Old 07-08-2019, 02:19 PM   #15
Pat
Pat's Avatar
Drives: 2023 BRZ
What are the chances bleeding and/or replacing the clutch slave would fix it?
Old 07-08-2019, 02:55 PM   #16
Not likely to help but easy enough to try. You may be able to adjust it out as was mentioned.
https://demos.starbase7.net/t3Portal...36214698620217
Pat (07-08-2019)
Old 07-08-2019, 03:09 PM   #17
Icecreamtruk
Drives: Track preped NA FRS
I have an ACT as well Pat, same exact problem. I just leave it on because it is not a street car anymore, and it does not bother me while on track, but it does feel like clutch drag to me. I also had it with another clutch, but with OEM flywheel, so it is not related to the flywheel only, but probably a combination of clutch and flywheel depth and the adjustment on the pedal travel. I saw a post somewhere to fix it but I never got around to it.
Edit: also, for what its worth. I did bled the clutch MC completely and it did not help.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Pat (07-08-2019)
Old 07-08-2019, 03:25 PM   #18
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by fika84 View Post
You mentioned a part about grease on the input shaft. I think this is really interesting and I didn't follow what the manual says.. I definitely put a little bit of Moly Paste (https://www.hondapartsdirect.com/oem...%3D&origin=pla) on the shaft.. I'm still running stock clutch, but do have a lightweight flywheel.
According to the manual, there shouldn't be any grease applied where the TOB travels.. Do you think it's to keep the shaft from getting gunked up in that location?
Well I can't say for sure it was because of the grease (whether there was too much or too little).
The OE TOB actually comes pre-greased on the inner race surface, where it sits on the input shaft cover.
When I installed the ACT kit, I put a very light coat of the hi temp grease (that came with the ACT clutch kit) on the splines, TOB inner race, on the input shaft cover where the TOB sits. All of this is per recommendation/common practice. If the clutch disk had problems coming away from the pressure plate, may be due to lubrication issues. Might not be the root cause, but is worth a consideration.
EndlessAzure is online now   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
fika84 (07-08-2019)
Old 07-08-2019, 03:27 PM   #19
fika84
fika84's Avatar
The Factory TOB comes pre-greased where it sits on the input shaft/cover. I put a light coat of the lithium grease that came with the ACT kit on the splines and on the shaft/cover. If the clutch disk had problems coming away from the pressure plate, may be due to lubrication issues. Just a consideration.
Do you know if the guy you sold the clutch to used grease or not?
fika84 is offline   Reply With Quote
Old 07-08-2019, 03:34 PM   #20
EndlessAzure
Wheels for Brains
Knowing the guy I sold it to, he probably did the bare minimum and didn't take much care in the process.
Old 07-08-2019, 03:42 PM   #21
Lantanafrs2
Drives: 2013 frs red
Nothing like OEM lol
Lantanafrs2 is offline   Reply With Quote
Old 07-10-2019, 04:23 PM   #22
Pat
Pat's Avatar
Drives: 2023 BRZ
I bled the clutch with fika84's help and it did not make a difference. I have an appointment with the shop that installed the clutch to see what they think.
Old 08-05-2019, 03:30 PM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
The shop that installed the ACT kit removed it and installed an OEM kit and yet ANOTHER redesigned OEM TOB. They said the most recent update to the TOB is very different than every other one. While I'm bummed to lose the benefits of the LWFW, it's nice to be able to drive my car on the street without issues. They said the ACT clutch, flywheel, and pressure plate are fine and were not the issue.
So yeah....who wants to buy an ACT kit with just a few thousand miles on it? The shop said it is in nearly new condition as expected given the mileage.
The Following User Says Thank You to Pat For This Useful Post:
jcw99 (08-06-2019)
Shifting Problem (Automatic) FRSure Issues | Warranty | Recalls / TSB 61 05-09-2021 07:38 PM
Diagnose my Civic no start Ashikabi Other Vehicles & General Automotive Discussions 30 04-21-2019 08:45 AM
Problem Shifting into gears. itzryry Issues | Warranty | Recalls / TSB 6 01-25-2018 07:19 PM
HELP needed to diagnose engine noise Docmattic Engine, Exhaust, Transmission 17 01-23-2018 12:42 PM
2013 brz automatic borla header catless down shifting problem from 3rd to 2nd. rjgough95 Issues | Warranty | Recalls / TSB 4 10-27-2014 03:37 PM
