Old 07-19-2012, 10:56 AM   #911
Visconti
Drives: 05 STi
I'm still driving home... Fml lol
Visconti is offline   Reply With Quote
Old 07-19-2012, 10:59 AM   #912
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Have a safe trip, we need you ))))
btw, where do you drain the oil from the turbo, if you do ?
MSTiFK8R is offline   Reply With Quote
Old 07-19-2012, 11:05 AM   #913
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by lordtakuban View Post
I think he was making a generalization. Typically young drivers are inexperienced. That's not to say ALL young drivers don't know what they're doing behind the wheel. Frankly, I'm shocked that we've already seen threads about wrecked ones. I find it nearly impossible to get the car upset in the rain with TC off (Without trying like hell to do so). I don't think all young drivers are inherently bad, but the wrecks so far have not been from "old" guys. I think old on this forum means people over 30 like me. hahaha. Anyway, congrats on the swapped Cressida.
Back to topic, this turbo kit looks promising. 4psi is probably all it really needs. The boost is what is filling the low end torque valley of the stock dyno graph.
Same here. You have to be really rough with the inputs. That's the only way I've gotten the car to misbahave so far.
Swapped Cressida = awesome. MT Cressida is awesome enough, I still look around for one to build every 6 months or so.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-19-2012, 11:12 AM   #914
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by mastertech86 View Post
the dark lines are actual and the faded lines are baseline...the faded lines are higher than the darker lines below 5500RPM...
edit: already answered... but.
TQ/HP will always cross at 5252 which is what you are seeing, but you are confusing the TQ curve of the car post turbo/tune as the horsepower curve of the baseline pull.
The only place it is down on power is <2,900rpm and that's likely from the dyno and not reality.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-19-2012, 12:10 PM   #915
Don@Accelerated
Don@Accelerated's Avatar
The humiditiy last night was pretty bad. I suspect the HP is a fuzz higher than we actually dyno'd. The car feels like a different animal. We'll keep pushing it farther as we go. Both of us had worked from 9am yesterday to 4am today on the car. Needless to say we were both delirious.
-Don
Originally Posted by Baker View Post
People said that the compression ment it could not be turboed....
+52.37 WHP :P id be happy with that
I calculate a 32.43% rear power increase at current....
At fly if in preportion
200*1.3243 = 264.86hp
Not sure of drivtrain calcs.
13.0925 per PSI
6 PSI*13.0925 = 240.05WHP
6 PSI at fly estimate 297HP
Thats if it will take it and if all the variables are at the same as they are on last dyno
Oh and if my math is right. if not feel free to correct me...
Don@Accelerated is offline   Reply With Quote
The Following User Says Thank You to Don@Accelerated For This Useful Post:
cobrabyte (07-19-2012)
Old 07-19-2012, 12:12 PM   #916
Don@Accelerated
I've roughly spent about 3 weeks ironing out the hard parts thus far. $ Lotttttttttsssss!
Originally Posted by muddog7898 View Post
So how much have you, Don@Accelerated, spent so far, time and money wise on building this?
Old 07-19-2012, 12:13 PM   #917
Warex
Warex's Avatar
Drives: 2013 Subaru BRZ
Nice thread and awesome project.
I am curious when the fuel system will tap out. Are you guys mainly adding fuel through the port injectors or through the DI injectors?
Also, has EcuTek or anyone figured out what the injection strategy is on this engine? I'm assuming on startup it probably uses a distributed injection with only the DI injectors then switches to a single firing with possibly the port injectors doing some amount of work.
Warex is offline   Reply With Quote
Old 07-19-2012, 12:15 PM   #918
Don@Accelerated
Not behind the wheel. We were not pressing that hard on it. We didn't feel the need to crank on the 4psi it was producing. I noticed today while driving it, it actually creeps a little bit. Peaks around 3 and creeps to 4. Probably why the tq is so linear
im curious on driving impressions cause from what im seeing on the dyno graph the car seems lifeless below 4500rpm...
Old 07-19-2012, 12:15 PM   #919
Don@Accelerated
Its all relative to your foot. I'll watch the MPG's on this next tank.
Originally Posted by blackfireball5 View Post
Don, i know it may be very early in the process to tell, but i figure you have past experiences also.
What kind of fuel economy changes can you expect from going FI?
blackfireball5 (07-19-2012)
Old 07-19-2012, 12:17 PM   #920
Don@Accelerated
Which dyno graph are you looking at. It makes more power the entire time!
Old 07-19-2012, 12:21 PM   #921
Gen
Drives: Scion FR-S
It sounds like it's difficult to tune correctly. What are the implications of this for having it tuned locally?
Gen is offline   Reply With Quote
Old 07-19-2012, 12:29 PM   #922
mastertech86
mastertech86's Avatar
Drives: 2009 scion tc turbo
my mistake, i was reading it wrong *slaps forhead* great work thus far tho, you guys are doing amazing work =)
mastertech86 is offline   Reply With Quote
Old 07-19-2012, 12:52 PM   #923
djdnz
1337
Drives: 2013 BRZ WRB S/C
Having already gone through this once before, from N/A stock to turbo on my current car, I'm curious if the ECU has any provisions for tuning while in boost? My car had none, so my tuning capabilities were limited until I went with EIC and 4 extra port injectors. Even then I had no ability to adjust timing while in boost with the stock ECU.
Just curious on what you guys found while tuning it.
djdnz is offline   Reply With Quote
Old 07-19-2012, 12:55 PM   #924
Don@Accelerated
I was dragging getting up this morning. I had a rough time falling to sleep after pounding around the streets at 3am OPEN WASTEGATE. I'm sure people were wondering what the hell all the noise was.
I've never run the dyno that late at night before. I can't believe the police did not come.
My initial impression of this kit is fairly good. I myself need more power and i'll work that out as we go along. I spent a lot of time and money on this kit to make it perform the best it can in a long term general public perspective.
John Visconti drove here yesterday from Chicago. Dredged a monsoon and worked til 4am with me last night. If that doesn't say anything about his character, I don't know what to tell you. He spent countless hours fixing and revising and working out the bugs. The cars obviously not 100%, John and ECUtek will sort it out. I'm not that concerned about the tuning, although I must admit i'm not used to sitting in the background while someone else is tuning.
That being said, hats off to John and EcuTek and lets turn the boost up!:happy0180:
-Don
The Following 13 Users Say Thank You to Don@Accelerated For This Useful Post:
blackfireball5 (07-19-2012), civicdrivr (07-22-2012), clevrname (07-19-2012), cobrabyte (07-19-2012), HotLeopardMama (07-19-2012), ill86 (07-19-2012), JiB (07-19-2012), kwood9000 (07-19-2012), mechaghost (07-19-2012), MSTiFK8R (07-19-2012), Sall (07-19-2012), Spaceywilly (07-19-2012), UncleFester (07-19-2012)
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
