Old 09-21-2015, 04:56 PM   #1
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
new clutch slipping already?
Just put this ACT-SB8-HDSS clutch in..I am boosted..running it for a little over 500 miles now and it started to slip already..going to drop the trans tonight but before i do..anything think its anything else? I've already attempted to adjust the pedal with no noticeable outcome..only slips randomly like sometimes i can do a 1, 2nd, 3rd pull fine..other times i slam second and slippppp. but it the car still pulls its a weird slip.
Then right after that ill go to start off from first and itll slip like crazy.
Wondering if i just didnt break it in long enough. And from what i see all of ACT's clutch kits use the same pressure plate so hopefully i can drop the trans and pop a better disc in.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 09-21-2015, 05:44 PM   #2
humfrz
hmmmm........sounds like you clutch pedal doesn't have enough free play at the top.
How much does it have, when you adjusted the clutch travel .... ??
humfrz
Old 09-21-2015, 05:46 PM   #3
nickmerronesucks
Ned flanders
humfrz
As of right now i adjusted it quite a bit up toward the seat..
Sent from my SPH-L720T using Tapatalk
797Performance.com
Old 09-21-2015, 09:37 PM   #4
How much torque do you make?
Old 09-22-2015, 07:04 AM   #5
M1K3
M1K3's Avatar
Drives: vrooom...
I recently had the same issue. I started off with the SB7-HDSS and it held 330 lb/ft for about 1000 miles and then I noticed it start to slip. Like you it would hold sometimes and then sometimes not, though I only tested this out two times after the second time I knew what I had on my hands and did not want to mess up the FW or PP surfaces. I called ACT and just picked up a sprung 6 puck disk and swapped that out and love it. I was worried it would be harder to drive, but I feel like it is easier to drive than the organic disk. Oh and another good thing about the 6 puck is that you really don't have to break it in too much.
M1K3 is offline   Reply With Quote
Old 09-22-2015, 07:08 AM   #6
nickmerronesucks
Ned flanders
Unsure because i still havent been able to hit the dyno cause my clutch isnt doing its job.
797Performance.com
Old 09-22-2015, 07:09 AM   #7
nickmerronesucks
Ned flanders
Wow. Hopefully this is all i need to do. Plan on dropping it out this week. It rained today so i didnt get to. Will keep this updated...clutch is rated at 280tq which im pretty sure im not making that much
797Performance.com
Old 09-22-2015, 07:27 AM   #8
PunX
Drives: GT86 - minor mods
I agree with M1K3 - i got ACT 6 puck with super light FW and HD pressure plate and i love it. Much easier to drive than stock or organic, very predictable - every F time. Truly a good advice.
PunX is offline   Reply With Quote
Old 09-22-2015, 07:29 AM   #9
nickmerronesucks
Ned flanders
I was hoping a 6 or 4 puck would give me a better pedal feel. Unlike most frs/brz owners im not to picky on how stiff the clutch is. Id actually prefer a stiffer pedal like all of my old s13s.
Welp might just order the damn disc now before i drop it.
797Performance.com
Old 09-22-2015, 11:41 PM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
This will fix the lack of feel.
If you've replaced your clutch, this is nothing. 40 bucks.
Old 10-07-2015, 11:09 AM   #11
nickmerronesucks
Ned flanders
Wow didn't realize how long the car was down for..well new disc came in on friday. I dropped the trans out a week or so ago. Appears the disc just looks like it was slipping, so resurfaced the flywheel, cleaned up the pressure plate and put it back together with the new 4 puck disc.
Wish me luck.
All thats left is to add my fluid and put my shifter in. Also used this as an excuse to install a trans mount insert and a shifter bushing
797Performance.com
Old 10-07-2015, 01:42 PM   #12
Ultramaroon
not playing cards
Good luck!
Old 10-07-2015, 02:33 PM   #13
nickmerronesucks
Ned flanders
Good luck!
I may do that slave and a stainless line next. My slave was giving me an issue going back in. I had to release pressure for some reason
797Performance.com
AT Slipping Issues OpteronO3 Issues | Warranty | Recalls / TSB 5 06-15-2015 12:28 PM
FR-S and the clutch is slipping. Where can I get it fixed in Cincinnati? rinnamon Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 08-08-2014 09:56 AM
Slipping to left from start when taking off =( HillCountryGuru Issues | Warranty | Recalls / TSB 5 04-19-2014 07:07 AM
Auto Trans Feels like it is slipping... Fett4Real Issues | Warranty | Recalls / TSB 19 01-16-2014 10:02 PM
AT Second Gear Slipping EK_Golfer Issues | Warranty | Recalls / TSB 13 12-23-2013 11:40 AM
