#15 |
Drives: 2023 BRZ
What are the chances bleeding and/or replacing the clutch slave would fix it?
Director of Rocky Mountain 86CUP
#16 | |
https://demos.starbase7.net/t3Portal...36214698620217
| The Following User Says Thank You to Tcoat For This Useful Post: | Pat (07-08-2019) |
#17 |
Drives: Track preped NA FRS
I have an ACT as well Pat, same exact problem. I just leave it on because it is not a street car anymore, and it does not bother me while on track, but it does feel like clutch drag to me. I also had it with another clutch, but with OEM flywheel, so it is not related to the flywheel only, but probably a combination of clutch and flywheel depth and the adjustment on the pedal travel. I saw a post somewhere to fix it but I never got around to it.
Edit: also, for what its worth. I did bled the clutch MC completely and it did not help. |
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Pat (07-08-2019) |
#18 | |
Wheels for Brains
The OE TOB actually comes pre-greased on the inner race surface, where it sits on the input shaft cover. When I installed the ACT kit, I put a very light coat of the hi temp grease (that came with the ACT clutch kit) on the splines, TOB inner race, on the input shaft cover where the TOB sits. All of this is per recommendation/common practice. If the clutch disk had problems coming away from the pressure plate, may be due to lubrication issues. Might not be the root cause, but is worth a consideration. |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | fika84 (07-08-2019) |
#19 | |
#20 |
Wheels for Brains
#21 |
Drives: 2013 frs red
Nothing like OEM lol
#22 |
Drives: 2023 BRZ
I bled the clutch with fika84's help and it did not make a difference. I have an appointment with the shop that installed the clutch to see what they think.
#23 |
Drives: 2023 BRZ
The shop that installed the ACT kit removed it and installed an OEM kit and yet ANOTHER redesigned OEM TOB. They said the most recent update to the TOB is very different than every other one. While I'm bummed to lose the benefits of the LWFW, it's nice to be able to drive my car on the street without issues. They said the ACT clutch, flywheel, and pressure plate are fine and were not the issue.
So yeah....who wants to buy an ACT kit with just a few thousand miles on it? The shop said it is in nearly new condition as expected given the mileage.
| The Following User Says Thank You to Pat For This Useful Post: | jcw99 (08-06-2019) |
| Shifting Problem (Automatic) | FRSure | Issues | Warranty | Recalls / TSB | 61 | 05-09-2021 07:38 PM |
| Diagnose my Civic no start | Ashikabi | Other Vehicles & General Automotive Discussions | 30 | 04-21-2019 08:45 AM |
| Problem Shifting into gears. | itzryry | Issues | Warranty | Recalls / TSB | 6 | 01-25-2018 07:19 PM |
| HELP needed to diagnose engine noise | Docmattic | Engine, Exhaust, Transmission | 17 | 01-23-2018 12:42 PM |
| 2013 brz automatic borla header catless down shifting problem from 3rd to 2nd. | rjgough95 | Issues | Warranty | Recalls / TSB | 4 | 10-27-2014 03:37 PM |
