Old 09-05-2019, 12:23 PM   #15
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by FineVisionz View Post
What I don't get is how is this car flush, with 17x8 +35 wheels
https://www.fitmentindustries.com/wh...d1-av20-eibach
While this car with 18x9.5+35 is also flush,
https://www.fitmentindustries.com/wh...dspeed-project
Many different things going on. Different suspension, amount of drop, camber settings, and tire size. (and of course wheel size)
A 18x9.5 +35 wheel will poke 19+mm more than a 17x8+35. Additionally, a 245/35/18 is stockish diameter. A 235/45/17 is 2.8% bigger in diameter than OEM. (almost to the suggested limit of + or - 3% different than OEM.
OEM 24.6" diameter
245/35/18 24.8" diameter
235/45/17 25.3" diameter
245/40/18 25.7" diameter - 4.5% larger!
Judging from the photo, the blue car is running Sportline springs. And, my educated guess is that they are good for -2.2 or so rear camber. This amount of camber makes the rear look good.
But, unlike in the rear, lowering will not add a usable amount of camber in the front. You will need camber bolts. (or some way to add camber in the front - like the camber plates on the other car) This is why there is no good pic of the front of the blue car.
The car with coilovers has -2.0 or more front camber to look like it does. it also is dropped more and has Rear LCA.
FYI: Adding rear (natural) camber by lowering may not be even side to side. After I installed 1" drop springs my camber was -1.8 and -2.2 left and right.
To correct this discrepancy, (even it out) I installed LCA.
I would suggest a 235/40 or 245/35 over a 245/40.
I LIKE TIRES!
Will BRZ (09-06-2019)
Old 09-06-2019, 01:19 AM   #16
FineVisionz
FineVisionz's Avatar
Drives: Series.Blue
OEM 24.6" diameter
I guess what i'm still confused on is how does a wheel that is 1.5 inches skinnier with the same offset still produce flush fitment?
FineVisionz is offline   Reply With Quote
Old 09-06-2019, 01:55 AM   #17
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
OEM 24.6" diameter
Wow great information. Honestly never knew a 245/35/18 was so similar to stock diameter. Must be a great size tire for like an 18x8.5 wheel or something for our cars considering the power. Seems like that’s the sweet spot for 18s. Suspension and fitment has always been my weak spot when it comes to cars lmao so thanks for sharing bro
Will BRZ is offline   Reply With Quote
The Following User Says Thank You to Will BRZ For This Useful Post:
Leonardo (09-06-2019)
Old 09-06-2019, 11:49 AM   #18
Leonardo
Country Boy 4 Life
Leonardo's Avatar
IMO, the answer is a combo of: camber, suspension parts installed, camera angle, ride height, tire size, and a wildly different perception by each owner of what flush Actually is.
All these things add up to, two different points of view.
I had springs /spacers, but then I installed these parts. They CHANGED the car adding adjustment where there was none before. This changed my perception of flush. I also have tried 5 different thickness of spacers, multiple different staggered and square wheel setups, and four different ride heights. (all the ride heights were very conservative though)
I LIKE TIRES!
Old 09-06-2019, 02:08 PM   #19
FineVisionz
Drives: Series.Blue
This makes sense. I guess my search for flush fitment.
Just for reference, this is my opinion of flush fitment...
I just don't want to run spacers.
The Following User Says Thank You to FineVisionz For This Useful Post:
Leonardo (09-07-2019)
Old 09-06-2019, 07:52 PM   #20
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
Bro just run 18x9.5 +38 with coilovers and drop about 2". Don't need LCA or camber plates as long as your coils are adjustable.
Problem solved...
Shizuka is offline   Reply With Quote
Old 09-06-2019, 08:28 PM   #21
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Spacers are great for anyone that wants to make a wheel flush that doesn't come in an offset that is flush. They are also great for making wheels fit after installing a BBK with flat calipers.
I'm running 18x9+42 square with 12mm front and 15 mm rear slip spacers. making the offsets +30 front & +27 rear.
