Old 04-13-2017, 07:03 PM   #1
Pat
Pat's Avatar
Drives: 2023 BRZ
Highest quality aftermarket headlights?
I was in an accident and need to replace one headlight. My car has 50,000 miles on it. Therefore the headlights are pitted somewhat. Ideally I would find an OEM BRZ HID headlight in about the same condition as my one remaining good headlight, but that is proving difficult. Therefore, I am considering just buying a new pair. However, a new OEM pair is something like $1,500. That's just not a price I'm willing to pay. Other than cost, my major concerns are quality and light output. Knowing how cheap many aftermarket HID options are, I'm skeptical they will be as good as OEM in terms of quality and light output. Can anyone share with me their first-hand experiences with this? What are the highest quality aftermarket options, and how do they compare with OEM?
Old 04-13-2017, 07:31 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
In all honesty, I've had both Spec-D's and Winjets and both didn't seem like good quality. Output on the Spec-D's wasn't good. It felt more like they spread light to the peripherals and left a darker spot in the center of the road. And the Winjets, while fine output, the DRL eyebrow burned out in less than 6 months. So I just bit the bullet and bought some OEM monogram headlights.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Pat (04-13-2017)
Old 04-13-2017, 07:57 PM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
Did you put a WTB ad on here?
Old 04-13-2017, 08:26 PM   #4
Pat
Pat's Avatar
Drives: 2023 BRZ
Yep. And bumped it. Twice.
The Following User Says Thank You to Pat For This Useful Post:
new2subaru (04-14-2017)
Old 04-13-2017, 08:26 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
Do you remember how much the monogram lights were?
Old 04-13-2017, 08:30 PM   #6
weederr33
weederr33's Avatar
I bought them off a member here for $900 and it was totally worth it.
Pat (04-13-2017)
Old 04-14-2017, 08:19 AM   #7
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Coplus LED will be about $1100 shipped. Light beam is better than OEM and simply non-comparable with Spyder, Spec-D and likes.
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
Pat (04-14-2017)
Old 04-14-2017, 10:02 AM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, Efferalgan. Is there anything else you can tell me about them? Build quality? First-hand experience? Preferred distributors?
Old 04-14-2017, 10:33 AM   #9
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
86Speed just got in the Valenti headlights. If you're ok with investing $900 into them I'd say go with them. My girlfriend and I both have the taillights and fourth brake light and they're amazing quality and have amazing output. Haven't had any issues what so ever with them. From the reviews I've read, the headlights get just as much if not more praise. In my opinion, Valenti is the way to go when going aftermarket front/ rear lights.
DaBoBo21 is offline   Reply With Quote
The Following User Says Thank You to DaBoBo21 For This Useful Post:
Pat (04-14-2017)
Old 04-14-2017, 12:55 PM   #10
swarb
IMO there is nothing as good as oem. The closest thing would be retrofitting a housing with a known high quality projector. By the time you've done all that, you could have just bought an oem and not waste your time.
Cheap, fast(bright), good(reliable). Pick two.
There is nothing in the market that I know of that is better than the oem brz headlights because most of the manufacturers are aiming for a price point for the frs owners, and the oem halogens aren't that great so almost anything is better.
The Following User Says Thank You to swarb For This Useful Post:
Pat (04-14-2017)
Old 04-14-2017, 01:04 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, swarb. A big part of me thought this. I was (am?) holding out hope for being proven wrong, but am growing ever skeptical.
Old 04-14-2017, 01:16 PM   #12
Extreme Dimensions
Extreme Dimensions's Avatar
Drives: G35C .: S2000 .: Maxima .: AM .:
your best bet is going to be getting a set redone by a custom shop!
Extreme Dimensions is offline   Reply With Quote
Old 04-14-2017, 01:18 PM   #13
Pat
Pat's Avatar
Drives: 2023 BRZ
I'm listening....
Old 04-14-2017, 02:27 PM   #14
Dennett_
Dennett_'s Avatar
Drives: Sprintex Supercharged FRS
I just got some Spec-D headlights and theyre great if you dont like the output you can get some hids. But id definitely recommend them theyre sick. You can look at them on my member journal.
Dennett_ is offline   Reply With Quote
15mm Highest Quality Spacers Mr. Wheels and Tires 8 08-24-2016 01:39 PM
Quality Aftermarket Lights Fenix Cosmetic Modification (Interior/Exterior/Lighting) 14 03-01-2016 09:21 AM
Highest build quality cat-back? NWFRS Engine, Exhaust, Transmission 5 09-07-2014 01:19 PM
Varis Arising II - highest quality made kit I hv ever seen RehabJeff86 Cosmetic Modification (Interior/Exterior/Lighting) 12 07-16-2014 08:32 PM
Aftermarket LED Tail Light Quality randel_07 Cosmetic Modification (Interior/Exterior/Lighting) 8 09-15-2013 07:57 AM
