Old 07-11-2019, 09:31 AM   #1
bryansuriel3
bryansuriel3's Avatar
Drives: Red Brz
Car won’t start after installed injectors
Decided to upgrade to 700cc injectors I followed the instructions and put them on then i started the car. For the first time it ran fine with no leaks then for about 30 seconds I revd it up to about 2,500 it was ok . It was hesitating on idle but I assumed it’s cus I needed to get tuned. I shut the car off and then turned it on to check if it still works and now this happens car won’t even start and I got a code at the end of the video p062d
After that, I decided to put the stock injectors back on and the car works fine any thoughts? I’ve tried everything I could think of and I’m also on 10:1 compression
bryansuriel3 is offline   Reply With Quote
Old 07-11-2019, 11:32 AM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
did you get it tuned?
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 4 Users Say Thank You to spitfire481 For This Useful Post:
DarkPira7e (07-11-2019), Irace86.2.0 (07-11-2019), kch (07-12-2019), Tcoat (07-11-2019)
Old 07-11-2019, 11:46 AM   #3
How did you get the compression ratio to 10:1 - ?
Other power mods?
Old 07-11-2019, 11:53 AM   #4
https://www.ft86club.com/forums/show...18#post3221718
Other power mods?
The bigger question is why on earth he dropped the compression!
humfrz (07-11-2019)
Old 07-11-2019, 12:02 PM   #5
Maybe for FI -
But, shouldn't the car at least start after the injector swap ?
"I had a 2 barrel carb on my car and it ran fine, but when I put a 4 barrel carb on, it wouldn't start".
Did you hook up the fuel line? Did you hook up the linkage?
humfrz - stuck in the 50's -
Old 07-11-2019, 12:05 PM   #6
bryansuriel3
Drives: Red Brz
Other power mods?
Sbd Turbo kit
Full catless exhaust
The Following User Says Thank You to bryansuriel3 For This Useful Post:
humfrz (07-11-2019)
Old 07-11-2019, 12:13 PM   #7
bryansuriel3
Drives: Red Brz
Maybe for FI -
It did once I installed it But after I shut it off the car and turned it back on that problem in the video started happening
Doesn’t happen when I put stock ones back In
Didn’t touch the fuel lines just removed the plate over it and unbolted the fuel rail
humfrz (07-11-2019)
Old 07-11-2019, 12:17 PM   #8
Originally Posted by bryansuriel3 View Post
Sbd Turbo kit
Are you running on pump gas?
If so, why are you replacing the injectors?
Old 07-11-2019, 12:41 PM   #9
Lantanafrs2
Drives: 2013 frs red
Might have been overly rich?
Lantanafrs2 is online now   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
humfrz (07-11-2019)
Old 07-11-2019, 12:45 PM   #10
bryansuriel3
Drives: Red Brz
Yeah pump gas I’m changing injectors so I can get more hp I was on stock injectors I just got my engine rebuilt so I’m trying to finish this so I can get tuned
Old 07-11-2019, 12:54 PM   #11
Yeah pump gas I’m changing injectors and so I can get more hp I was on stock injectors I just got my engine rebuilt so I’m trying to finish this so I can get tuned
Well, maybe I'm confused, because I came from the generation where FI meant Fuel Injected, but, according to their web site, you shouldn't have to change injectors if you are using pump gas -
https://spdbydesign.com/product/sbd5...-brzscion-frs/
humfrz - maybe I need a mid-morning nap?
Old 07-11-2019, 01:27 PM   #12
spitfire481
Drives: 2JZ FRS
you doubled, or more the injector size without re-scaling the fuel table. Car is so rich its killing itself. You can't just swap injectors over and not adjust the tune.
MoTeC
Build Thread
@spitfire481
BirdTRD (07-12-2019), humfrz (07-11-2019), Irace86.2.0 (07-11-2019), kch (07-12-2019)
Old 07-11-2019, 01:51 PM   #13
bryansuriel3
Drives: Red Brz
But shouldn’t the car start tho? And
I’m going to get it tuned I wanted to make sure everything is fine first before scheduling it
Old 07-11-2019, 01:52 PM   #14
Yep. The p062d code is for a defective or malfunctioning injector so the car thinks it is broken.
Which it actually will be if OP keeps changing stuff before he gets a tune!
INSTALLED TURBO, CAR WONT START Nightflo Forced Induction 23 06-23-2018 09:26 PM
P0455 EVAP Code after New Direct and Port Injectors Installed? (Vortech Supercharger) Figo Forced Induction 8 10-04-2016 01:40 PM
car won't start after clutch installed aquaman Issues | Warranty | Recalls / TSB 4 07-19-2016 01:29 AM
Cold start issue(tune or injectors?) 86 driver Software Tuning 0 08-01-2015 02:49 AM
Cold start rattle after header,op,fp installed by a newb aristo Engine, Exhaust, Transmission 5 10-28-2014 07:28 AM
