Old 02-23-2018, 03:46 PM   #1
Spectral Entity
Spectral Entity's Avatar
Drives: 16 Scion FR-S Hot Lava, 81 DeLorean
High pitched chirping when AC on??
I've developed a mildly annoying sound in my car that is apparently not crickets, and while the Toyota dealer couldn't hear it, I certainly can.
It literally sounds like a cricket chirping nonstop but it's only when I have my AC on, and most noticeable on fan setting 2.
Could there be some debris in the blower motor? If so, how would I go about checking it out?
Thanks in advance.
Spectral Entity is offline   Reply With Quote
Old 02-23-2018, 04:02 PM   #2
nico_rsx
Drives: BRZ 2017 Pure Red, MT
When you mean AC, you are talking about the compressor right?
What happens if the AC if off and the fan at speed 2? If there is no noise, then it's not the blower motor.
If the noise is still there, then there is a good chance it's the blower motor. Bearing maybe.
If the noise is only there when the compressor is running, then it has nothing to do with the blower motor. Check if the noise is coming fom the accesories belt.
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
humfrz (02-24-2018)
Old 02-23-2018, 04:14 PM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Check your cabin air filter too. Also open the hood when it's doing it and listen around to where it's coming from
Old 02-23-2018, 05:02 PM   #4
Spectral Entity
Changed the cabin filter last week but glad for the suggestion as I found some dead ants up in there (wtf?!) and tapped them all out on the ground.
I seemed to have isolated the noise to the round thing plugged in under the glove box. I turned the AC compressor off and still heard the noise from this area, as well.
Is said round thing the blower motor?
Old 02-24-2018, 12:41 AM   #5
humfrz
Most likely. I'd suggest you take it off and have a look see .....
humfrz
Old 02-24-2018, 02:01 AM   #6
Yes it is the blower. Take a look at the last couple of posts here - http://www.ft86club.com/forums/showt...t=97411&page=2
Old 02-26-2018, 09:17 PM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The ant's and other debris may be within the motor now and may have effected the motor. If you still have a warranty it's best to have it replaced, if not do the wd40 trick.
Old 03-02-2018, 04:49 PM   #8
hichamaziz
Drives: subaru brz
hichamaziz is offline   Reply With Quote
Old 01-29-2021, 05:50 AM   #9
Sniepster
Drives: 2013 Toyota 86
My blower motor makes the same noise, will try the WD-40 trick whenever i have time. '13 GT86 with 69k miles on
Sniepster is offline   Reply With Quote
Faint, high-pitched whistling sound retrosmiths Issues | Warranty | Recalls / TSB 45 09-20-2022 12:42 AM
Occasional high pitched squeak Midjetv8 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-28-2016 07:00 AM
High Pitched Noise, Engine Off TheLaughingMan Issues | Warranty | Recalls / TSB 10 01-04-2014 05:25 PM
not very loud, but high pitched sound at 70+mph fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 16 10-16-2013 10:30 PM
TSB - FRS (re: High pitched chirping...) PNW FRS Issues | Warranty | Recalls / TSB 1 01-19-2013 01:05 AM
