Drives: '19 Toyota 86, MT, Asphalt
grinding noise while turning/slipping clutch
Hey guys,
After the 2nd time I accidentally slipped my clutch pretty hard at high RPM (haven't done it since, whew) I've felt a weird grinding feeling/noise coming through the clutch pedal when I have the steering wheel turned all the way and I'm letting the clutch out in 1st gear (like taking off from a stop and turning right). Everything feels fine and smooth otherwise. It doesn't always happen, but it's specifically only when the steering wheel is turned all the way and I'm accelerating while slipping the clutch. I'm slipping it minimally and under gentle throttle, too. I have a lighter touch now that I'm more used to the manual. Car only has ~1500 miles on it. Any ideas? To help visualize, it goes like this: -stopped at a stop sign -turn the wheel all the way to the right -rev to about 2k and let out the clutch gently -feel a BRRRR through the clutch pedal for about half a second while taking off -car runs just fine otherwise so weird! |
#2 |
#3 | |
It's also only on takeoff in 1st gear. If i'm rolling, like changing from 1st-2nd or 2nd-3rd, it doesn't happen. |
#4 | |
Are you on the original clutch? |
#5 |
#6 |
If you shift slow is the noise still there? Typically a noise after the shift completes would be the input and output transmission shafts not spinning at the same speed, but with a new car like yours it still shouldn’t make any noise.
With any new car, I’d take it to the dealership to get a free repair asap. Worst thing they can say is they want the noise to be worse before they fix it, which means they’ll make note of it and fix it inevitably. |
| Grinding Noise When Turning Left | ThatAsianBradah | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 03-20-2023 11:55 AM |
| Grinding Noise While Turning During Track Event | J1Avs | Issues | Warranty | Recalls / TSB | 5 | 09-16-2018 04:40 PM |
| clutch grinding noise | BoxerBlock88 | Engine, Exhaust, Transmission | 13 | 11-14-2015 06:12 AM |
| new clutch slipping already? | nickmerronesucks | Engine, Exhaust, Transmission | 12 | 10-07-2015 02:33 PM |
| Clicking / tapping sound + fuel pump noise + clutch grinding | Mikeez | Issues | Warranty | Recalls / TSB | 11 | 04-26-2015 11:19 PM |