The 18x9 was only available in +42.
Additionally, spacers are cool cause you can change them.
First I thought a 10mm was going to work for the rear, but then went 12mm, and finally settled on 15mm.
I have hubcentric single bolt pattern spacers that are the same diameter as my brake rotor hub. Once you install extended studs, they really are almost part of the car. I've never had any problems.
I LIKE TIRES!
Old 09-07-2019, 01:41 AM   #22
FineVisionz
Drives: Series.Blue
Problem solved...
I'm mean... Ok, lol. The wheels I want are 18x9.5 +38 and the flex z coilovers I have are adjustable
Old 09-07-2019, 11:47 AM   #23
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I was contemplating new wheels to improve the look/stance...as a stopgap I installed 20mm/25mm spacers. And, I couldn't believe the difference they've made to the car.. stopped looking for new wheels.
What did the spacers do to your handling? I've been thinking of them since i have the extended lugs to install when I redo all my brakes. I want the rear more planted under power.
Old 09-07-2019, 12:06 PM   #24
JD001
JD001's Avatar
Drives: Subaru BRZ
I had the car dropped on Eibach Sportlines at the same time.. the drop in height was more of note. Hadn't messed with the front camber but had done the tracking at the same time... later on I went for the front camber bolts, what a difference they made!! Car was keener to turn and very pointy.. love it..
A few months back I had the STI Group N engine and transmission mounts installed which has further enhanced the lock down feel at the front end. I must change my tyres but can't make up my mind, go all out for a summer compound or compromise.
The Following User Says Thank You to JD001 For This Useful Post:
Old 09-07-2019, 02:19 PM   #25
Will BRZ
Drives: 2015 BRZ
Do you have pictures of that setup? Don’t think I’d run it but very interested in seeing it lol
Old 09-07-2019, 03:46 PM   #26
JD001
JD001's Avatar
Drives: Subaru BRZ
Here you go. I have posted photos elsewhere on this forum but can't find them...
The Following 2 Users Say Thank You to JD001 For This Useful Post:
JesseG (09-19-2019), Will BRZ (09-07-2019)
Old 09-07-2019, 03:52 PM   #27
Will BRZ
Drives: 2015 BRZ
Damn that looks pretty good
JD001 (09-07-2019)
Old 09-07-2019, 04:16 PM   #28
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I had 18x8 +45 wheels and read that 18x8 +35 was flush, so I installed a 10mm spacer. (and was disappointed) IMO it was not flush. So then went to a 15mm. Then a +25mm bolt on. Essentially making the front wheels 18x8 +20. IMO, this is flush. (you could go 18x8 +15 in the back even)
Anyway, I have taken my wheels on and off probably like 100 times... I'm on my 3rd set of studs and 5ths set of lug nuts. I hacksawed the extended studs to be able to put the bolt on spacers. Then ended up removing the shaved studs and replacing them with fully extended studs. I have also tried a few different camber bolts and variations. top only, bottom only, both holes, etc.
I have learned a lot about the car and what will fit on it. My suggestions are based on my own experiences with my car and from what other members have posted.
(Part of the reason for all the parts above: I Wanted to know first hand about the installation process, how they change the car, and how they make wheels fit)
I LIKE TIRES!
new2subaru (09-07-2019)
How's the fitment of 1320's dual res fp fitment on AT aznchris Engine, Exhaust, Transmission 0 04-16-2019 07:02 AM
Spacers for flush fitment on 225's? scubastove Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-16-2017 01:27 PM
Stay Low & Flush or Race Mode Functional with FR Sport's Fly Fitment Special FRSport.com Wheels and Tires 0 08-08-2014 02:25 PM
Need Opinions on Wheel Offset (+35 or +15) for Flush Fitment Dustin2JZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-30-2013 09:33 PM
Why can't the BRZ GT300 or factory BRZ wheels have flush fitment? switchlanez BRZ First-Gen (2012+) — General Topics 43 03-19-2012 01:50 PM
