Drives: Toyota Highlander; Subaru BRZ (SWP)
Torque OBDII Test Results
Last week I bought and used this product here: [ame="http://www.amazon.com/gp/product/B005NLQAHS/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1"]Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive[/ame]
I connected it to my Limited BRZ (2013) and several tests received a 'FAIL'. I am not confident that I know how to interpret all this. Any help is appreciated. ![]() ---- MID:$0e TID:$0c Misfire counts for last/current driving cycles(calculated) - O2 Bank 4 Sensor 2 Max: 53,336 Min: 22,745 Test result value: 3 FAIL ---- MID:$1f TID:$fe - Max: 53,248 Min: 27,977 Test result value: 323 FAIL ---- MID:$21 TID:$89 - Catalyst Monitor Bank 1 Test incomplete or dependant test failed -- MID:$2e TID:$0c Misfire counts for last/current driving cycles(calculated) - Max: 53,248 Min: 27,961 Test result value: 3 FAIL ---- MID:$0e TID:$0c Misfire counts for last/current driving cycles(calculated) - O2 Bank 4 Sensor 2 Max: 53,336 Min: 22,745 Test result value: 3 FAIL ---- MID:$1f TID:$fe - Max: 53,248 Min: 27,977 Test result value: 323 FAIL ---- MID:$21 TID:$89 - Catalyst Monitor Bank 1 Test incomplete or dependant test failed -- MID:$2e TID:$0c Misfire counts for last/current driving cycles(calculated) - Max: 53,248 Min: 27,961 Test result value: 3 FAIL ---- MID:$3d TID:$cc - EVAP Monitor (0.020") Test incomplete or dependant test failed -- MID:$3e TID:$0c Misfire counts for last/current driving cycles(calculated) - Purge Flow Monitor Max: 53,332 Min: 26,841 Test result value: 3 FAIL ---- MID:$3f TID:$fe - Max: 53,248 Min: 23,881 Test result value: 323 FAIL ---- |
Seeing as your results are all 3 or 323 I think your reader or your OBD2 port or both aren't communicating very well. Don't worry about it if the car is running ok and there are no CEL's on.
| The Following User Says Thank You to FirestormFRS For This Useful Post: | carma143 (04-13-2015) |
Some Dumb Guy
Drives: wanting an Acabian
Check your connection, there have been issues with the OBDII port early on with this vehicle. Pins disengaged and so on.
She said it was her or the car. Longest
she had ever seen. |
| The Following User Says Thank You to Blu-by-U For This Useful Post: | carma143 (04-13-2015) |
#4 | |
Edit: So I found this discussion http://www.ft86club.com/forums/showthread.php?t=39137 . The OBDII device's LEDs flash correctly and connects to my phone just fine, sending rpm data, etc in real time. I'll try it with my Toyota Highlander, and my friend's 2014 BRZ Limited to see if similar issues occur. |
| Tags |
| error, fail |
| BRZ vs. Torque App & Cheap OBDII Adapter | extrashaky | Issues | Warranty | Recalls / TSB | 10 | 04-29-2014 03:59 PM |
| OBDII Bluetooth and Torque app, throwing CEL | BRZPDX | Issues | Warranty | Recalls / TSB | 11 | 03-03-2014 02:03 PM |
| HTC One V + Mount + OBDII tool + Torque App | Hanakuso | Audio/Visual, Electronics, Infotainment, NAV | 5 | 02-04-2014 02:35 PM |
| OBDII Splitter for OFT + Bluetooth Torque App? | 1Cor10:23 | Software Tuning | 6 | 11-19-2013 07:33 PM |
| BT OBDII/Android/Torque Confirmed working | Dadhawk | Engine, Exhaust, Transmission | 54 | 12-06-2012 12:57 AM |
