Old 06-27-2019, 08:31 PM   #1
norcalpb
norcalpb's Avatar
(SOLVED!) Loud transmission clunk
Hi all,
I have about 130,000 miles on my 2013 and I've just developed this ultra loud transmission clunk when making right turns only under acceleration.
This noise is not there when I have the clutch in and take a right turn.
My throwout bearing is about to go out again based on the compressed air noise it makes when I put my foot on the clutch, but I think this issue is unrelated to the throw out bearing.
I had my diff/transmission serviced 10k miles ago with Motul, no signs of leaks or anything.
I checked my transmission mount and everything looked fine and all the bolts were properly torqued. When I rev the car in Neutral I don't hear any noises so that may rule out engine mounts. The noise is coming from directly in front/below the shifter.
Anyone have any idea on what this noise could be??? Not only is it loud, but it shakes the whole car violently.
TIA.
[ame]https://www.youtube.com/watch?v=xh6UrAzf4aE[/ame]
[ame]https://www.youtube.com/watch?v=9fyJaFtMELU[/ame]
Old 06-27-2019, 09:08 PM   #2
norcalpb
norcalpb's Avatar
Also noticed a fluid coming out of my driver's side axle. Looks like the CV joint.
Is this something to be worried about?
Passenger side looks normal I guess:
Old 06-27-2019, 09:56 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
First the boot cracked. Then the lube spun out. Now the CV joint is shot.
Textbook failure.
Use this format.
jcw99 (06-29-2019), norcalpb (06-27-2019)
Old 06-27-2019, 10:05 PM   #4
norcalpb
norcalpb's Avatar
Textbook failure.
Use this format.
Would a failed CV joint make such a bad noise? It sounds like it’s coming from the transmission but I know how deceiving noise transmission can be.
Old 06-27-2019, 10:18 PM   #5
Ultramaroon
not playing cards
Let me backpedal after listening again. I'm used to hearing the popping/cracking sound of a FWD CV joint in a tight turn. This is not the same case for the output shafts of a differential.
I think the slight difference in sound is due to a combination of slop in the failed CV joint along with the locking action of the Torsen.
jcw99 (06-29-2019)
Old 06-27-2019, 10:30 PM   #6
norcalpb
norcalpb's Avatar
That would make sense, as this problem has slowly gotten worse and worse over time. It's only in the last week that it has become an audible concern.
I'm wondering if my last track day tore a boot and I'm now starting to feel the repercussions. Will this potentially damage the differential?
Old 06-27-2019, 11:16 PM   #7
Ultramaroon
not playing cards
Death by a million little hammer blows. Spline joints, gear teeth, and bearing races hate impact energy. Your diff won't grenade tomorrow but why beat on it if you don't have to?
Until you fix it, try to plan your corners so you coast through them as much as you can.
jcw99 (06-29-2019)
Old 06-27-2019, 11:22 PM   #8
norcalpb
norcalpb's Avatar
Ok that’s good to know. If I crawl around sharp right hand turns it won’t make the noise so I think that’ll be the way to roll. It’s my only car atm so I need to take it to and from work.
I have an appointment at an 86 shop next Wednesday, but I’ll have it looked at before then.
For it to make so much noise, the joint must be totally void of grease...but it would make sense how a sharp right turn under throttle would upset the driver side axle as it’s supporting a ton of weight from the car.
Looks like $320 for an axle fml.
Old 06-27-2019, 11:29 PM   #9
Ultramaroon
not playing cards
Meh. That's about right. Stay away from the rebuilt ones. I learned that lesson the hard way. :/
Old 06-28-2019, 02:21 AM   #10
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Woh.... crunchy cv bearing.
I'll concur with everyone and say it's your axles.
But...if it was me I'll just rebuild them from good axle shop. I'll just make sure they come with a nice warranty. $300 is a bit pricy. But at the end of the day it's your wallet not mine.
Old 06-28-2019, 01:34 PM   #11
norcalpb
norcalpb's Avatar
I called a couple shops and they said they replace the axle instead of rebuilding due to labor costs. They probably wanna stick me with an off-brand axle, but is that even a bad idea?
Old 06-28-2019, 01:42 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can try hitting up CL or facebook market place for a car being parted out. I have a spare set of CV's I picked up that way.
Old 06-28-2019, 04:05 PM   #13
norcalpb
norcalpb's Avatar
Do you separate the CV joint from the axle and collect them that way?
Old 06-28-2019, 04:13 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No, I got complete axles with CV
The Following User Says Thank You to NoHaveMSG For This Useful Post:
norcalpb (06-28-2019)
Loud Clunk while driving Flame9020 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 04-23-2018 09:28 PM
Automatic transmission clunk when stopping snidd111 Issues | Warranty | Recalls / TSB 7 01-19-2015 07:27 AM
Loud clunk from rear of car tennisfreak Issues | Warranty | Recalls / TSB 14 11-26-2014 12:55 PM
Loud clunk noise when i pull E-Brake Deagle50 Issues | Warranty | Recalls / TSB 28 09-20-2014 01:01 AM
Loud pop/clunk under braking. Panda Grahams Issues | Warranty | Recalls / TSB 2 07-26-2013 03:13 PM
