Old 04-16-2017, 12:03 AM   #15
The_Understated
Hooner in training... eh?
The_Understated's Avatar
Drives: 2013 Scion FRS
Originally Posted by Pat View Post
I'm listening....
Try to do some digging on here (or HIDPlanet as well), for local shops near you that offer headlight retrofitting services. That's probably going to be the best option if you're trying to get a specific look and output for around or less than the price of replacing the OEM $1500 healdights.
If you're unfamiliar with retrofitting: a shop will take apart your headlights and install a different set of projectors, bulbs, lens, etc in to your preference. HIDPlanet and The RetroFit Source are probably the two best places to start.
Start there and see if anything piques your interest. Here's a quick review of the Spec-D headlights from a member that has some amazing retrofitting skills: http://www.ft86club.com/forums/showthread.php?t=63406
Also from the same guy, one of the more ambitious projects you can shoot for: http://www.ft86club.com/forums/showthread.php?t=33559
**Dunno what to put here yet... Imagine something witty...**
The_Understated is offline   Reply With Quote
Old 04-16-2017, 12:19 PM   #16
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by The_Understated View Post
That's probably going to be the best option if you're trying to get a specific look...
Thanks for the extra info. I don't really care much about how my headlights look, though. I want excellent output for little money. Style doesn't really matter to me.
Old 04-16-2017, 01:32 PM   #17
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Car dismantles or breakers. Avoid the aftermarket tat.
Scrappydoo is offline   Reply With Quote
Old 04-16-2017, 02:26 PM   #18
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks. I've been trying those with little success. I did find a place in CA that has something that would probably work, but still kinda pricey.
Old 04-19-2017, 04:35 AM   #19
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Thanks, Efferalgan. Is there anything else you can tell me about them? Build quality? First-hand experience? Preferred distributors?
Check this thread out:
http://www.ft86club.com/forums/showthread.php?t=102373
It's not as awesome as BMW adaptive LED that I have on another car but close and night/day difference with Spyders I had previously which were just crap both in light and build quality. I had to swap the stock ones as I swapped the stock bumper and needed indicators inside the unit. Otherwise, I'd not touch stock lights which were quite good (I had the xenon European spec).
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
Pat (04-19-2017)
Old 04-26-2017, 09:36 AM   #20
Wyattkb
Drives: 2014 Whiteout FRS
Just though I would chime in here. I bought a set of Spec D headlights and retrofitted them with stuff from https://www.theretrofitsource.com/.
I went with the MORIMOTO FX-R 3.0 which required me to make custom brackets. But they have other options that literally bolt up no problem. The difficulty is pretty low, wiring them was the most time consuming.
Light output and cut off is comparable to a high end luxury car.
Wyattkb is offline   Reply With Quote
Old 08-06-2019, 02:36 PM   #21
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
https://www.amazon.com/MOSTPLUS-Sequ...CG40NWHEZZMBV9
Does anybody have any experience with these? Do they come with a harness? I'm assuming they are not plug and play with the MY13-16 BRZ, but could it be done easily?
Old 08-06-2019, 02:40 PM   #22
Irace86.2.0
Answered my own question, maybe.
[ame]https://www.youtube.com/watch?v=9lTlYfsPQTQ[/ame]
Old 08-06-2019, 05:02 PM   #23
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
A friend has a set of Vland's. The LED eyebrow was flicking on and off randomly a while back. They were working again last I spoke with him.
The fitment isn't perfect either. For $200-250 per headlight they're an upgrade over halogens.no where near OE quality.
The Following User Says Thank You to RToyo86 For This Useful Post:
Irace86.2.0 (08-06-2019)
Old 08-06-2019, 05:35 PM   #24
Irace86.2.0
Vlands and the amazon posting look the same. There are a few more "brands" with the same design. What do you think, did the same place produce them then sold them to difference brands, or are they just all slightly different copies?
Old 08-06-2019, 07:04 PM   #25
RToyo86
RToyo86's Avatar
Hard to say. They could be the same lights rebranded.
Or worse, they're knock offs which means they're probably worse but who knows. I see no reviews, so you'd be taking a shot in the dark. Worst case the light pattern is crap and you could gut them and put in quality projectors.
Old 08-06-2019, 07:10 PM   #26
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
I would recommend that you look into Morimoto headlights if you're looking for a very high-quality option! I have them on my FRS and LOVE them! Pics below!
They are plug-and-play and use only LED bulbs. A 5-year warranty is offered from Morimoto, and the DRL's look amazing IMO! Light output is great as well, didn't need to adjust the headlights at all.
-Sam
eastendraceshop is offline   Reply With Quote
The Following User Says Thank You to eastendraceshop For This Useful Post:
Old 08-06-2019, 09:23 PM   #27
Irace86.2.0
-Sam
They look the same as the FT86Speedfactory units. Any difference? Those do look nice, but I think the verdict is out on HID/projector versus LED for light quality. I would say the boomerang look of the Vlands is more my taste.
@RToyo86
I’ve read this elsewhere, that the projectors are bad. What does that mean? The bulb has defects in the glass, or the concavity is warped or not ideal? Shouldn’t the stock HIDs plug into the projector and work?
Old 08-06-2019, 09:28 PM   #28
eastendraceshop
The housing is exactly the same and is from the same housing. The difference is that each company uses their own bulbs. The LED low beams on the Morimoto headlights seem to work better than the HID's that I had in my stock housing and Winjet headlights. Can't say how they would compare to the Vland's though, I haven't had much experience with those yet.
-Sam
Irace86.2.0 (08-07-2019)
15mm Highest Quality Spacers Mr. Wheels and Tires 8 08-24-2016 01:39 PM
Quality Aftermarket Lights Fenix Cosmetic Modification (Interior/Exterior/Lighting) 14 03-01-2016 09:21 AM
Highest build quality cat-back? NWFRS Engine, Exhaust, Transmission 5 09-07-2014 01:19 PM
Varis Arising II - highest quality made kit I hv ever seen RehabJeff86 Cosmetic Modification (Interior/Exterior/Lighting) 12 07-16-2014 08:32 PM
Aftermarket LED Tail Light Quality randel_07 Cosmetic Modification (Interior/Exterior/Lighting) 8 09-15-2013 07:57 AM
