Old 08-06-2019, 12:53 PM   #1
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
Torque app w/OBDII and oil temps
I had been logging oil temps just fine on my MY 14. Sometime since updating to OFT 2+ tune, I no longer am getting oil temps. Anyone w/ help??
Sent from my XT1254 using Tapatalk
snuff58 is offline   Reply With Quote
Old 08-06-2019, 01:46 PM   #2
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
I noticed recently that I am not getting oil temp reading anymore either. Didn't check into it yet but I will pass on anything I find.
Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 08-06-2019, 01:56 PM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Are you able to see them using the OFT?
BigTuna is offline   Reply With Quote
Old 08-06-2019, 07:28 PM   #4
snuff58
snuff58's Avatar
I'll give that a try. If I can read the temps, how could it help with the Torque data?
Old 08-07-2019, 12:06 AM   #5
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
I just put a UEL on just over 1 month ago & the day before I installed,l Torque was fine.
I put the UEL & installed OFT & POOF!!!! no more oil temp. Oil temp shows up fine on OFT.
So I sent an email to OFT & received this.....
" Your TQ app shouldn't be useless. If you're using our v4 tune files, you may not have the same channel/data availability that you had before - and the TQ app is recognizing that fact.
Not all software (calibration codes) support the exact same datalogging channels. "
Now if someone could explain what to do it would be great as I like my phone up to see water/oil temps. OFT is just a little too big & worried it would commit suicide & jump out window on a hard turn. I have a RAM mount which is just maybe a little too tight for the tablet.
I have a post up about this about 1 month ago.
Maybe I'll check for updates phone/app?
Tks.
CB750F is offline   Reply With Quote
Old 08-08-2019, 09:24 AM   #6
BigTuna
BigTuna's Avatar
My thought was maybe the PID got changed somehow. However, that doesn't really help being able to find out what it is and how to read it.
Maybe @steve99 has some insight.
Old 08-09-2019, 04:23 AM   #7
steve99
Drives: FT86
Ive noticed the V1.5 kbd adapters seem to read oil temps , but the v2.1 version often have isdue not sure why
Old 08-11-2019, 09:53 AM   #8
snuff58
snuff58's Avatar
I am anxiously looking forward to a solution. Would downgrading my OFT tune back to stage 1 give me any clues?
Old 05-22-2020, 07:34 PM   #9
snuff58
snuff58's Avatar
FINALLY!!!
Found info in this link worked!!!
http://www.ft86club.com/forums/showthread.php?t=23530
BAFX OBDII with Torque Lite MuseChaser Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 05-24-2019 12:43 AM
Torque OBDII Test Results carma143 Issues | Warranty | Recalls / TSB 3 04-14-2015 12:05 AM
BRZ vs. Torque App & Cheap OBDII Adapter extrashaky Issues | Warranty | Recalls / TSB 10 04-29-2014 04:59 PM
HTC One V + Mount + OBDII tool + Torque App Hanakuso Audio/Visual, Electronics, Infotainment, NAV 5 02-04-2014 03:35 PM
OBDII Splitter for OFT + Bluetooth Torque App? 1Cor10:23 Software Tuning 6 11-19-2013 08:33 PM
