Old 02-19-2016, 12:56 PM   #1
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
Quality Aftermarket Lights
I try to avoid poorly made aftermarket. A lot of you have replaced the OEM lights. Buying solely on looks would be a mistake. I ed quite a bit. Any recommendations based on your experience? 'Avoid XYZ brand...'
Fenix is offline   Reply With Quote
Old 02-19-2016, 01:02 PM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Headlights? Tail lights? Side markers? Which lights are you referring to?
jawn is offline   Reply With Quote
Old 02-19-2016, 01:36 PM   #3
HachiRo
Drives: 2013 White-Out FRS
If you're talking about tails, I would recommend against fake Valentis. I heard the LEDs on them go out pretty quickly (within a year). Yes, there are fake Valentis and you can see which ones are fake by comparing them to the ones Valenti actually offer.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 02-19-2016, 01:39 PM   #4
Fenix
Fenix's Avatar
Headlights + Tail Lights. I plan to use JDM clear side markers.
I buy genuine parts. You might as well flush cash down the shitta buying knockoffs.
Old 02-19-2016, 02:42 PM   #5
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
You're going to be spending around $1k+ for Headlights alone if you want quality. Or if you want to spend less you can essentially build your own by retrofitting a good projector in there.
YamahaR86 is offline   Reply With Quote
Old 02-19-2016, 03:02 PM   #6
swarb
Not from personal experience, but from what I've read on here. They will all go out eventually unless they are oem. Better aftermarket ones last longer, but the oem are the best.
Old 02-19-2016, 03:36 PM   #7
Fenix
Fenix's Avatar
Both the BRZ and Euro GT86 headlights are nice. Either would cost approximately $1500.
Old 02-19-2016, 03:39 PM   #8
ryoma
ryoma's Avatar
the best bang for your buck in regards to headlights is probably a good quality HID kit. it's way cheaper than buying aftermarket headlights. even though the stock FRS headlights are halogen projectors, they still do pretty well with HID bulbs. remember that you will need an HID "kit" which includes ballasts and wiring along with the HID bulbs. avoid buying cheap HID kits since there is usually a reason why they're cheap. a good place is either The Retrofit Source or Diode Dynamics. however, if you want to do it right, you can retrofit a projector into your housing yourself for a little more... but still cheaper than buying a new quality headlight
as for tail lights, I would say the TOMS are my favorite (I have the red tinted ones). the clear TOMS have problems with melting so try and avoid those. I previously had the clears and swapped them out for the reds after I got hit with the melting problem. a lot of people have Valenti's as well.
Old 02-19-2016, 10:06 PM   #9
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
Headlights I have Winjet, had them for a year and half, the clear coat is starting to peel now, nothing a sand and re clear coat won't fix. Besides that the winjet headlights haven't had any problems. But for headlights OEM is the best. Tail lights, don't buy any unless you get WARRANTY from the vender. If not then you'll be screwed when it condensates or melts. I had clear Tom's and the top part melted a bit cause of the SoCal sun. But for tail lights make sure to use the OEM foam gasket or it will be 50/50 it will leak. Been through 4 aftermarket tail lights so far cause of condensation or bad LED's
KungFuWaffle is offline   Reply With Quote
Old 02-19-2016, 10:14 PM   #10
swarb
Even the red toms have problems. Some have the light leak(not the melting). It's not too noticeable but some still have it.
Old 02-19-2016, 10:49 PM   #11
HachiRo
ModBargains is really good in terms of warrantying and helping you out with Valenti Tails in the event of any condensation (that isn't due to installer error.)
Old 02-19-2016, 11:01 PM   #12
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Bought genuine TOMS' clears and have been using them now for over a year. No issues at all. Bought via japanparts.com. Their quality looks top notch and still looks as new, but I garage my car at work and home so cant comment on the effects of exposure to the elements. Hmm knew I forgot something in my sig!
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 02-20-2016, 06:58 AM   #13
FirestormFlex
Drives: 2015 Turbo FR-S
I've been looking into headlights for a while now - I've read a lot about the cheap aftermarket lights (Winjet etc) having issues with low quality and bad light output, as well as not having true HID projectors. I decided on a set of OEM Monogram headlights. Very pricey but the quality is gorgeous and I've now got OEM Toyota quality/reliability.
FirestormFlex is offline   Reply With Quote
Old 03-01-2016, 02:24 AM   #14
sw20monster
Drives: 2002 MR-2 Spyder
How's the brightness and light beam on the winjets? How simple was the wiring?
sw20monster is offline   Reply With Quote
Wtb aftermarket tail lights fast_dude Canada Classifieds 0 03-29-2015 04:52 PM
WTB: a dark set of aftermarket tails + fog lights BlueDubbinTDI Exterior Parts (Aero, Lighting, Etc.) 1 07-15-2014 01:28 PM
Aftermarket Tail Lights RurumariGhost NY / NJ / CT / PA 13 09-09-2013 10:39 AM
Q for those w/ Spyder aftermarket tail lights Iddoit2er Cosmetic Modification (Interior/Exterior/Lighting) 2 08-03-2013 06:23 PM
Are there any aftermarket Fog Lights for the FRS yet!?!? TheFRSChick Cosmetic Modification (Interior/Exterior/Lighting) 40 04-10-2013 03:14 PM
