Drives: Red Brz
Car won’t start after installed injectors
Decided to upgrade to 700cc injectors I followed the instructions and put them on then i started the car. For the first time it ran fine with no leaks then for about 30 seconds I revd it up to about 2,500 it was ok . It was hesitating on idle but I assumed it’s cus I needed to get tuned. I shut the car off and then turned it on to check if it still works and now this happens car won’t even start and I got a code at the end of the video p062d After that, I decided to put the stock injectors back on and the car works fine any thoughts? I’ve tried everything I could think of and I’m also on 10:1 compression Sent from my iPhone using Tapatalk |
#2 |
Drives: 2JZ FRS
did you get it tuned?
| The Following 4 Users Say Thank You to spitfire481 For This Useful Post: |
#3 |
How did you get the compression ratio to 10:1 - ?
Other power mods? humfrz |
#4 | |
https://www.ft86club.com/forums/show...18#post3221718 Quote:
The bigger question is why on earth he dropped the compression!
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (07-11-2019) |
#5 | |
![]() But, shouldn't the car at least start after the injector swap ? "I had a 2 barrel carb on my car and it ran fine, but when I put a 4 barrel carb on, it wouldn't start". Did you hook up the fuel line? Did you hook up the linkage? humfrz - stuck in the 50's -
#7 | |
Drives: Red Brz
It did once I installed it But after I shut it off the car and turned it back on that problem in the video started happening Doesn’t happen when I put stock ones back In Didn’t touch the fuel lines just removed the plate over it and unbolted the fuel rail Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to bryansuriel3 For This Useful Post: | humfrz (07-11-2019) |
#8 |
#9 |
Drives: 2013 frs red
Might have been overly rich?
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | humfrz (07-11-2019) |
#10 |
Drives: Red Brz
Yeah pump gas I’m changing injectors so I can get more hp I was on stock injectors I just got my engine rebuilt so I’m trying to finish this so I can get tuned
#11 | |
![]() https://spdbydesign.com/product/sbd5...-brzscion-frs/ humfrz - maybe I need a mid-morning nap? |
#12 |
Drives: 2JZ FRS
you doubled, or more the injector size without re-scaling the fuel table. Car is so rich its killing itself. You can't just swap injectors over and not adjust the tune.
#13 | |
Drives: Red Brz
But shouldn’t the car start tho? And I’m going to get it tuned I wanted to make sure everything is fine first before scheduling it Sent from my iPhone using Tapatalk |
#14 | |
Which it actually will be if OP keeps changing stuff before he gets a tune!
| INSTALLED TURBO, CAR WONT START | Nightflo | Forced Induction | 23 | 06-23-2018 09:26 PM |
| P0455 EVAP Code after New Direct and Port Injectors Installed? (Vortech Supercharger) | Figo | Forced Induction | 8 | 10-04-2016 01:40 PM |
| car won't start after clutch installed | aquaman | Issues | Warranty | Recalls / TSB | 4 | 07-19-2016 01:29 AM |
| Cold start issue(tune or injectors?) | 86 driver | Software Tuning | 0 | 08-01-2015 02:49 AM |
| Cold start rattle after header,op,fp installed by a newb | aristo | Engine, Exhaust, Transmission | 5 | 10-28-2014 07:28 AM |
