to stay on.
However the shaft the TOB rides on was pretty rough up. But a bit of sand paper and red Scott brite made it good as new. If the damaged was greater I would have replaced that part. Which is only $140-ish and 4-5 bolt to remove simple fix really.
High pitched chirping when AC on?? Spectral Entity Issues | Warranty | Recalls / TSB 8 01-29-2021 05:50 AM
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
Is it bad to have my ankle fully extended forward when pressing the clutch? cat94 Scion FR-S / Toyota 86 GT86 General Forum 70 11-24-2016 04:10 PM
high pitched noise when clutch is engaged ( video attached) jotig Issues | Warranty | Recalls / TSB 9 07-05-2015 09:22 PM
TSB - FRS (re: High pitched chirping...) PNW FRS Issues | Warranty | Recalls / TSB 1 01-19-2013 01:05 AM
