car won't start after clutch installed
So I uograded my clutch, old one came out and new one went in with out an issue. all connections that were disconnected were reconnected. when i went to go turn the key to start it, it cranked but didn't start. I'm now getting three DTC codes U0100, U0122 and U0151. Has anyone had this or a similar issue and have possible resoloutions? I'm thining the ecu is shot... I hope not...
Side note, I know it's not good pratice, but I didn't disconnect the battery before i started... |
Site Moderator
Drives: ichi 86 Project
U0100 is causing the rest of the codes. iirc U0100 is something to do with ECM. Might need to check to make sure to you connected all the wires correctly.
In addition, you may consider disconnecting the battery now ..... to see if the system will right itself.
humfrz |
We've triple check the wire connections and I disconnect the battery earlier today for about a half an hour with no change in status
#5 | |
![]() http://www.obd-codes.com/u0100 humfrz |
| Help!! Car Wont Start After Clutch Swap (25$ reward for solution!!) | bren5279 | Issues | Warranty | Recalls / TSB | 44 | 07-03-2017 08:36 AM |
| Clutch Rattle at cold start | shellslinger | Issues | Warranty | Recalls / TSB | 16 | 10-11-2015 01:45 PM |
| Cold start rattle after header,op,fp installed by a newb | aristo | Engine, Exhaust, Transmission | 5 | 10-28-2014 07:28 AM |
| Push-button start clutch switch | mike the snake | Engine, Exhaust, Transmission | 8 | 04-14-2014 11:31 PM |
| RPM varies, cold start, clutch in and out | 00NissanNinja | Issues | Warranty | Recalls / TSB | 8 | 03-04-2014 11:40 PM |
